Seems like there was a thread on this the other day? Well anyways what I've always used to keep my pocket knife, hunting knife and wire skinning knife was the ceramic rod out of high pressure sodium lamps, after their replacement life, I've broken the exterior glass envelope, salvaged the ceramic rod, epoxied it into an old multi- blade screwdriver handle, or dowel rod, and put in my tool box for in field use, makes the edge shave able.
IMO.. there are (2) kinds of sharp.. wire stripping sharp and meat cutting sharp.. I use a wet stone for meat cutting sharp and one of these for wire stripping sharp..
I use a diamond stone on mine. The best thing I've seen is a bench grinder, turned backwards so the wheel spins up, with a fine grit sand flapper on one side and a buffing wheel on the other.
You only have to use the sanding wheel if your blade is fubared and the buffing wheel gets it surgical sharp.
They have a setup like this at a meat processing plant here. I've been going to make one for myself but haven't messed with it yet.
Related Threads
Electrician Talk
2.3M posts
93.1K members
Since 2007
