04-16-2011, 03:10 PM
hole saws
im looking to buy a new hole saw set. Im leaning towards buying the lenox 10 pc electricians set. Any suggestions?
04-16-2011, 03:13 PM
Coaster Sparky
Milwaukee, Greenlee, Lenox, Klein. I have a Milwaukee setup for personal use, my old company supplied Lenox.
I saw a girl texting & driving the other day & it really made me mad, so I rolled down my window & threw my beer at her.
If you're talking about the regular, plain ole hole saws, they are all about the same. Stick with a name brand like Lenox and you'll do just fine.
However, if you are cutting into anything other than wood, metal, or even modern drywall, you must use a "grit edge" hole saw or your holesaw will be destroyed before you even finish the hole.
04-16-2011, 03:16 PM
Heavily Armed Member
Those work well and last a good long time.
04-16-2011, 03:17 PM
Especially if you have to cut into a "Structolite" ceiling from the 1950's. (metal lath, cement board, layer of plaster)
04-16-2011, 03:19 PM
Do you have the starrett and Bosch over here?
04-16-2011, 03:20 PM
We have a lot of that around here ..
Big PITA..
Yes, though haven't seen either brand lately. Not at any of the big box stores or supply houses, at least.
04-16-2011, 03:21 PM
Same here, it's in pretty much every house of that time period. Though at least in the 1960's they stopped using the metal lath.
04-16-2011, 03:26 PM
Coaster Sparky
I have one of those for recessed lights, makes very quick work of whatever's in its way. I think they're a must have along with Carbide, but I find myself dealing with plaster and lathe/wire a lot.
04-16-2011, 03:36 PM
Yes thankfully..
Now they are just going right over it with sheet rock,, makes it even more fun,,,
It would be nice to know that before i give them a price.
04-16-2011, 04:22 PM
Those ideal carbide tip hole saws are pretty sweet.
The Following User Says Thank You to sparkymcwiresalot For This Useful Post:
04-16-2011, 07:18 PM
carbide grit lenox eats through almost anything and a little less clean up and plaster is the reason i gave up carrying a keyhole saw and switched to the lenox folding one with a fire rescue blade
04-16-2011, 07:44 PM
Whatever you buy use cutting oil, they will last a long, long time.
04-16-2011, 07:59 PM
Lenox big daddy
04-16-2011, 09:14 PM
Not if you use carbide tipped.
You pay peanuts, you get monkey's!
04-16-2011, 09:19 PM
still in business
I actually think the Morse hole saws and sawsall blades are really good ****. Cheaper and of high quality stuff.
The Following User Says Thank You to sbrn33 For This Useful Post:
04-16-2011, 09:28 PM
#18
That will be messy on wood, sheet rock and plaster.
04-16-2011, 10:56 PM
#19
I've been told that you can cut sponge to fit in a hole saw and put tap oil in it and as you push down it will keep it oiled.
04-16-2011, 11:19 PM
#20
Wont the oil get all over the ceiling:?
