Old 01-13-2008, 07:54 PM   #1
Licensed Electrician
knothole's Avatar
Default Greenlee flex bits
Does anyone use the Greenlee flex bit for getting romex around and in and out of, and drill behind, finished walls? What are your thoughts? Thanks in advance.
Danny
Danny
knothole is offline   Reply With Quote
Old 01-13-2008, 08:06 PM   #2
They work great! No problems!
sundogusa is offline   Reply With Quote
Old 01-13-2008, 08:24 PM   #3
Not Banned Yet
BryanMD's Avatar
When I know you all better I tell you what a problem with them can be.
March 2010: On the road with my RV. California is first primary destination then it is off to Eastern OR, Northern ID and Western MT for drycamping and fly fishing until Labor Day.
Old 01-13-2008, 08:40 PM   #4
Seen your member
Definately worth the money to invest in a couple.
Be sure to get the placement tool as well.
Old 01-13-2008, 09:45 PM   #5
480 beat me to it. The placement tool is a MUST!
The guy in the pic is using it all wrong though.
Bryan, it's all good. Do tell.........
Old 01-13-2008, 10:05 PM   #6
nap
a real PITA
hopefully the pic is simply to show the intent. If they were using it correctly, obviously most of the tool would not be seen.
I don't have one of those tools but I have used a piece of conduit with a proper bend in it to guide the bit. Probably doesn;t work as good as the tool does but it did do what I needed when I needed it.
Old 01-13-2008, 10:15 PM   #7
Not Banned Yet
BryanMD's Avatar
I was an apprentice and new to working with this JM doing a heavy up and panel change IIRC. He left me alone to go fetch some tool or material with an instruction to bore a pilot hole near the sill plate...
Long story short, the end of the flex bit ended up through the (hardwood) dining room floor and in the leg of an allegedly antique chair. There may have been a Persian rug too.
To his credit he never really blamed me for it but I still shudder whenever I so much as see a flex bit.
Old 01-13-2008, 11:00 PM   #8
gilbequick's Avatar
They're a handy thing to have around.
Be careful about running them too fast while you're bending it a good bit. It'll heat up and snap at the bend point if you're not careful. I've snapped 2 of them like that so far.
Because of heat I'd think, I also had one where the drill/auger part of the drill bit separated from the shaft.
I've never liked that placement tool, for myself I can do a better job placing and controlling the bit by hand.
Old 01-13-2008, 11:38 PM   #9
Mad Skills
Celtic's Avatar
A piece of EMT with a nice bend on it works well ... ...save your paw for playing cards.
Old 01-14-2008, 07:11 AM   #10
How 'bout this.
Get you a piece of 1/2 Pex tubing just shorter than the shaft length of your flex-bit.
Slide your bit in and leave it. You can hold it tight and drill and the bit will never burn through the Pex, and your hands stay unhurt.
You can also slide it on the bit after placing it in the wall. The wall does not get all chewed up if the bit bounces around a little.
Old 01-14-2008, 08:40 AM   #11
A real loose neutral!
DPDT's Avatar
That one goes in my book speedy. Nice one.
DPDT is offline   Reply With Quote
Old 01-14-2008, 09:06 AM   #12
Seen your member
The placement tool image is from Greenlee's web site.
So it shows the tool, not how to use it. When used correctly, most of the tool is in the wall.
I also use this same tool for getting my green fish sticks to go where I want them to.
Old 01-14-2008, 02:35 PM   #13
Bkessler's Avatar
I keep two with me at all times But, they can get away from you if your not careful. You never know whats on the other side of that first floor ceiling joist. I try and use it as little as possible. I do like using the irvin long 16" paddle bits.
When ls lunch
Old 01-14-2008, 05:53 PM   #14
"A" inside wireman
randomkiller's Avatar
How 'bout this.
I like that one, thanks.
"One Nation Under God"
Old 01-14-2008, 05:54 PM   #15
"A" inside wireman
Conduit doesn't cause as much drag on the bit as their placement tool either. I used to spray the bit with WD 40, but now I think I'm gonna try the Pex jacket.
Old 01-14-2008, 05:55 PM   #16
"A" inside wireman
Has anyone used the masonary bit and liked it?
Old 01-14-2008, 06:22 PM   #17
DJFVT
John's Avatar
I use them all the time, just don't do this.
Attachment 341
Old 01-14-2008, 08:05 PM   #18
PEX, huh? I'll give it a try. I do have hte placement tool...forgot about that!
Best use I ever had was installing can lights in 1st floor ceiling with bedroom above. Cut the 8 6" holes, then used loooong flex bit to go between openings. Owner thought I was the greatest. Didn't booger-up the ceiling.
"FREE ADVICE" That 90 degree angle in Greenlee's picture is a good way to make a mess. Try to limit the angle as much as possible. Try to drill straight down. You'll have better control of the bit.
Old 01-14-2008, 08:07 PM   #19
Attachment 341
OOPS!
(Blame the plumber!)
Old 01-20-2008, 06:52 PM   #20
Post
[quote=knothole;15860]Does anyone use the Greenlee flex bit for getting romex around and in and out of, and drill behind, finished walls? What are your thoughts? Thanks in advance.
The Diversibits do come in longer lengths for drilling up through the bottom and out the top of stud bays if that’s what you mean.
I don’t recommend getting them in lengths longer than the 54-inch though, because the extensions and 72-inch bits just have too much whip and the shafts are easily twisted or snapped.
I have used them to go from basement to attic before, but it's hard to control that long thin unwieldy shaft. Always felt like it was going to snap and take my eye out.
The type B and C tip 54-inch and shorter lengths on the other hand are very useful for drilling down into a basement or crawl or up into an attic space from a switch location. I use the wire basket grips through the hole in the tip to pull wires back through. The positioning tool is the easiest way to get the bit started close against the interior wall when working from a one-gang box cutout. If your working in an insulated exterior wall, they make a flexible nylon sleeve that slides over the shaft before you chuck it in the drill. It keeps the insulation from wrapping around the shaft and protects your fingers from friction burns. The placement tool fits over this nylon sleeve, so you can still use it for positioning.
Greenlee bought out Diversabit years ago, but Milwaukee also markets this same style of bit as their “Cable Bit”. I’ve never tried the type M masonry bit to drill through fire stops before.
greenlee paul d. Vintage Electrical 0 10-04-2008 06:58 PM
1/2" flex support K.B.Q.C. General Electrical Discussion 1 07-22-2008 09:16 PM
flex cord works for everything, right??? BP_redbear Code Violation Discussion 2 07-11-2008 10:08 PM
Power Flex VFD jhanth General Electrical Discussion 3 04-12-2008 03:34 PM
Greenlee 1940 flex conduit cutter splitter twintask Tools, Equipment and New Products 12 09-01-2007 11:01 AM
