11-08-2009, 08:16 AM
Where do you start?
11-08-2009, 08:32 AM
The only way I would touch that is with a total redo- shutting down the building. Perhaps a sealant can take care of the water entering the boxes.
4 Out Of 3 People Have Trouble With Fractions
11-08-2009, 09:14 AM
its hard to tell from the pictures just how many sticks of dynamite you would need to fix that.
Chuck Norris sleeps with a night light. Not because Chuck Norris is afraid of the dark, but the dark is afraid of Chuck Norris.
11-08-2009, 09:37 AM
Wow! It's like someone puked wire.
11-08-2009, 09:56 AM
Motor Repair&Control Shop
When I look at that wiring all I see is $$$$$$$
When somethings broke, I wanna put a bit of fixin on it
11-08-2009, 10:01 AM
Unlimited Lic.Electrician
I agree with Dennis it all needs to be redone.
11-08-2009, 10:02 AM
Exactly, $$$$$$$$$$$
11-08-2009, 10:06 AM
The good thing about the hacks of teh world they make the pros losts of $$$4
11-08-2009, 12:41 PM
Proud member of IBEW LU 340
11-08-2009, 01:29 PM
Site Idiot Smacker
cha ching!
Don't make me bust out the apprentice stick!
11-08-2009, 01:43 PM
Not Peter D
Rip it apart start again with a plan and it will come together nicely.
It realy does not look like that many circuits, clean up the LV crap and get that out of the way then deal with the feeders.
You could make this look great ........ but I do agree with the others, there is no half way here, it's time to jump in and fix it right.
11-08-2009, 02:17 PM
We're dealing with the water situation first.
This is for the kind of stuff that can not be turned off so we're planning to re feed it all temporary first, disconnect all the crap and hopefully re use some of the underground conduit runs.
Alot of this stuff is no longer in use, just left there. This building was built in the 30's I think.
11-08-2009, 02:26 PM
B4T Scotchkote installer
Foam the inside of the pipes to stop the water and rip everything out when you get the job
314.27.. you must use "listed" connectors when bringing wires into a 6X6 PVC box. Use a water tight compression connector for the UF because a 1/2" hole in the bottom of the box will cause all kinds of problems if you post it on a Internet Forum
11-08-2009, 04:21 PM
Licensed Journeyman
Foam the other end so they don't fill up with water. Duct seal doesn't keep water out?
11-08-2009, 04:35 PM
Seen your member
I would start with a Cat D9.
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
11-08-2009, 09:43 PM
You can borrow my friends, Ill drive it down for you.
11-08-2009, 09:51 PM
Seen your member
No, thank you. I've already got one.
11-08-2009, 09:57 PM
#18
Damn, Im still living in the 1970's
11-08-2009, 09:58 PM
#19
Mamaluke
boy talk about a cluster. how does it even get that bad ?
Evil triumphs when good men do nothing.
Edmund Burke
11-08-2009, 10:00 PM
#20
You need to use that thing.  Do you even know how to operate it?
