Closed Thread
Old 09-09-2008, 08:00 PM   #1
Default PSE&G meter key
Does anyone have a key they are willing to sell?
heel600 is offline
Old 09-09-2008, 08:54 PM   #2
el abogado del diablo
good luck..
oldman is offline
Old 09-09-2008, 10:47 PM   #3
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
Here is your meter key:
~Matt
TOOL_5150 is offline
Old 09-09-2008, 11:09 PM   #4
What does the lock look like?
Wireless is offline
Old 09-09-2008, 11:25 PM   #5
Bkessler's Avatar
Every time I see an Edison guy I ask for free meter lock key or ask if he has seen mine laying around near his truck. Sometimes they laugh, sometimes they ignore me but they have never given me a key.
When ls lunch
Bkessler is offline
Old 09-09-2008, 11:28 PM   #6
Bkessler's Avatar
In the last seven years I have used an angle grinder at least 25 times on residential meters. The utility guys say they have to cut them off a lot as well and the keys don't work or they wont have the right one with them. I have mentioned I cut them off to them as well and know has seem to care. The usual circumstance is either a burned bus bar or main that cannt be done with out pulling the meter. I don't do it for fun.
When ls lunch
Bkessler is offline
Old 10-28-2008, 04:55 AM   #7
Default Meter Key
What's it worth to you? I have machined keys for several of my contractor friends.
enauman is offline
Old 10-28-2008, 04:57 AM   #8
Burger Flipper
TOOL_5150's Avatar
Its worth about the the same value as an angle grinder. Whatever costs less... I am going to use.
~Matt
Old 10-28-2008, 05:53 AM   #9
Default key
Just to be sure we are on the same page... The keys I have machined are a small diameter cylinder with a rod that pass through the center and is threaded into the body. When the rod is threaded in, it expands the end o the cylinder to open the lock. Does this sound like what you are looking for?
enauman is offline
Old 10-28-2008, 08:24 AM   #10
Yep!
heel600 is offline
Old 10-28-2008, 12:04 PM   #11
Default Meter Key
In that case, I can make you one for $200 for brass and $275 for stainless steel.
enauman is offline
Old 10-28-2008, 06:16 PM   #12
The last few genuine Brooks keys I've seen on eBay have gone near 600 bucks each. It's not the red handle key some sellers try to con you into buying.
MDShunk is offline
Old 10-28-2008, 11:45 PM   #13
Licensed Journeyman
nolabama's Avatar
do they fit all barrell locks, ?meter locks?
nolabama is offline
Old 10-28-2008, 11:54 PM   #14
couldn't find brooks keys on google! Do you have a link?
I took some locks apart, and it sure looks like those red handled ones will work. Do you know what specifically is different?
Thanks!
heel600 is offline
Old 11-01-2008, 06:23 PM   #15
Default Meter Keys
Provided there is nothing illegal about it, If any of you guys are interested, I can make you meter keys to your specifications. Just email me at enauman@roadrunner.com with a dimensional sketch and I will give you a quote. I have made several for my contractor friends that work in the so. Cal. area. They are real happy with them. I make the body out of 304 stainless steel so they last. I have several of the type I made for the guys out here in stock. They work on the meters in the area just fine. If you want to be sure you get one that works in your area, the best way is to send me a lock or a dimensional drawing of your requirements.
enauman is offline
Old 11-07-2008, 09:42 PM   #16
BIGRED's Avatar
Check out www.brooksutility.com
BIGRED is offline
Old 11-08-2008, 10:34 AM   #17
I've seen Brooks' website. The important dimensions are missing and the resolution of the "drawing" isn't fine enough to allow scaling. If someone has a key that I can measure, I will make them a spare key for free so I can get accurate dimensions. I will return the key once I have measured it. After researching several manufacturers and databases, it is apparent that there are several designs of this type of lock and a "one key fits all" solution isn't likely. However, if you have accurate dimensions, I can duplicate just about anything you come up with. - Just trying to help.
enauman is offline
Closed Thread
Elec meter 5' from a gas meter heel600 General Electrical Discussion 18 11-23-2008 04:43 PM
stolen meter nolabama Tools, Equipment and New Products 12 11-01-2008 11:36 AM
what meter should I get ToddH General Electrical Discussion 13 10-30-2008 07:28 PM
Which Fluke meter? iAmCam Tools, Equipment and New Products 51 10-22-2008 06:27 PM
Wanted: In Need of Meter gilbequick Electrician Swap 23 07-26-2008 08:40 AM
