Old 09-07-2008, 08:16 PM   #1
Default Meters
I just got a Sperry DM-210A and a GB Solenoid voltage tester My question is kind of dumb. can i take a reading from a wall outlet that has power. Would that be safe. Or do I have to turn the breaker off.
Littlejim82 is offline   Reply With Quote
Old 09-07-2008, 08:24 PM   #2
EBFD6's Avatar
Uhhhhhhhhh......WHAT?
How are you going to take a VOLTAGE reading if you turn the breaker off and have no VOLTAGE present at the receptacle?
No offense, but you were right, that was a dumb question.
EBFD6 is offline   Reply With Quote
Old 09-07-2008, 08:35 PM   #3
your right that was a dumb question. Just thought there was a certain way to get reading.
Old 09-07-2008, 08:43 PM   #4
gilbequick's Avatar
Everybody has got to start somewhere. Stick around a while a read all you can. You'll get way ahead of your fellow coworkers that are around the same experience level as you right now. Ask all the "dumb" questions that you want to. Would you rather ask "dumb" questions to people you work with or to people you'll probably never see face to face in your life? Ask away.
Old 09-07-2008, 08:55 PM   #5
EBFD6's Avatar
Hey, I said no offense
Seriously, I was just busting your chops. Asking questions is the only way to learn.
Old 09-07-2008, 10:41 PM   #6
its all good thanks guys
Old 09-21-2008, 12:29 PM   #7
mattsilkwood's Avatar
actually its not so dumb. you cant take a VOLTAGE reading with the breaker off but you can take an OHM reading with it off. and just my opinion but take that solinoid tester back and get your money back, they are too dangerous. google them and you will find some pretty hairy pics of them blowing up. i dont think there is a manufacturing plant around anymore that will let them on the grounds.
Old 09-21-2008, 05:35 PM   #8
semi-electrician
Are you serious? I grew up in construction, so I have been around jobsites for the last 40 years and have yet to see anyone blow up a wiggy. I just started using one again (Fluke T + Pro) just to avoid constant ghost voltages of the regular digitals. Chances are it isnt the device but the tool operating it.
Old 09-21-2008, 09:47 PM   #9
i agree most of the time its the operator but do you want an apprentice running around with one testing everything he comes across? they are allright if all you plan to do is residential. and ive never seen a big gear blow up but it happens.
Old 09-21-2008, 10:31 PM   #10
"A" inside wireman
randomkiller's Avatar
I know what he is trying to point out to you. I work out of local 3 NYC, there are thousands of members. You hear first hand stories of gear that blew up in guys faces and every other thing you can imagine. I had a UEI digital amp clamp blow up in my hand reading 480 3ph.
BUT, I have never heard of any one blowing up a wiggy or volt con, or an associated piece of equipment with one. Not saying it's an Urban Legend but I don't think it is common at all. I also just picked up a new Fluke T plus pro when they were on special at Grainger, to avoid phantom voltage readings.
"One Nation Under God"
Old 09-22-2008, 10:19 AM   #11
Here's a Fluke Application note on voltage testers: http://support.fluke.com/find-sales/...125203_a_w.pdf
Bill
wptski is offline   Reply With Quote
Old 09-22-2008, 06:02 PM   #12
mech & rk EXACTLY right. wiggy type tester should be among every electricians " arsenal" of testers.
Old 09-22-2008, 06:14 PM   #13
Just got the Ideal 61-732. Clamp meter
Fluke Meters cdnelectrician Tools, Equipment and New Products 14 09-22-2008 07:28 AM
Electrical Meters...what are your recommendations?? NC_Electrician Tools, Equipment and New Products 72 02-14-2008 07:14 PM
Presentation electric meters Idaho Abe Vintage Electrical 3 12-04-2007 12:03 PM
dc meters frank Vintage Electrical 0 04-11-2007 04:53 PM
Phase rotation meters MDShunk Tools, Equipment and New Products 2 03-11-2007 08:51 PM
