Benfield miter box? - Electrician Talk - Professional Electrical Contractors Forum
Old 12-17-2011, 11:54 AM   #1
Rewards Points: 77
Default Benfield miter box?
I was reading the tool bag photo thread and there was mention of a Benfield hand held miter box. What is this used for? I searched the web and can't find anything on this tool.
astrodoggie3000 is offline   Reply With Quote
Old 12-17-2011, 11:59 AM   #2
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 458
http://www.benfielddirect.com/
scroll
Old 12-17-2011, 12:29 PM   #3
Rewards Points: 77
So i assume it just enables you to make a perfectly square cut on pipe and cable? Does unistrut fit in it as well? That would be the only thing i ever need to cut perfectly square.
Old 12-17-2011, 06:15 PM   #4
3rd Generation
MF Dagger's Avatar
Rewards Points: 1,010
It works best for flex conduit. It's one of my favorite tools
Beercan ceiling fan.
MF Dagger is offline   Reply With Quote
Old 12-17-2011, 06:26 PM   #5
Rewards Points: 1,062
I'm a little confused as to why it would be more important for you to cut strut straighter than EMT???
ElectricJoeNJ is offline   Reply With Quote
Old 12-17-2011, 06:49 PM   #6
Rewards Points: 250
Because you can see the ends of the unistrut. EMT ends are in a coupling or connector and aren't seen. Obviously you'd want them fairly straight too.
mnelectrician is offline   Reply With Quote
Old 12-17-2011, 06:55 PM   #7
BBQ
Salty Member
BBQ's Avatar
I am very confused why a guy that cuts tubing frequently would need this.
As far as flex I usually cut it at an angle just like a roto split would and untwist it.
With uni-strut I just mark it out with my combination square I keep in my bag.
Old 12-17-2011, 07:11 PM   #8
Rewards Points: 77
I guess it would also help you hold the pipe in your hand while your cutting. Is it sold anywhere in stores... i would like to take a good look at it?
Old 12-17-2011, 07:17 PM   #9
Hippie's Avatar
Rewards Points: 548
If you're cutting a bunch of flex just slide it thru a piece of pipe in a tristand the length of your whip cut with portaband push the next length thru and repeat, no miter box needed
Hippie is offline   Reply With Quote
Old 12-17-2011, 07:21 PM   #10
Use a chop saw. Definitely my tool of choice for any large commercial project. Cuts strut, EMT up to 4", rod, etc... Anything metal it makes quick work of. Get a good 1/4 or half round file and your good to go. If i spent time messing with that contraption and a hacksaw I'd fire myself!!!
Old 12-17-2011, 08:13 PM   #11
Rewards Points: 250
Yeah I've never used what the OP was talking about either to cut strut or pipe.
Old 12-17-2011, 08:45 PM   #12
cdnelectrician's Avatar
Rewards Points: 1,018
I always find that cutting strut from the front or the open end with a bandsaw gives me nice straight cuts every time, no marking needed. It pisses me off when I see a piece of strut cut at some obscene angle and even more when it gashes me open somewhere while I'm up in a ceiling.
Old 12-18-2011, 04:20 PM   #13
Now, one of the old guys!
Rewards Points: 107
I have had one of these for years, Best way to cut sealtite conduit I have ever used.
gesparky221 is offline   Reply With Quote
Old 12-18-2011, 04:25 PM   #14
BBQ
Salty Member
BBQ's Avatar
Chop saw? That is so 1990s.
I would go with a band saw or a metal cutting circular saw over a chop saw now.
Old 12-18-2011, 05:00 PM   #15
freeagnt54's Avatar
Rewards Points: 972
For strut your cut should be square enough to stand up on the end you just cut
freeagnt54 is offline   Reply With Quote
Old 12-18-2011, 05:24 PM   #16
Coffee drinking member
Wirenuting's Avatar
Rewards Points: 2,532
If you can see the horizontal end of my strut then I'll cut it on a slight angle and file the edge down.
I hate guys who leave sharp edges for people like me. I seem to enjoy leaving DNA dripping all over the place. :-(
Old 12-18-2011, 06:02 PM   #17
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 282
That miter-box looks like a solution searching for a problem.
You can't see the end of the pipe when it's in a connector, and the wire sure ain't gonna care if the cut is 82 instead of perfect 90°
Big John is online now   Reply With Quote
Old 12-19-2011, 12:05 AM   #18
Rewards Points: 250
Yeah that's not fun.
Old 12-19-2011, 12:27 AM   #19
Jlarson's Avatar
Rewards Points: 2,954
I freehand flex with an angle grinder lol.
This miter box is one of those tools I look at and ask myself; would i carry it and have it when I could use it, no. Do I really need it, no.
Jlarson is online now   Reply With Quote
Old 12-19-2011, 03:19 PM   #20
Hippie's Avatar
Rewards Points: 548
Absolutely. Ugh I hate a crookedly cut unfiled piece of strut
Wanted: Benfield Saw-box MF Dagger Electrician Swap 3 09-15-2009 10:44 PM
Compound Miter Saw Dude Man Tools, Equipment and New Products 34 08-11-2009 09:57 PM
Benfield Conduit Bending Manual - good? BP_redbear General Electrical Discussion 9 12-30-2008 09:57 AM
benfield paul d. Vintage Electrical 10 11-29-2008 07:12 PM
