Milwaukee ECX bits - Electrician Talk - Professional Electrical Contractors Forum
Old 08-19-2011, 09:49 PM   #1
Rewards Points: 25
Default Milwaukee ECX bits
Milwuakee is making a new bit called an ECX. I got one of their multi-screwdrivers that has two different size ECX bits along with 2 phillips and two straight blades. The ECX is for those muliti-screws that can use either a flat blade or a square head. First time I pulled it out, I used it on a panel that had been opened before and the head was slightly boogered. It didn't grab, wound up flipping over to a straight blade to back the screw out. Probably works fine on virgin screws, but not on anything that someone tried to open with a phillips. They are available as a multi-screwdriver, as apart of a screwdriver set, and as a pack(5 or 6) of hex drive bits. I'm glad I went with a multi-driver, at least if it fails to work as intended I'll get some use out of it.
cavecom is offline   Reply With Quote
Old 08-19-2011, 09:52 PM   #2
gold's Avatar
Rewards Points: 2,048
Send a message via Yahoo to gold
I just saw these the other day at Lowes and i wasn't that impressed they seemed about equal to a husky screwdriver. Didn't warrant the 40 bucks IMO
Define "Anger Management"
“Free at last, Free at last, Thank God almighty we are free at last.”
gold is offline   Reply With Quote
The Following User Says Thank You to gold For This Useful Post:
Josue (08-20-2011)
Old 08-19-2011, 10:14 PM   #3
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
They're useless because not all squares are parallel to the slot. Some are 45 degrees off axis. Look closely
Old 08-19-2011, 11:04 PM   #4
I like them for putting on devices. If you use a #6 they strip too easy and a flat is just clumsy. The exc is a good compromise.
randas is offline   Reply With Quote
Old 08-20-2011, 12:15 AM   #5
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,126
They work great on square D panel covers, other than that - I just like to stick with #2 square.
Old 08-20-2011, 12:16 AM   #6
Rewards Points: 258
I think they are also designed to fit the Phillip/flat heads on devices. But they don't always fit them either. I also tried to strip 14awg ounce to no avail with the Milwaukee multi. The wire Bender works but that's nothing new. Its also to big for my pouch. It might find a knew home in my kids box. Realistate in my pouch is at a premium.
Electrical Student is offline   Reply With Quote
Old 08-20-2011, 12:48 AM   #7
RIP 1959-2015
HARRY304E's Avatar
Rewards Points: 1,344
That slot on the side is a knife sharpener.not great but it does work..
Old 08-20-2011, 01:02 AM   #8
Rewards Points: 3,855
I'm probably still gonna buy one. I buy all the new gadgets to see if they suck or not.
Josue (08-20-2011)
Old 08-20-2011, 01:40 AM   #9
Data Tech/Apprentice.
Rewards Points: 22
I bought one as an impulse buy for my old man to put in his carpentry belt and after handling it I dont think I'd ever be a big fan, its too short, too fat in the shank because of the nut driver feature and I cannot get the bits off the shelf at any hardware store or out of my driver bit set.
Despite my love for Mllwaukee I think I will stick with my Bahco ratcheting screwdriver or any other 1/4 inch driver bit holding screwdriver because I can interchange the bits with bits I actually use like #2 square drive and T30 Torx.
I'm pretty sure that actually is a wire stripper too Harry, there aint no way I'm sticking a knife in there
Old 08-20-2011, 03:09 AM   #10
Ambassador of Amps
TOOL_5150's Avatar
what would you prefer for drop ceiling cable installs: The extender type pole, fish sticks, or the string gun?
Old 08-20-2011, 06:34 AM   #11
Bucket Head
The Motts's Avatar
Rewards Points: 256
I do that, too. Most of the time they suck, but I still haven't learned.
I have a face for radio. And a voice for silence.
The Motts is offline   Reply With Quote
The Following 2 Users Say Thank You to The Motts For This Useful Post:
76nemo (08-20-2011), Josue (08-20-2011)
Old 08-20-2011, 07:13 AM   #12
Rewards Points: 946
fish sticks all the way
'I believe that banking institutions are more dangerous to our liberties than standing armies"
Thomas Jefferson
electricalwiz is offline   Reply With Quote
Old 08-20-2011, 07:31 AM   #13
RIP 1959-2015
HARRY304E's Avatar
You are right just read the spec's again but it does ok sharpening your knife......
Old 08-20-2011, 07:35 AM   #14
Rewards Points: 258
Old 08-20-2011, 08:33 AM   #15
Dave L's Avatar
Rewards Points: 150
I looked at the ECX bit but it wasnt what I needed. The driver seemed okay, nothing too special though.
I ended up buying a Wiha Zeno terminal block screwdriver that works really well, tons of torque no stripped screws. Wired 250 Estop switches - fun stuff!
I also ordered a Wiha Pozi driver yesterday as I seem to run into a lot of those
Dave L is offline   Reply With Quote
The Following User Says Thank You to Dave L For This Useful Post:
Josue (08-20-2011)
Old 08-20-2011, 09:55 AM   #16
Rewards Points: 160
Ha its ok Harry it does kind of look like a knife sharpener but yes it is actually a wire stripper
oww-is-that-hot? is offline   Reply With Quote
Old 08-20-2011, 10:03 AM   #17
Rewards Points: 160
Also they are made for all new devices not for panels or breakers or anything else. They are nice for devices because you can actually install a device with just that one tool. Strip, bend, screw... wow, that sounds kinda perverted now that I think about it. Also, they are made for EMT connectors and couplings and for most 1/4 20's. Actually a pretty good tool if your doing a lot of devices, which happens a lot for me, or doing long runs of conduit, which happens a lot for me... so it's really just about what kind of work you do.
Old 08-20-2011, 10:37 AM   #18
Deplorable-Electrician
Rewards Points: 17,610
Same here I picked one up when I saw them in a rep manned display at home depot. I have been using it around the house and it works fine on devices which is what the rep said they were for, not for A-B (combo screws or din style terminals). The stripper in the handle is a real joke. I have found the ecx bit is much better suited swapped over to the Klein 10 in 1 that I usually carry.
Old 08-20-2011, 11:44 AM   #19
Rewards Points: 160
No it actually works well, you just have to spin it around the wire once and then pull and you have a stripped wire
Old 08-20-2011, 11:46 AM   #20
Maybe on romex but I tried it on THHN/THWN with real poor results.
spline bits sparky723 General Electrical Discussion 28 12-16-2010 12:59 AM
Let's talk auger bits! 480sparky Tools, Equipment and New Products 22 11-28-2010 12:27 AM
SDS bits for sale mark35 Electrician Swap 7 09-01-2010 12:04 AM
Drill bits deakn Tools, Equipment and New Products 34 01-14-2010 07:31 PM
drill bits electric mike Tools, Equipment and New Products 18 07-08-2009 03:38 PM
