Milwaukee Hackzall - How Can I Lubricate It? - Electrician Talk - Professional Electrical Contractors Forum
Old 04-10-2012, 09:11 PM   #1
WIElectric's Avatar
Default Milwaukee Hackzall - How Can I Lubricate It?
So I have a Milwaukee Hackzall that I have been using to cut a lot of plaster ceilings. My problem is that all of the dust falls inside of the body and around the cylinder. This has casued the hackzall to not funtion properly.
I am thinking about blowing it out with compressed air - but what product should I use to lubricate the cylinder?
WIElectric is offline   Reply With Quote
Old 04-10-2012, 09:58 PM   #2
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
grease it, if that doesnt work, you might have to open it up and clean it some
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
Old 04-10-2012, 10:08 PM   #3
Data Tech/Apprentice.
Rewards Points: 22
DO NOT OPEN IT UP! I opened a tool up once, the motor expanded and I couldn't reassemble it.
Old 04-10-2012, 10:15 PM   #4
Rewards Points: 2,000
Try silicone lubricant. It's thin, so it'll get in there, and lubricates dry, so it will not stay gooey and collect dust and turn into sludge. Plus it's not going to deteriorate plastic parts like petroleum based lubricants can.
Old 04-10-2012, 10:23 PM   #5
WIElectric's Avatar
This makes sense. I will try it out and report back.
Old 04-10-2012, 10:24 PM   #6
WIElectric's Avatar
I would never open up a power tool. I would pay someone who new what the were doing first.
Old 04-10-2012, 10:30 PM   #7
Hope it works out for you. It may not be as ideal as opening it up and giving it a proper cleaning, but I have had success with this method on my hammer drill and sawzall.
Old 04-10-2012, 10:46 PM   #8
zap
tates1882's Avatar
Rewards Points: 756
If you guys can't handle opening a tool up and doing a little maintenance then maybe you should pick different trade. I'm not saying doing a full repair but a little cleaning and lubricating.
Old 04-10-2012, 11:00 PM   #9
WIElectric's Avatar
This mentality says that a home owner who is an auto mechanic should be able to cobble together their own service....and have it opperate properly. I know that isn't true.
Old 04-10-2012, 11:34 PM   #10
Bababoee
captkirk's Avatar
Rewards Points: 2,030
I would open it. Just do it carefully. I fixed a couple of drills this way, and a giant hand blender. When you consider how much they will charge you to have someone else fix it, you would be better off buying another saw... You can get a reconditioned tool only from Millwaukee CPO for like 50 bucks and tech will charge you at least that much to fix it...
Full time Bovine Scatologist.
Old 04-11-2012, 12:13 AM   #11
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 3,426
I point it nose down and and pull the trigger, all of the vibration seems to shake out the dust. I would not add anything that would attract or hold dirt.
or just enjoy the show.
Old 04-11-2012, 12:20 AM   #12
Ambassador of Amps
TOOL_5150's Avatar
sounds like you bought a ryobi or some crap.
Old 04-11-2012, 12:26 AM   #13
WIElectric's Avatar
I do this after use..and bang it with the ruubber side of my screw driver.
Old 04-11-2012, 12:31 AM   #14
Jlarson's Avatar
Rewards Points: 2,758
I clean ours out every once and awhile with contact cleaner then re lube them with dry molly lube.
Sometimes you got to get in there with a long q-tip too if the gunk is really caked in there.
Old 04-11-2012, 12:47 AM   #15
Rewards Points: 150
I'm going to second the suggestion of silicone-based lubricant. The petro-based stuff eats plastic in a bad way, and so many others stay tacky and just attract a ton of crap. Seems to me that if you've got a ton of plaster dust in it, you'd need to blow it out with air or open it up. If it's beyond the warranty, I'd crack it open, but if not, I'd just turn the compressor on it and see what I could get out of it.
CanadianBrad is offline   Reply With Quote
Old 04-11-2012, 02:10 AM   #16
Rewards Points: 22
Nah it was a Milwaukee, I took the motor out of the case and it expanded I dont know FA about electric motors but I'm assuming they had some kind of press to insert them back into the casings as it was a good 2mm larger than the space it had to be inserted back into. Perhaps the windings were under tension, I really have no idea except for the fact that sucker wasnt going back in. Curiosity while checking brushes really did kill the cat
Old 04-12-2012, 01:07 AM   #17
Compressed air for me. I wouldn't put lube in a tool unless the manufacture recommended it. It will hold dust and dirt and then be really gunked up.
I took apart a Dewalt XRP drill one time. It didn't go back together. Complicated thing.
Old 04-12-2012, 02:57 PM   #18
Lurker...
LJSMITH1's Avatar
Rewards Points: 306
"the motor expanded"?
Larry
LJSMITH1 is offline   Reply With Quote
M12 Hackzall jza Tools, Equipment and New Products 31 09-04-2011 02:03 PM
Milwaukee Hackzall Mike in Canada Tools, Equipment and New Products 32 07-26-2011 02:11 AM
12v milwaukee hackzall crash_777 Tools, Equipment and New Products 12 02-08-2011 06:23 PM
For Sale: milwaukee m12 hackzall kit Breakfasteatre Electrician Swap 9 01-15-2011 11:12 PM
Milwaukee Hackzall M12 amptech Tools, Equipment and New Products 2 10-24-2008 07:36 AM
