Old 10-23-2009, 08:04 PM   #21
Always Learnin'
I haven't used a corded drill to rough-in since I got the Milwaukee Li 18V. I use a sharp 3/4" auger bit and have no trouble. Most studs around here the last few years are match-stick pine, just a little tougher than balsa wood. I usually go through 3-4 batteries a day. My corded drills only come out now when the hole saw size goes over 2-1/2".
amptech is offline   Reply With Quote
Old 10-23-2009, 09:23 PM   #22
I am a RAT.
william1978's Avatar
How long do your drills last?
Old 10-23-2009, 10:54 PM   #23
Always Learnin'
I'm still on my 1st Milwaukee 18V Li drill.
Old 10-23-2009, 10:55 PM   #24
Rat Extraordinaire
OK, so when did you buy it, and how many entire houses have you drilled out with it?
Old 10-23-2009, 10:56 PM   #25
Are you saying that you use this drill:
That drill is super light and a pleasure to work with, but I never thought it would hold up to drilling studs all day.
ArrrrrMatey is offline   Reply With Quote
Old 10-23-2009, 10:56 PM   #26
Hack and Rat all in one
Peter D's Avatar
OK, I'm going to take a stand here. Drilling out a new house with a cordless drill is girly.
Old 10-23-2009, 10:58 PM   #27
Rat Extraordinaire
And you would know because.........?
Old 10-23-2009, 10:58 PM   #28
I am a RAT.
Amen.
Old 10-23-2009, 10:59 PM   #29
Peter D's Avatar
I am The King!!
Old 10-23-2009, 11:00 PM   #30
I am a RAT.
I am The King!!
Old 10-23-2009, 11:01 PM   #31
Rat Extraordinaire
I am The King!!
Aw, man. You totally ignored my girl with the drill thingy. I'm gonna stop worshipping you now!
Old 10-23-2009, 11:04 PM   #32
The only ones I see going cordless are the AV crews, and all they drill are little 3/8'' holes. There ain't a cordless drill on the market that can outdo a corded drill on the yellow pine they use around here if you're drilling out a house for roping.
Old 10-23-2009, 11:05 PM   #33
Peter D's Avatar
That's what I'm sayin'.
Old 10-23-2009, 11:05 PM   #34
Peter D's Avatar
Most new homes here are built with furring strips so very little drilling is actually required.
Old 10-23-2009, 11:22 PM   #35
Always Learnin'
I bought the Milwaukee 18V Li drill, 1/4" impact and sawzall last November. Since then it has been used on the rough-in of 2 houses, 4 churches, a dental office, 3 house additions and an insurance office. Everything else has been metal studs and pipe. I haven't had a battery go bad yet either. Call it girly if you want, but it's just too easy to jump on a baker's scaffold and wheel around drilling ceiling joists without worrying with a cord. And like I said, the framing lumber around here is pretty soft and floor joists are TJI. Just don't force the drill and avoid lugging and stalling and you'll extend the life a bunch.
Old 10-23-2009, 11:25 PM   #36
Always Learnin'
That is not a Milwaukee drill.
Old 10-23-2009, 11:31 PM   #37
No one said I was smart.
Old 10-23-2009, 11:43 PM   #38
Wanna be Guru
mikeg_05's Avatar
Maybe a Pirate
Old 11-01-2009, 02:23 PM   #39
The Ridgids have enough torque to spare and they're pretty well priced.
g_core18 is offline   Reply With Quote
Old 11-03-2009, 03:50 PM   #40
We tested a bunch of the new lithium-ion powered cordless drills and the one that impressed us the most was the DeWalt DCD970 with its 3 speed range gearbox. It's 2 and 3 settings correspond to the 1 and 2 gearing of other drills. Having the extra low range makes a big difference in both torque and battery charge life.
The lithium-ion power ratings from the manufacturer are lab based and really don't provide an accurate picture of the power a drill will provide in the real world. The overload circuitry will cut power to the motor before the maximum torque can be applied. Hitachi is the worst in this regard.
Recharge times also vary a lot with it taking twice as long to recharge the Hitachi and Milwaukee battery packs as with the Makita and the DeWalt (both were under 15 minutes).
The cutting tool makes a big difference and the designs are mostly good for corded drills but not so good for cordless. Lots of auger designs on the market but none are designed to make the best use of the power provided by a cordless drill. There are short auger bits on the end of a thin shaft and these will require a lot less power than the continuous auger designs but all are designed for fast cutting and minimize damage from hitting a nail and not for minimizing the power needed from the drill.
People have not shifted their thinking from old designs for the most part - one exception being the new hole cutters like the Milwaukee Big Hawg and the Blue Boar Self-feed TCT hole cutters.
Michael Winters is offline   Reply With Quote
Blue handle and Red Handle Klein Diagonal cutter? Chevyman30571 Tools, Equipment and New Products 19 07-20-2009 10:05 PM
drill bits electric mike Tools, Equipment and New Products 18 07-08-2009 04:38 PM
"New" Klein bender w/ Orange Handle Ross Tools, Equipment and New Products 17 06-08-2009 07:36 PM
star drills electricalperson Tools, Equipment and New Products 21 06-02-2009 06:22 PM
Greenlee flex bits knothole Tools, Equipment and New Products 25 01-22-2008 08:34 AM
