Hole saw size - Electrician Talk - Professional Electrical Contractors Forum
Old 08-23-2011, 09:25 PM   #1
Default Hole saw size
After 3 months of heavy use and abuse my harbor freight uni-bit/ step drill is getting dull. Was thinking about switching to hole saws but was wondering what sizes you all use the most? Was thinking about just getting a kit but, only really used my step drill for 1/2 inch ko's mc connectors.
sp009 is offline   Reply With Quote
Old 08-23-2011, 09:33 PM   #2
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
Just buy another unibit and use some cutting oil when drilling it will last much longer...
Old 08-23-2011, 09:44 PM   #3
Rewards Points: 1,364
I use 7/8 for 1/2 inch, 1 1/8 for 3/4 and 1 3/8 for 1" I use the Lennox carbide tipped hole saws. They seem to do a good job in carbon steel.
I will borrow the Ideal saws from work if I am working with stainless. I was told that the Ideals will cut 600 holes in stainless with out coolant. Don't know if that is true but they do a good job on stainless.
LC
Old 08-23-2011, 09:47 PM   #4
Rewards Points: 356
Rule of thumb is add 3/8" to the pipe size you want. Thus a 1" emt needs a 1 3/8" hole, etc
BuzzKill (08-24-2011)
Old 08-23-2011, 09:48 PM   #5
Rewards Points: 5,198
LC
For what it's worth when I am cutting stainless I stuff the hole saw with a rag and soak it with cutting oil. As it spins it applies the oil to the teeth.
The Following User Says Thank You to RIVETER For This Useful Post:
kawimudslinger (08-25-2011)
Old 08-23-2011, 11:25 PM   #6
A Little Short's Avatar
Rewards Points: 118
Irwin makes a unibit for knockouts. They are marked for the size knockout needed. For a 1/2" you use a 7/8" and for a 3/4" you use a 1-1/8".
Old 08-23-2011, 11:27 PM   #7
Fried Bologna um um good!
jwjrw's Avatar
The greenlee 7/8" and 1 3/8" are freaking awesome.
Old 08-24-2011, 01:16 AM   #8
Rewards Points: 3,855
I got a set of the Lennox carbide hole saws for knockouts. They are freaking awesome! They are very shallow hole saws, with a spring that ejects the slug. I got them specially for a buttload of stainless work, and they're still going strong. I highly recommend them. I have a whole kit of stainless knockout punches, but I've been using the Lennox carbide knockout holesaws for knockouts up to 1-1/4", and only punching stuff that is bigger.
If I was to only buy one holesaw, it would be a 7/8", because that's the size you need to get the drawstud in for the bigger knockout punches.
Old 08-24-2011, 05:15 AM   #9
jwjrw's Avatar
Ideal has the same thing
Old 08-24-2011, 07:26 AM   #10
Rewards Points: 160
Ideal and Klein have the same thing. I'm pretty sure they are exactly the same though, awesome. I have Ideal. Gotta be willing to fork over some extra $ though, but you get more holes IMO
oww-is-that-hot? is offline   Reply With Quote
Old 08-24-2011, 10:41 AM   #11
Deplorable-Electrician
Rewards Points: 18,746
I would get the unibit for 1/2" & 3/4" ko's and a hone to keep it going.
Old 08-24-2011, 11:13 AM   #12
Rewards Points: 1,212
I use the Blair holecutters for 1/2 through 1" conduit. I have not tried their carbide tip version, but am very pleased with how the standard ones cut and last. The key is high drilling pressure and low RPMs. We would normally use Extra Thick Tap Magic as the cutting fluid, especially if drilling stainless boxes.
Old 08-24-2011, 02:44 PM   #13
MarkyMark's Avatar
The carbide hole saws are the shiznit for 1" + holes. For 1/2" and 3/4 holes, I think a sharp uni-bit is just as quick if not quicker than a hole saw, and to me makes a cleaner hole. Around here, Harbor Freight step bits cost somewhere in the 3 for $14 range. When they get dull, I throw them out and buy new ones.
MarkyMark is offline   Reply With Quote
Old 08-24-2011, 07:47 PM   #14
Rewards Points: 160
oh, that's what I forgot to say about the carbide hole saws, their holes are C-L-E-A-N
It's seriously like using a punch, and It's at least twice as fast as a unibit. That goes for 1/2", 3/4", and 1".
They're totally different than regular hole saws and don't require oil in the slightest.
At least not that I can tell.
Is there a minimum size Wire size for commercial? bushwickbill NEC Code Forum 28 02-24-2015 11:44 AM
wire size and breaker size D neitzke General Electrical Discussion 3 07-14-2011 03:00 PM
Hole Pro XL-Arbor Hole Saw Adapter KayJay Tools, Equipment and New Products 11 12-01-2010 02:08 PM
Ground size vs. Ungrounded Size Conduit Phil General Electrical Discussion 5 04-27-2010 08:26 PM
What size hole saw for 4" Square Box Fixture Cover kornbln General Electrical Discussion 20 10-04-2009 07:56 PM
