Offset Screwdrivers - Electrician Talk - Professional Electrical Contractors Forum
Old 06-17-2011, 06:42 PM   #1
Default Offset Screwdrivers
Does anyone use them? I've heard they supposedly save a lot of time (it was a master electrician telling me this), but I've never found any good use for them. They don't put things on with enough tightness for my liking, so I just carry my standard screwdrivers.
Schreck is offline   Reply With Quote
Old 06-17-2011, 06:55 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
I use mine all day long. Installing devices & cover plates, mostly. 90% faster.
Old 06-17-2011, 06:58 PM   #3
Rewards Points: 2,002
I think I bought one back in 1996 or 1997. I still haven't used it.
The Following User Says Thank You to user4818 For This Useful Post:
ce2two (06-18-2011)
Old 06-17-2011, 07:01 PM   #4
They're also great for checking for obstructions when cutting in a box or remodel can.
You need to actually do work in order to use one.
The Following 5 Users Say Thank You to 480sparky For This Useful Post:
Chris Kennedy (06-17-2011), dronai (06-18-2011), Speedy Petey (06-18-2011), The_Modifier (07-10-2011), walkerj (06-19-2011)
Old 06-17-2011, 07:02 PM   #5
Work? What's that?
Old 06-17-2011, 07:14 PM   #6
Chris Kennedy's Avatar
Rewards Points: 2,000
I'm actually thinking about posting a tutorial here on how to install an old work/cut in box without marking up the wall with a sharpie. The off-set screw driver is a very important part of this process.
Bulldozers and Dirt
Old 06-17-2011, 07:25 PM   #7
Rewards Points: 504
Work? What's that?
I'm not sure. I have a feeling I'm going to find out on Monday....
Mike_586 is offline   Reply With Quote
Old 06-17-2011, 07:26 PM   #8
Originally Posted by Chris Kennedy View Post
.......... without marking up the wall with a sharpie. ..........
Does using a pencil count?
Work? What's that?
What you do when you use a map and a shovel.
Old 06-17-2011, 07:34 PM   #9
There is never a reason to draw on the wall with anything when installing a cut in box.
Bulldozers and Dirt
Old 06-17-2011, 07:37 PM   #10
tkb
tkb's Avatar
Rewards Points: 502
How does an offset screwdriver save time or help with a cut in box?
Cathedra mea, regulae meae
tkb is offline   Reply With Quote
Old 06-17-2011, 07:47 PM   #11
Coaster Sparky
thegoldenboy's Avatar
Rewards Points: 1,000
Okay, I'll bite. What do you know that I don't? I've always located the studs, matched existing heights, unless in plaster and wood lathe, traced box, cut hole, installed box.
I saw a girl texting & driving the other day & it really made me mad, so I rolled down my window & threw my beer at her.
thegoldenboy is offline   Reply With Quote
Old 06-17-2011, 07:48 PM   #12
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,126
lol....... Thats not what they are talking about
Old 06-17-2011, 07:48 PM   #13
That's a hacks' offset. This is a pro's:
Josue (06-18-2011)
Old 06-17-2011, 07:49 PM   #14
Ambassador of Amps
TOOL_5150's Avatar
He just holds the cut in box to the wall.. and kicks it into the wall like a boss.
Old 06-17-2011, 07:49 PM   #15
Ambassador of Amps
TOOL_5150's Avatar
Pros dont use klein
The Following 2 Users Say Thank You to TOOL_5150 For This Useful Post:
administr8tor (06-17-2011), randas (06-17-2011)
Old 06-17-2011, 07:51 PM   #16
Anyone can score the wall with a nail, screw, awl, drywall saw, utility knife, screwdriver, etc.
Old 06-17-2011, 07:58 PM   #17
Why would you draw on the wall? Use an offset as Ken has posted and drill one little " hole in the wall. Spin that bitch around to find obstructions. Then from that little hole you saw horizontally in both directions checking the dimension with the box until your cool the do the same vertically. No marking required.
Bulldozers and Dirt
Old 06-17-2011, 07:58 PM   #18
Coaster Sparky
Like a boss?
Old 06-17-2011, 08:03 PM   #19
Ambassador of Amps
TOOL_5150's Avatar
That takes to much ****ing around. Find center of the box, put a hole to make sure youre not cutting into a stud, mark it and cut it, wire it up and gtfo.
Old 06-17-2011, 08:05 PM   #20
You live in a perfect world. Again, if you feel the need to draw on a wall to install a box, you won't be on my crew for very long. Just absolutely unnecessary.
Bulldozers and Dirt
Box Offset Conduit Phil General Electrical Discussion 159 10-03-2012 06:16 PM
Not doing a box offset every time Jlarson General Electrical Discussion 136 06-10-2011 07:50 AM
Best screwdrivers Niven8 Tools, Equipment and New Products 71 08-01-2010 08:36 AM
Offset Nipples Flash NEC Code Forum 22 07-19-2009 06:13 PM
Need help making a rolling offset steadypimpin General Electrical Discussion 38 06-09-2009 07:07 PM
