EZ Box - Electrician Talk - Professional Electrical Contractors Forum
Like Tree66Likes
Old 03-19-2017, 10:09 PM   #1
halfamp's Avatar
Rewards Points: 452
Default EZ Box
Looks like a local up and coming product line for the residential market. I'm not into residential but this looks pretty slick for new stick construction MDUs etc. Plus the local midwest element is a plus. Any residential guys see any pros / cons to this stuff?
http://www.ezboxess.com/
halfamp is offline   Reply With Quote
The Following User Says Thank You to halfamp For This Useful Post:
splatz (03-20-2017)
Old 03-19-2017, 10:14 PM   #2
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,240
Are they trying to advertise that you can pull into it from the same piece that mounts in the hole? How would you clamp it?
Old 03-19-2017, 10:16 PM   #3
halfamp's Avatar
Rewards Points: 452
I'd really like to see a better application video to address your questions, I just came across this and it looks pretty slick for a market I am not in.
Soilentblue9 (03-20-2017)
Old 03-19-2017, 10:18 PM   #4
Majewski's Avatar
Lol I like how you say "I am not in" in that sense anything can look great right?
It seems slick though.
Old 03-19-2017, 10:25 PM   #5
Rewards Points: 1,684
It look pretty slick but I do not know what those thing will run on pricewise.
It kinda hard to say if that justify the cost for that purpose .,,,,
Majewski likes this.
Old 03-19-2017, 10:56 PM   #6
still in business
sbrn33's Avatar
Rewards Points: 3,490
I would not invest in this company if that is what you are asking....
but this is the economically depressed South and we're just a bunch of barefooted cousin humpers.
Old 03-19-2017, 11:23 PM   #7
mdnitedrftr's Avatar
Rewards Points: 915
I don't get it.
They want me to install those guard things in every stud? What happens when there are multiple studs? What happens when I want to run multiple wires through the same holes without ending up at the same box?
- Rich
mdnitedrftr is offline   Reply With Quote
The Following User Says Thank You to mdnitedrftr For This Useful Post:
Majewski (03-19-2017)
Old 03-19-2017, 11:33 PM   #8
Safety Pin Member
PlugsAndLights's Avatar
Rewards Points: 2,876
Don't buy the idea that box mounts etc are a significant source of arc faults.
Drilling the hole through the stud in exactly the right place, at a 90deg angle,
would be a pain.
P&L
Old 03-19-2017, 11:59 PM   #9
Rewards Points: 5,216
IDK.. Quit coming out with stupid products attempting to make up for crappy workmanship and proper testing procedures.
Train people to install stuff correctly... 90% of the issues are gone.
Train people how to use testing equipment, Megger the wires at rough and before trim, and the other 9.99% is gone.
The last %... Well... Materials fail! lol...
I don't see the value in it, nice novelty though.
LuckyLuke, Majewski and NDC like this.
The Following User Says Thank You to Switched For This Useful Post:
Majewski (03-20-2017)
Old 03-20-2017, 12:11 AM   #10
Rewards Points: 15,776
would be a pain.
P&L
A companion jig would be required, no doubt.
It does solve a non-problem, though.
It is no solution for off-angle studs.
The mounting holes, themselves, will be expensive to install.
The multi-gang box makes absolutely no sense to me.
active1 and Switched like this.
Old 03-20-2017, 12:17 AM   #11
Exactly... I don't see how this will save me time or money. How often does a drill bit wander a little...? Now every box in that room is at slightly different heights!
99cents, telsa and Majewski like this.
Old 03-20-2017, 12:18 AM   #12
Rewards Points: 9,930
You're just trying to figure out how to pound spikes through it .
Switched and Majewski like this.
Old 03-20-2017, 01:56 AM   #13
Rewards Points: 306
I drill holes in studs willy-nilly. You guys would laugh if you saw my roller coater wire from stud to stud. This would take me forever to get boxes the right height.
Hammer vertical from the floor, box on stud to top of hammer, hold in place, pull hammer, bang on box. Drill all the holes around it close enough the same height.
I do like the nail guard sleeves though.
Switched likes this.
matt1124 is online now   Reply With Quote
Old 03-20-2017, 01:59 AM   #14
I was taught boxes at hammer height (yeah, everyone was provided a company hammer) and drill at your hips/waist, which is typically above a receptacle and below a switch.... Unless your freakishly tall or short.... Not that there is anything wrong with that, you just do it at your knees or head...
Old 03-20-2017, 03:28 AM   #15
Deplorable-Electrician
Rewards Points: 2,108
With the way the boxes slide into each other with no chase between boxes seems like one feed coming in and having to feed separate switch legs going out of a 2 or 3 gang box would be close to impossible.
The new boxes are let's say $3 each, the special clamp on the stud drill press for mounting holes is $400, j/s!
Old 03-20-2017, 03:43 AM   #16
You noticed that.
active1 likes this.
Old 03-20-2017, 03:47 AM   #17
You noticed that.
Sure did, it's pretty rare to have separate feeds for each individual device mounted in multigang boxes.
telsa likes this.
Old 03-20-2017, 07:10 AM   #18
RePhase277's Avatar
Rewards Points: 4,570
It's cute, but it solves a problem I don't think exists. I think the gangability is cool.
telsa likes this.
Old 03-20-2017, 07:12 AM   #19
RePhase277's Avatar
There is a 1/2" KO between each box.
Old 03-20-2017, 07:19 AM   #20
Rewards Points: 3,010
I want to buy one of the sleeves and make a youtube video of driving a screw through it. I have told my story of the homeowner that drilled a deck screw right through 1" EMT where it went through a stud. That wouldn't have happened with a nail plate.
The Customer is Always Right! - @Hackwork
