New Toys - Page 263 - Electrician Talk - Professional Electrical Contractors Forum
Like Tree558Likes
Old 04-16-2017, 06:02 PM   #5241
mdnitedrftr's Avatar
Rewards Points: 897
Originally Posted by Switched View Post
I can't quite read what kneepads those are.... What brand and model #?
Around here they call em "San Francisco Sandals"......
http://www.steelflex.com/product/str...ks-cushioning/
- Rich
mdnitedrftr is offline   Reply With Quote
Old 04-16-2017, 06:08 PM   #5242
Rewards Points: 897
Originally Posted by Lone Crapshooter View Post
Need to get a sanding pad attachment with 180 grit or finer sandpaper. Those tools do a excellent job on sanding the callouses on the bottom of your feet. I know from experience.
LC
Haven't used them on calluses....but I have used the sanding attachment before. It does do a good job.
- Rich
Old 04-16-2017, 08:58 PM   #5243
Rewards Points: 4,888
Originally Posted by mdnitedrftr View Post
Those look very interesting, haven't heard or seen anyone using them before.
Keep us posted, I'm always interested in something that works. They look like they could be a little uncomfortable to me, with that matrix pattern. I wonder how that makes your knees feel after a few hours, like that matrix pattern will dig into your skin?
Old 04-16-2017, 09:09 PM   #5244
Rewards Points: 1,448
Does a very good job. I am using about a 80 grit for now which is a bit aggressive for calluses.
lC
Old 04-16-2017, 09:26 PM   #5245
Deplorable-Electrician
Rewards Points: 28,472
lC
Now my wife will want mine in the bathroom all the time for sandal season.
I could give her the M12 and buy a new M18.......THANKS!
Lone Crapshooter likes this.
Old 05-09-2017, 09:20 PM   #5246
Jlarson's Avatar
Rewards Points: 3,008
10" Klein/NWS re-brands and a set of Williams ratchets.
splatz and spenny like this.
The Following 2 Users Say Thank You to Jlarson For This Useful Post:
spenny (05-16-2017), Ty the electric guy (05-16-2017)
Old 05-15-2017, 11:53 PM   #5247
Rewards Points: 333
Scored this Ideal kit on clearance for $51, which is about what the pouch alone goes for. Web belt was included too, but forgot to stick it in for the pic.
backstay and splatz like this.
Grogan14 is offline   Reply With Quote
Old 05-15-2017, 11:59 PM   #5248
Big nosed attic troll
Majewski's Avatar
Rewards Points: 2,082
Wow I'm jealous! Nice buy dude!
Old 05-16-2017, 09:04 PM   #5249
Rewards Points: 175
Those Steel flex knee pads cost $90 bucks !!!!! Sheeeze I hope they work!!!
There are 3 types of people...Those that make it happen, those that watch it happen, and those that wonder what the f**k just happened.
sburton224 is offline   Reply With Quote
Old 05-19-2017, 10:54 AM   #5250
Rewards Points: 22
I've been thinking about upgrading to a high quality set of ratcheting combo wrenches, as my Huskies are pretty sloppy on the open end, enough that using them on a unistrut strap bolt (oh man I loathe those cheap POS bolts with factory rounded corners!) leaves me praying to the elder gods that I don't make complete circles out of the head. I figured I'd order one of each brand that interested me (without having to track down a dumb truck) in 7/16" and see what I like enough to order in a full set.
Left to right is the Husky, Wera Joker, Proto ASD and SK X-Frame. Nice progression in lengths, with the SK a whole inch longer than the Husky. All of them have some interesting trickery in the open end to help grab a hex and keep it from rounding over, little ridges and wavy bits. The Wera has some mad science going on with a jaw that's like a partial 12-point socket with a 6 point insert bolted to it. The way they overlap gives it the ability to hold a nut or bolt on its own, thought that was pretty cool.
