Milwaukee Drill Repair - Electrician Talk - Professional Electrical Contractors Forum
Old 01-09-2008, 06:18 PM   #1
Rewards Points: 25
Send a message via AIM to kkelter
Default Milwaukee Drill Repair
So today when I was looking for "bugs" for the mock service we were doing I came across an old Milwaukee angle drill in the back of the shelf. I tried it out but it didn't work. I asked my teacher if I could have it and troubleshoot it.
So I brought it home and opened up the handle. I first checked to see if the switch was the problem so I bypassed the switch and connected the conductors directly. I plugged it in.. nothing. Then I checked the brushes but they were fine. I proceeded to take the drill apart and clean it/check the coils. Everything seemed fine. Do you guys think its just burnt out? What should I do with it now? I really wanted to fix it. Any ideas?
I'll post some pics in a bit..
kkelter is offline   Reply With Quote
Old 01-09-2008, 06:51 PM   #2
Rewards Points: 25
It can't be the commutator being a bit dirty can it?
The armature looks a bit rusted.. probably has been sitting on that shelf for a while.
Here are some of the specs.
Serial #: 0014102557
1/2''
10 amps
Category #: 1100
Any websites with information on this drill or parts would be awesome.
Old 01-09-2008, 06:57 PM   #3
R.I.P. 2014
Did you check the cord for continuity?
Old 01-09-2008, 08:02 PM   #4
Rewards Points: 25
Yeah, I used a voltage detector. I really need a fluke meter. It would have been easier to just check the the load side terminals on the switch instead of bypassing it to see if that was the problem.
Old 01-09-2008, 08:30 PM   #5
gilbequick's Avatar
Rewards Points: 1,000
That comm is really caked, it needs to be cleaned. The brushes won't conduct to the comm very good with it like that. If there's a lot of brush left (at least half) I wouldn't worry about replacing them, but definitely clean the comm! Try to clean the brushes though, you can try using a pencil eraser. You don't want anything that is going to change the shape of them.
Old 01-09-2008, 08:33 PM   #6
gilbequick's Avatar
By checking the cord you need to do a continuity check, not just a voltage detector. A voltage detector won't tell you if the cord is ok.
By "voltage detector" you mean just an indicator, not a meter? If you're using a meter and get 120v from hot to neut and hot to ground that should be ok too.
Old 01-10-2008, 09:13 AM   #7
Congrats on attempting to resurrect an old tool.
I'm a little confused here. You inferred that you did not have a meter to check the cord, yet your OP states that you "cleaned it/checked the coils". How did you check those colis?
Best Wishes Everyone in 2008
Be Safe Out there
Milwaukee M12 MechanicalDVR Tools, Equipment and New Products 3 11-18-2008 08:02 PM
For Sale: milwaukee 28v li ion 4 pc set steve91886 Electrician Swap 0 08-23-2008 06:16 PM
aluminum wire repair crk1a General Electrical Discussion 8 08-19-2008 09:18 PM
aluminum wire repair crk1a Other Codes and Standards 1 08-18-2008 04:34 PM
Unique Repair brian john General Electrical Discussion 3 06-16-2007 04:00 PM
