Old 09-15-2007, 08:45 PM   #1
Default Ground Fault Location Equipment for Ungrounded AC
480v three phase system, Have seen equipment that is two parts. One hooks to ground, and three phases, has battery or 120v plug in, it has normally three lights that are on when no faults are present, and they are off when there is a fault. The other part is a clamp wond that picks up the pulse noise through a head set...
I always knew it as a ground thumper, but not a "burn type"
Anyone know what I am decribing and where to find one.
Thanks
Larry is offline   Reply With Quote
Old 09-15-2007, 09:54 PM   #2
Sounds like the old Metro-Tech fault finder. Does that ring a bell? That's the only one I know about that uses a headset.
Old 09-15-2007, 09:55 PM   #3
Bit confused at first (I WAS) you are looking for fault locating equipment for buried conductors.
I have used numerous systems over the years at present we are using the 3m (MODEL?) I get on Monday when I get int he office
Addressing Ground Fault Issues brian john General Electrical Discussion 53 03-02-2010 08:11 AM
Equipment Ground Absolutetruthz General Electrical Discussion 6 06-06-2008 06:23 AM
Location, location, location brian john Introductions 3 11-25-2007 09:13 PM
Ground Fault Installation brian john Code Violation Discussion 4 05-29-2007 11:57 PM
Ungrounded Romex, thermoplastic. MDShunk General Electrical Discussion 20 04-09-2007 11:43 PM