The ratcheting ends were all different. Wera has a traditional 12- point socket type, Proto has a 12-point spline / universal that's also angled and reversible, SK has a 6-point hex socket with a ludicrously fine ratcheting mechanism that's supposed to also be even more strong & durable than the traditional kind, with the hex head supposed to allow you to put some more muscle into it without rounding like a 12-point. I rigged up a little test of the low angle ratcheting abilities: a right angle bracket bolted to unistrut in the third hole, which all 4 could just reach. The Husky couldn't do a damn thing, Proto was not having a good time of it because the angle took it up to where it was hitting the rolled edges of the strut instead of the full width, the SK was oddly inconsistent, sometimes hitting an angle where the slop between the socket and the nut was just enough to keep the teeth from engaging, but I could clear it up by putting pressure on the wrench in line with it, as if I'm trying to push it further into the strut. The Wera just kept ratcheting like a champ, clockwise or counter.
I was expecting to like the X-Frame best, but Wera's Joker put in a surprising show, I really liked it a lot.
HackWork, splatz and Rob-Bryant like this.
The Following User Says Thank You to Jarp Habib For This Useful Post:
HackWork (05-19-2017)
Old 05-19-2017, 11:13 AM   #5251
Rewards Points: 22
Of course, the fatal flaw in my plan is that I can't test 7/16 on those stupid cheap unistrut strap bolts. Guess I'll have to order 'em all in 3/8 for the next round!
$2500 poorer and 17 complete sets later, maybe my testing will be complete...
Majewski likes this.
Old 05-19-2017, 12:11 PM   #5252
tjb
Cool Kid
Rewards Points: 291
Thanks for putting the time into this! That's sort of how I do it. Buy one before I buy a set.
Jarp Habib and splatz like this.
tjb is offline   Reply With Quote
Old 05-19-2017, 04:28 PM   #5253
NRA Member
backstay's Avatar
Rewards Points: 1,438
Fluke 374 clamp on, because I do so much DC stuff.
Jarp Habib, splatz and Majewski like this.
backstay is online now   Reply With Quote
Old 05-22-2017, 08:36 PM   #5254
Rewards Points: 897
Yea, they're not cheap but neither are knee replacements. I learned the hard way, you gotta take care of your joints...and body in general.
Its been a few weeks now, and a couple things I've noticed...
- A few of the seams have become frayed, and while its not the biggest deal, I think for the price, they should hold up a little better. I plan on emailing the company about it.
- Also, they're not the quickest things to put on. If I only need kneepads for quick minute, I'm hesitant to grab them just because by the time I put them on, I could have finished the task.
- Climbing ladders with them is annoying. They stick out a good bit and I catch them on every rung.
Even with those caveats, they still do a very good job at protecting your knees, and thats obviously what is most important. They are far and away better than anything that I've tried from HD or Lowes..and believe me I've tried almost all of them.
And FYI, you can find them for a little cheaper if you do your homework. I got them for $70 and free shipping. It was worth it to me.
- Rich
Old 05-22-2017, 09:52 PM   #5255
Majewski's Avatar
Mine looks different!
Old 05-26-2017, 09:46 AM   #5256
Rewards Points: 22
More new toys! Gonna be wrenching on the car this long weekend, figured I might as well throw the money saved not taking it in to the shop on new toys.
I played with the One-Key settings a little bit and it is pretty slick. Made a custom ultra-low setting of 350RPM and torque level 1 and I was impressed that it worked. I was able to grab a spinning socket and stop it without straining at all, that's some sensitivity. Full speed, nuh-uh, not trying that.
Sent from my SM-G935T using Tapatalk
Old 05-26-2017, 09:51 AM   #5257
Nice wrench, best of luck with it!
Jarp Habib likes this.
Old 05-26-2017, 11:06 AM   #5258
NRA Member
backstay's Avatar
Maybe it "is" different.
Old 05-26-2017, 11:38 AM   #5259
Majewski's Avatar
I just got a m18 hackzall, yay I'm included!
Old 05-26-2017, 11:41 AM   #5260
That is pretty normal
MCasey is offline   Reply With Quote
Tags
new toys, tools
New toys sparky970 General Electrical Discussion 7 03-27-2011 10:36 AM
Who has toys??? elecapp79 Tools, Equipment and New Products 53 03-25-2011 09:34 AM
Share neat Toys for New Year BobBob General Electrical Discussion 3 01-07-2011 08:12 PM
More Cop Toys BBQ Off Topic (Non Trade) 112 01-01-2011 05:04 PM
New Toys :) bduerler Tools, Equipment and New Products 25 03-21-2010 05:07 PM
