Old 06-30-2009, 12:21 PM   #1
Default FYI For SeeSnake Micro Owners
I just received a reply from Ridgid tech support this morning regarding the new smaller 9.5mm imager head for the SeeSnake Micro.
They said that the new 9.5mm imager head assembly uses the same connector and is interchangeable with the older 17mm head assembly, so that means if you already own the original model SeeSnake Micro with the 17mm head, you can upgrade it to the new smaller 9.5mm head and can also continue to use any additional 3-foot extensions that you may already have. The smaller replacement head is around $95.00, but that's still less than half as much as it would cost for a complete new SeeSnake unit with the 9.5mm head.
This is good news since the new imager head is only about half of the diameter of the older head. It's also rare that a company considers their base of existing owners when they make improvements to a product line.
Old 06-30-2009, 04:32 PM   #2
Tabihu Juhar
76nemo's Avatar
Question
They said that the new 9.5mm imager head assembly uses the same connector and is interchangeable with the older 17mm head assembly, so that means if you already own the original model SeeSnake Micro with the 17mm head, you can upgrade it to the new smaller 9.5mm head and can also continue to use any additional 3-foot extensions that you may already have. The smaller replacement head is around $115.00, but that's still only about half as much as it would cost for a complete new SeeSnake unit with the 9.5mm head.
The head is smaller and the shafts are the same????????
Old 06-30-2009, 04:44 PM   #3
Chief Electron Relocator
If I'm going to do anything, I think I'll upgrade to either the Rigid or Milwaukee that can record images and video.
Old 06-30-2009, 07:08 PM   #4
If I'm going to do anything, I think I'll go out and buy a SeeSnake.
Old 06-30-2009, 07:10 PM   #5
Hacks don't use SeeSnake's they use hammers.
Old 06-30-2009, 07:12 PM   #6
This sentence is incorrect. It should be: "Hacks don't use SeeSnake's. They use hammers."
Old 06-30-2009, 07:12 PM   #7
If you want to wait, I'll sell you mine when I upgrade.
Old 06-30-2009, 07:13 PM   #8
No thanks. I don't buy tools from tools.
Old 06-30-2009, 07:16 PM   #9
You're not buying tools. You're buying a tool. Slight technical difference there.
Old 06-30-2009, 07:17 PM   #10
Sorry.
I don't plan on buying a tool from a Tool.
Is that better now?
Old 06-30-2009, 07:18 PM   #11
Sorry.
Is that better now?
Besides, it would be A tool that was once owned by THE tool.
And that would be cool!
Old 06-30-2009, 07:18 PM   #12
Actually a comma between SeeSnake's and they would have worked fine, Hackman.
Old 06-30-2009, 07:20 PM   #13
Either way it was wrong. Too bad Steelersman didn't catch it first.
Old 06-30-2009, 07:23 PM   #14
Oh, you mean my buddy Barth.
Old 06-30-2009, 07:30 PM   #15
Also, no apostrophe in SeeSnake's. It should be SeeSnakes. With the apostrophe, it's possessive. Without it, it's plural.
Old 06-30-2009, 09:18 PM   #16
Next week you guys are going to start diagramming sentences.
Old 06-30-2009, 09:19 PM   #17
Yeah, so what's it to you?
Old 06-30-2009, 09:20 PM   #18
Keep me in mind. I'll take you up on it.
Old 06-30-2009, 09:21 PM   #19
Milwaukee has theirs on promotional with the little 12V lithium-ion driver free in the kit. Uses the same battery as the Milwaukee see snake thingamajig. I got one a couple weeks ago for $248. Probably cheaper online if you look. I think it was the same part number as the camera alone, but with a "-P" on the end of the part number for "promotional".
Old 06-30-2009, 09:30 PM   #20
Where?
Business Owners' Cost Calculator Speedy Petey Business, Marketing, and Sales 23 04-13-2013 06:03 AM
Micro & Island outlet BIGRED General Electrical Discussion 62 03-12-2010 10:13 AM
Owners meter/ panel Magnettica NEC Code Forum 10 05-31-2009 08:51 PM
Owners panel preacher NEC Code Forum 22 03-09-2009 09:13 PM
owners salary capt1012 Business, Marketing, and Sales 5 10-08-2007 12:07 AM
