Headlamp - Electrician Talk - Professional Electrical Contractors Forum
Old 04-17-2012, 01:56 PM   #1
Rewards Points: 194
Default Headlamp
What kind of headlamp do you guys recommend for darks spaces/attic? I'm looking for a led/rechargable headlamp if possible. Thx
In Denver, Co doing Service work and Remodel all day... Love it.
Smileyboy is offline   Reply With Quote
Old 04-17-2012, 02:39 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Petzl. If you want rechargeable, use AA's or AAA's. If you get one with a proprietary battery & charger, you'll be working in the dark if the battery is dead. Using rechargeable AA or AAAs, you can at least buy batteries just about any where if you need light.
Elec-Tech (04-18-2012)
Old 04-17-2012, 03:13 PM   #3
Amish Electrician's Avatar
Right now, I'm in a 1000-man steel mill with loads of maintenance folks doing just fine with the ordinary, buy-at-Lowes Eveready headlamps that have LED's and use AAA's.
Amish Electrician is offline   Reply With Quote
The Following User Says Thank You to Amish Electrician For This Useful Post:
Frasbee (04-19-2012)
Old 04-17-2012, 03:50 PM   #4
Rewards Points: 150
http://www.fenixtactical.com/fenix-hp11.html
that thing is awsome!
i use it in the 55 lumen setting the most but 277 is very nice when you want really bright.
Features of Fenix HP11 Headlamp:
  • • Cree XP-G LED (R5) with lifespan of 50,000 hours
    • Uses four 1.5V AA (Alkaline, Ni-MH) batteries (not included)
    • Separated type structure to balance the weight for comfortable wearing
    • Output mode / Runtime:
    • Turbo 277 lumens 3h 51min
      High 133 lumens 9h 31min
      Mid 55 lumens 25h
      Low 4 lumens 206h
      Strobe 277 lumens
      Flash 55 lumens
      SOS 55 lumens
    • Dual switch system for easy operation - one for turning on and off, second for output adjustment
    • Digitally regulated output - maintains constant brightness
    • Light head made of aircraft-grade aluminum, the rest made of high quality plastic
    • Premium Type III hard-anodized anti-abrasive finish
    • Waterproof to IPX-6 Standard
    • Toughened ultra-clear glass lens with anti-reflective coating
East Coast Paul is offline   Reply With Quote
Old 04-17-2012, 04:25 PM   #5
animal lover /rat bastard
wildleg's Avatar
Rewards Points: 384
The Following 10 Users Say Thank You to wildleg For This Useful Post:
Awg-Dawg (04-17-2012), B4T (04-18-2012), CanadianBrad (04-17-2012), ce2two (04-21-2012), chicken steve (04-19-2012), Chris1971 (04-18-2012), french connection!! (04-17-2012), HARRY304E (04-17-2012), mcclary's electrical (04-17-2012), oldschool (04-17-2012)
Old 04-17-2012, 04:56 PM   #6
Donuts > Fried Eggs
Big John's Avatar
Rewards Points: 262
The H7 from LED Lenser. Adjustable focus, adjustable light angle, and adjustable intensity from 2 up to 155 lumens.
It won't last but a couple hours at 155 lumens, but that's brighter than any other headlamp I've ever seen.
-John
The Following 3 Users Say Thank You to Big John For This Useful Post:
76nemo (04-24-2012), Frank Mc (05-13-2012), kecci (09-03-2012)
Old 04-17-2012, 05:03 PM   #7
Originally Posted by wildleg View Post
LOVE IT!!! ahaha
chicagoremodeling is offline   Reply With Quote
The Following User Says Thank You to chicagoremodeling For This Useful Post:
Chris1971 (05-15-2012)
Old 04-17-2012, 08:57 PM   #8
ilikepez's Avatar
http://www.amazon.com/Petzl-E78CHB-P.../dp/B004M3GDI4
this is what I use
ilikepez is offline   Reply With Quote
The Following User Says Thank You to ilikepez For This Useful Post:
Smileyboy (04-18-2012)
Old 04-17-2012, 09:50 PM   #9
Rewards Points: 2,000
Princeton EOS is pretty decent and cheap on amazon.
Old 04-18-2012, 10:20 AM   #10
Rewards Points: 194
Originally Posted by ilikepez
That looks like what I want. Thanks all
Old 04-18-2012, 06:03 PM   #11
Rewards Points: 250
Any suggestions on which one to grab? My 3 AAA minimag died today when I was using it as a lantern in a drop ceiling and accidentally knocked it out with some Cat-5 somebody lazily hung.
A bunch of the ones they have seem to be Lithium packs only, but I'm looking for something that will let me use the rechargeable Energizers I have.
bubb_tubbs is offline   Reply With Quote
Old 04-18-2012, 06:52 PM   #12
Elec-Tech's Avatar
Rewards Points: 77
Petzl has some good stuff.
Elec-Tech is offline   Reply With Quote
Old 04-18-2012, 09:21 PM   #13
Rewards Points: 25
Default Head Lamps
Petzl if you want really good quality. The cheap ones may be just as bright, but they don't hold up as well against bumps and scrapes.
12-Gauge is offline   Reply With Quote
Old 04-18-2012, 09:26 PM   #14
Rewards Points: 83
Try 3m light vision glasses. They an led on each side that swivels. Pretty easy if you wear safety glasses when working.
Knauer is offline   Reply With Quote
Old 04-18-2012, 10:22 PM   #15
beartp515's Avatar
Rewards Points: 87
Just got those, great for service upgrades in dark basements.
beartp515 is offline   Reply With Quote
Old 04-18-2012, 11:38 PM   #16
wendon's Avatar
Rewards Points: 50
I would recommend an LED head lamp that will only fit the head of your helper so he gets to do all the attic/crawl space work!
wendon is online now   Reply With Quote
The Following User Says Thank You to wendon For This Useful Post:
Old 04-21-2012, 11:18 PM   #17
Rewards Points: 150
Since this thread is here, and still kinda fresh, I'm going to throw in an add-on question. Does anyone know of a good-quality clip-on headlamp I can stick on my hard hat(like a miner's light)? My nice Fenix angle light walked off(turns out someone else liked it too), and I find myself increasingly in the dark and needing both hands, usually in tight spots. However, because I do quite a bit of work in a smelly, nasty cattle slaughterhouse, I don't really want to have a strap, since it'll just grab hold of the smell.
I'd definitely rock that headlight bra, but it doesn't look like it's fire-******ant...
CanadianBrad is offline   Reply With Quote
Old 04-21-2012, 11:43 PM   #18
ce2two's Avatar
Rewards Points: 690
How about when she says go down dare...make sure it's cleared by the std. examiner ..........he he he ..snapper inspection
ce2two is offline   Reply With Quote
Old 04-21-2012, 11:49 PM   #19
Rewards Points: 250
The trick is to get fat enough that you can't fit through the hatch.
The Following User Says Thank You to bubb_tubbs For This Useful Post:
hdgeno777 (05-24-2014)
Old 04-22-2012, 01:18 AM   #20
Rewards Points: 150
I think that might be a pretty standard practice for a few Alberta journeymen...
