Old 05-24-2012, 05:48 PM   #1
Master Of Disaster
socalelect's Avatar
Default wet location
I know a lb is rated for a wet location
, since when did a wet location mean under water.
Old 05-24-2012, 05:58 PM   #2
Looks like nothing is supported either.
Old 05-24-2012, 06:06 PM   #3
Master Of Disaster
socalelect's Avatar
Good call dennis it was just floating there
Old 05-24-2012, 06:10 PM   #4
chicken steve's Avatar
the codes dry/damp/wet location(s) definitional greay areas are supplemented by nema's standards....~CS~
Old 05-24-2012, 06:51 PM   #5
CADPoint's Avatar
Send a message via AIM to CADPoint Send a message via Yahoo to CADPoint
Where's the fix-it pictures> ?
What's with the flowers, trying to stay up with 480 ? ¿
If your even thirsty, your two quarts low.
Old 05-24-2012, 10:41 PM   #6
Master Of Disaster
socalelect's Avatar
I didn't fix it I noticed it at the harbor freight of electronics. Frys
Old 05-25-2012, 12:30 AM   #7
The LB fitting is not listed for direct suberison in the eau ( water )
Merci,
Marc
Old 05-25-2012, 12:35 AM   #8
Without knowing more about what's in that conduit, I could say that might be a compliant install. If they just ran the submarine cable of the pump in a cable gland in that box, and sleeved it out of the fountain, that could be compliant (supports aside). It's also safe to say an electrician didn't do that, as I note the blue 'rain or shine' glue showing.
Old 05-25-2012, 12:56 AM   #9
Master Of Disaster
socalelect's Avatar
I did see it open a few months ago the sub pump cord is wire nutted to thhn in the box, it's a pretty ugly hacked job, its a shame too a beautiful fountain thing with. A 2 foot marble looking ball that the water spins
Old 05-25-2012, 01:05 AM   #10
erics37's Avatar
Sorta like this thing?
Old 05-25-2012, 01:08 AM   #11
Master Of Disaster
socalelect's Avatar
Sorta kinda but it is like a 8 foot round pool about 1.5 feet deep then in the middle it has a round thing about 2 feet in diameter about 2.5 feet tall that the ball sits it then the water comes up under the ball and somehow spins it they have goldfish in this thing. Wonder how long they will survive
Old 05-25-2012, 01:09 AM   #12
I used to install for www.spinningballfountains.com. Those things were like 20 grand a piece when they first got popular. Their website doesn't exist anymore, which is probably why I haven't done work for them in a long time. This is a snapshot from the Wayback Machine of what the site used to look like: http://web.archive.org/web/200201252...fountains.com/ I installed and wired the one on the right at the top in a mall.
Old 05-25-2012, 01:15 AM   #13
There isn't much the Shunkmeister hasn't done.
The Following User Says Thank You to user4818 For This Useful Post:
walkerj (06-18-2012)
Old 05-25-2012, 01:16 AM   #14
Resi Service Electrician
electrictim510's Avatar
Perfect spot for them to mistake an afci breaker for a gfci type when replacing it.
Question; since the afci breakers "have gfci protection" would it still trip at the same rate? Or is the ground fault protection in a afci device different in that regard?
Stupid question of the day maybe. :shrug:
"Understand one thing every one has a place in this trade, and no matter what your skill set I doubt you know it all." brian john
electrictim510 is offline   Reply With Quote
Old 05-25-2012, 01:17 AM   #15
GFCI's trip at 5 mA.
AFCI's trip at ???? But it's way above GFCI level.
Old 05-25-2012, 01:17 AM   #16
I think I said one time, that if it's weird, I want to be the guy involved in it. Regular electrical work bores me.
Old 05-25-2012, 01:19 AM   #17
Ya, that's your thing. Me, I've come to appreciate mundane electrical work quite a bit. I like coming home and not thinking about what I have to do tomorrow.
Old 05-25-2012, 01:33 AM   #18
I am not sure where I did recall the speces but one breaker manufacter did mention it was 30mA.
Merci,
Marc
Old 05-27-2012, 10:02 AM   #19
I just installed 3 CH - CH "combination" AFCI's and they were labeled as 30mA "earth leakage detection" The standard GFCI's trip at 6mA.
delaware74b is offline   Reply With Quote
Old 05-29-2012, 02:11 AM   #20
PGW Professional
Magnettica's Avatar
The circuit breakers that look like GFCI breakers but trip at 30ma are called GFEP circuit breakers and theyre used for snow and ice melting equipment. 426.28.
Pics of panel location and vase location jwjrw General Electrical Discussion 3 06-26-2010 06:06 AM
hazardours location davis2000 General Electrical Discussion 3 04-20-2010 09:37 PM
Location rlc3854 Off Topic 8 09-20-2009 09:29 AM
WET Location ? manchestersparky Code Violation Discussion 18 03-30-2009 05:46 AM
Location, location, location brian john Introductions 3 11-25-2007 09:13 PM
