Old 06-06-2008, 08:37 PM   #1
Default Philips #2 holding screwdriver
Does anyone know of a good #2 phillips holding screwdriver?
I usually wish I have one when I need to change out a breaker and a shut down is not reasonable. Please spare the lectures about working on live equipment, I always wear full arc flash PPE and am very aware of the hazards.
MNservicetech is offline   Reply With Quote
Old 06-06-2008, 09:11 PM   #2
Chewing gum, duct seal, tape and
http://www.shop4tools.co.uk/acatalog...rewdrivers.php
Old 06-06-2008, 10:27 PM   #3
Greenlee has them also.
Old 06-06-2008, 11:41 PM   #4
Chief Electron Relocator
Click here.
Old 06-07-2008, 08:49 AM   #5
That's the one. There is one laying on the counter at one of my supply houses as we speak.
Old 06-08-2008, 09:34 PM   #6
Thanks guys. I have the Greenlee one on order now. Greenlee seems to be using good metal compared to Klien tools these days. I went through 2 Klein hooded screwdrivers in a 6 month period (the tip kept breaking apart) and since I switched to Greenlee I haven't had any problems.
On another subject... Does anybody else wish that a manufacture would make wire strippers with hardened steel? I'd love it if Ideal made the 45-915's with hardened steel. I'd pay double for a pair that wouldn't get f'd up everytime cut though something harder than a piece of play-dough!
Old 06-09-2008, 12:43 AM   #7
village idiot
piette's Avatar
What are you cutting? I have never had a strippers get knicked up by cutting or stripping wire with it. I have however once tried to cut a piece of very small steel wire and knicked the cutting blade with it. I was then promptly smacked up along side the head by my leadman (this was about 12 years ago) and told "thats why it is called a WIRE STRIPPER and not a cut whatever the hell you want tool!!!"
Jeff
piette is offline   Reply With Quote
Old 06-09-2008, 12:54 PM   #8
Jeff
I don't cut anything but copper either, but think about why you've had to replace your strippers in the past. Either they get dull, you lose the damn spring, or the cutters somehow get messed up and bind. I just think it would be nice to have the option like the Klein linesman pliers do. (ie. D213 vs. D2000)
Old 06-09-2008, 05:41 PM   #9
greenish
I bought the greenlee holders the first day I saw them at the supply house and they are perfect in my eyes.
dadadan is offline   Reply With Quote
Old 06-09-2008, 09:02 PM   #10
"A" inside wireman
randomkiller's Avatar
I like the ones that are spring loaded that go completely inside the screw so you can fit it into a tighter place than the outside type.
"One Nation Under God"
Old 06-09-2008, 09:22 PM   #11
Only nicked a pair cutting the wrong type of wire. I have never lost a single spring, I throw them away before I leave the supply house.
Old 06-09-2008, 10:33 PM   #12
village idiot
piette's Avatar
You guys probably know this, but if you buy Klein strippers from the Home Depot, you can pretty much blow them apart and they will exchange them for you for free. Every time mine get dull, I just crank the center bolt down a little tighter and bring them in, they give me a brand new stripper every time. I have only bought one in the last......well I can't even remember the last time I had to buy a stripper, I always get a free replacement from the Home Depot.
Jeff
Torque-limiting screwdriver KayJay Tools, Equipment and New Products 30 11-19-2011 03:28 PM
controls screwdriver pehelectric Tools, Equipment and New Products 16 09-19-2009 09:56 PM
holding in momentary switch freddiekd General Electrical Discussion 2 12-17-2007 09:48 PM
