Ideal 61-797 Megger - Electrician Talk - Professional Electrical Contractors Forum
Old 09-08-2009, 10:33 PM   #1
Default Ideal 61-797 Megger
I was wondering if anyone has used one of these. We have been having problems at my company with this megger. We basicly cant get it to fail. We took a piece of 500 mcm and taped up the end and took a hack saw and cut it in the middle, and exposed the copper. then we took one lead and stuck it into the wire and put the other lead to ground. We tested at 1000v and it would not fail. we're not sure if the meter is broken or not but it is brand new so any help would be great.
thanks
Tony
dareibreathe is offline   Reply With Quote
Old 09-08-2009, 10:36 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
So what path between the conductor and ground did you provide? If there isn't one, the megger can't find it.
Old 09-08-2009, 10:50 PM   #3
nothing i suppose. are you saying you would need a jumper from the conductor to the ground?
Old 09-08-2009, 10:51 PM   #4
Unless you provide a path (circuit), all you're measuring is the resistance of air. If you put a jumper in, you'll end up measuring the resistance of the jumper
If you're up for a long read, check out Stitch in Time.
Old 09-08-2009, 10:54 PM   #5
so your saying instead of taping up the other end of the wire in question We should have a jumper to ground on one end and on the other would be one lead from the megger and the other lead would also go to ground?
Old 09-08-2009, 11:17 PM   #6
What I'm saying, if I read your OP right, is all you're doing is measuring the resistance of the air between the conductor and ground. You could completely strip the conductor of insulation and as long as it's not grounded, the megger will pass it.
Now, put some dirt, or grease, or oil or water 'twixt the wire and ground and see what happens.
Old 09-08-2009, 11:33 PM   #7
Rewards Points: 150
dareibreathe, what are you doing with the megger, what is your purpose in using it?
BadSplice is offline   Reply With Quote
Old 09-12-2009, 08:58 PM   #8
"We took a piece of 500 mcm and taped up the end and took a hack saw and cut it in the middle, and exposed the copper. then we took one lead and stuck it into the wire and put the other lead to ground. We tested at 1000v and it would not fail. we're not sure if the meter is broken or not but it is brand new so any help would be great."
Of course it would not fail, you dont have a complete loop. Thats the purpose of megger if to see if there is a short to ground due to insulation
issue. The only way you can get it to fail is to make sure your distance from ground and the expose copper is enough to cause an arc.
Dennis is offline   Reply With Quote
Old 09-12-2009, 09:54 PM   #9
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
You're lucky no one got hurt. guessing at how to use a megger is not smart.
Old 09-13-2009, 08:17 AM   #10
Zog
Zog's Avatar
Rewards Points: 808
dare I breathe, dare i ask, did your employer provide you with any training on how to use your new toy?
Megger how to JohnJ0906 General Electrical Discussion 40 04-28-2012 11:06 AM
Megger brian john General Electrical Discussion 6 08-27-2008 09:11 PM
Megger ohmontherange Tools, Equipment and New Products 2 08-06-2008 08:30 PM
Megger jbfan Tools, Equipment and New Products 5 07-05-2007 06:53 AM
More on the Megger brian john General Electrical Discussion 2 05-10-2007 06:40 PM
