Old 09-04-2011, 06:18 PM   #1
Les Voltage
Default Porter Cable 12 volt lithium
I have had these 2 drills for about 3 months. I have to say this was the best 100 bucks I have spent on cordless tools. The drill is ok and will drill almost anything small. I use it alot for drilling 1/4" pilot holes in cans before using a uni bit. I also use it for triming out devices because of the adjustable clutch. the impact is just awesome and will drive almost anything an electrician would need to drive all day on one battery. The impact is very light and fits well into my pouch. It only takes about 30 min to get a full charge. One thing that Im starting to like is how the battery is either 100% or dead. there is no in between. I have been looking at this, but not sure how well a little sawzall would work for me
Old 09-04-2011, 06:34 PM   #2
I have the 18v set, feel like I NEED to get this one now also. VERY happy w/ the 18v set. Surprising how little they cost.
oww-is-that-hot? is offline   Reply With Quote
Old 09-04-2011, 09:47 PM   #3
Former sparky
If it is comparable with the Milwaukee 12v hackzall you will be very pleased, I find if you carry an assortment of blades it can get into very small spots and do things you could never do with a full sized saw. I have yet to cut EMT larger than 1" but I have cut strut with it.
Old 09-04-2011, 10:48 PM   #4
ilikepez's Avatar
I think they are basically the same drill and hammer-drill as the Milwaukee m12. The hackzall look different. How much did they cost you?
ilikepez is offline   Reply With Quote
Old 09-05-2011, 10:56 PM   #5
Les Voltage
Got em on sale at Lowes for 100. I think 129.00 now. They are about the same size as the m12, the batterys even look like they would fit, but dont. M12 seems heavier, it also has alot more tools with the same battery. For the money difference the proformance of the M12 had better be alot better.
Its not a hammer drill its an 1/4" impact and drill.
Im sure Porter Cable will never have this
Old 09-05-2011, 11:09 PM   #6
Les Voltage
The Porter Cable one has some kinda adjustable clamp that holds the material
From the site:
The clamping feature works great, but it could be better. While the clamp itself is fine, the problem lies within the adjustment. The saw uses a simple screw to lock clamp into place. Any time you need to adjust the clamp, you are required to pull out the allen wrench, loosen the screw, adjust the clamp, tighten the screw, than put away the wrench. Porter-Cable has designed the tool with on on-board wrench holder, which helps, but is still a hassle. This is not only a convenience issue, but also there is the chance you might lose the hex wrench
Old 09-05-2011, 11:46 PM   #7
That's It?'s Avatar
Take out the screw and put in something you you can tighten with your fingers. My oscillating tool had the same deal, needed an allen wrench to change the blade. The screw got replaced with all thread rod and a wing nut.
That's It? is offline   Reply With Quote
Old 09-05-2011, 11:53 PM   #8
Heavily Armed Member
HARRY304E's Avatar
From the site:
What is the largest diameter that clamp can be adjusted too.
That look cool as well though.
Old 09-06-2011, 12:08 AM   #9
Les Voltage
Id say not very much considering the size of the blade.
Old 09-06-2011, 12:14 AM   #10
HARRY304E's Avatar
Well it looks good for small pipe at least..
For Sale Minty HK Porter 6990FS Ratcheted Cable Cutters Electric Bill Electrician Swap 1 09-01-2011 04:22 PM
Porter Cable tools.. B4T Off Topic 11 08-02-2011 10:12 PM
18v porter cable? oww-is-that-hot? Tools, Equipment and New Products 14 07-31-2011 11:18 PM
porter cable cordless drill BuzzKill General Electrical Discussion 22 04-24-2010 01:43 AM
volt drop on cable Derek UK Electrical Forum 2 12-29-2007 03:02 PM
