02-06-2009, 08:55 PM
Compact drill/driver hex or 3/8 chuck?
So I have an old 9.6v Makita that works ok, but I have decided to upgrade to a compact drill/impact set. I was looking at the Makita set (10.8v drill and driver) but wanted to ask yout opinions on something. The set comes with a drill and impact that both only accept 1/4 hex shank bits. Now, makita just announced a new 10.8v drill that has a 3/8" chuck instead of the hex socket (DF330DW). Do you all think the 1/4 hex socket is a drawback and I should wait for Makita to release a combo set with the unit with a chuck or go with the current hex set?
FYI Home Depot has the Makita 10.8v Drill/Impact set on sale for $129.
This is the new Makita 10.8v drill with the 3/8" chuck that is not in stores yet: http://makita.com/en-us/Modules/Tool...x?Name=DF330DW
I know the bottom line is that it is my decision. I just dont want to regret picking up the hex socket sets and not be able to use any bits I might have that are not hex quick change ones.
02-06-2009, 10:31 PM
As you can see, Bosch already has one.
They're probably pretty comparable, though I'm not sure the quality of Makita.
If you're a Makita loyalist, I would say just wait until you can order it on-line or buy it in stores. The 1/4 speed chuck sucks in comparison because the 3/8'' is more versatile and will use anything the 1/4'' will hold. It's virtually obsolete.
02-06-2009, 11:29 PM
I've got a Milwaukee 12 vt drill/driver. I love it. Its a great tool. Same size as the Bosch.
02-07-2009, 12:07 AM
Are those little units with the keyless chuck actual impact/drivers or just standard drill/drivers?
If no impact function, I probably wouldn't even bother with them myself.
02-07-2009, 10:58 AM
They have impact drivers at 10.8 v, I just don't need anything like that so I don't bother.
02-08-2009, 10:56 AM
Wait for the combo. We have three sets of them, and had to buy makita keyless chuck to 1/4 hex adapters for them. 90% of drill bits don't come with quick adapter ends on them, so the drill driver of the set is useless to me. (I didn't buy the adapter for keyless chuck, not spending $40) Use the impact every day though, keep it right in my bag.
Chuck adapter: http://www.makita.com/en-us/Modules/....aspx?ID=34188
Reason: link
02-08-2009, 12:08 PM
I have the Bosch 10.8V Impactor with the hex head. Also bought the CC2130 Clic-Change 27-Piece Drilling and Driving Set. The only downside that I have found is when the Lithium battery gets cold they do not want to work.
02-08-2009, 12:29 PM
Personally, with the Makita set, I've never had the cold effect them. I keep a battery in the drill and an extra in the bag, and only need to charge them when they're fully drained. Once every couple days per battery usually. (Really long, I thought they wouldn't last at all)
But my Hatachi 18volts need charging every time I want to use them because of the cold. And both set's are kept in the same van every night.
02-14-2009, 08:10 AM
i'll give the makita impacts a try. some black male from a concrete crew stole my hilti impact driver today..looks like i'll try makita.
02-14-2009, 09:55 AM
I just got this:
 ..and this:  ....for $149.
Both drivers, two batteries, charger and case.
Last set they had.
I really like 'em so far.
02-14-2009, 03:36 PM
Pete, do you see the hex as a disadvantage? Would you think one with a 3/8" chuck like the one listed above would be more convienent?
02-14-2009, 03:45 PM
Not at all. I have two Makita 14V impact drivers that I use the hell out of. This was just an impulse buy on sale.
I actually like the hex better for the quick release and ease of bit change. I have a ton of bits as we all must have. So changing from #2sq drive to phillips to 5/16" tek driver is simple.
These little ones are nicer for devicing out and driving small screws like for box mounting. Much easier to carry aorund too.
I wouldn't run 3" deck screws or 2" #10sms with them, that's what the bigger impact driver does really well.
02-14-2009, 08:57 PM
Do you mind if I ask where you picked them up for $150 on sale?
02-14-2009, 09:11 PM
"A" inside wireman
I use them in much the same way but, I do drive some larger screws/teks with the impact as well.
"One Nation Under God"
02-14-2009, 09:57 PM
Lowes
02-14-2009, 11:05 PM
i'll have to check lowes out and see what's on sale.
02-14-2009, 11:19 PM
thought of an impact driver? you can get some little ones that have more torque than a main stream 18V cordless drill.
02-14-2009, 11:25 PM
#18
okay so I have a question... impact drivers.. which model... 10? 12? 14? 18? sucks.. i had both my hilti impact drivers taken from my cart by <guys> on the concrete crew when I went to lunch... that teaches me never forget to lock tools inside my knaack whenever there is young to middle age <guys> working a jobsite.
Reason: remove racial terms
02-14-2009, 11:33 PM
#19
I've found that anything past 14V is too much for general screwdriving, too much torque and you lose the feel of what your doing. I use a 12V metabo impact and nearly never use a screwdriver. Its hanging on a hook on my belt at all times. impacts really excel with tek screws in a commercial environment. You can go all day on a charge and they drive them in so fast, and without stripping them out. Most guys around I see use 18V drills for driving the screws and nearly every one is stripped out and won't really be holding much unless the sheetrock comes quick and locks the screws in place with a panel of rock...
They wonder why all their boxes end up crooked and MC straps swinging around loose.
02-14-2009, 11:45 PM
#20
I'll go checkout a 12 or 14. I had Hilitis, might go get two more Hilitis but trying to find something just as good with reliablity. So far Makita or milwaukee are the ones I'll play with..buy one of each from hole depot/lowes
