Tools for Cat 5 & Cat 6 - Electrician Talk - Professional Electrical Contractors Forum
Old 12-06-2011, 07:10 PM   #1
A Little Short's Avatar
Rewards Points: 124
Default Tools for Cat 5 & Cat 6
Without starting out with expensive tools, what brands/kinds of basic tools would do a good job with Cat5 & Cat6 cables. Such as a RJ45 crimp tool, a punch down tool, and a LAN checker and toner?
Old 12-06-2011, 09:21 PM   #2
Crimpers, Greenlee or Ideal.
Punch down, Harris
LAN checker, Fluke
Toner, Tempo
weston is offline   Reply With Quote
The Following User Says Thank You to weston For This Useful Post:
A Little Short (12-06-2011)
Old 12-06-2011, 09:38 PM   #3
FireInTheWire's Avatar
Rewards Points: 262
Punch down, Harris
LAN checker, Fluke
Toner, Tempo
I second this. Go on Ebay and find yourself a Harris punchdown. Industry standard. I've used all sorts of other ones and none compare.
I'd like to add a small flathead screwdriver for working with the faceplates and jacks.
Also... SNIPS and a knife. Best tools I own. Those Klein sets with the cable knife and snips in a leather belt-pouch are so dang handy. I use the knife part to help with stubborn ceiling tiles that need an little encouragement to seat back down
FireInTheWire is offline   Reply With Quote
The Following User Says Thank You to FireInTheWire For This Useful Post:
Old 12-06-2011, 10:00 PM   #4
Rewards Points: 77
Snips- http://www.amazon.com/Klein-2100-7-E...226434&sr=8-11
Punch tool- http://www.amazon.com/Fluke-Networks...3226486&sr=1-1
LAN Tester- http://www.amazon.com/Multimedia-Voi...3226618&sr=1-1
Tone and Probe- http://www.amazon.com/Fluke-PRO3000-...3226564&sr=1-1
These tools have done well for me... and that has been about 8 years of use so far. Good advice to get a small flat tip screwdriver as well, you will use it alot to open data jacks and pull pairs off of phone blocks and patch panels. I suggest the mini Wiha variation.
astrodoggie3000 is offline   Reply With Quote
Old 12-06-2011, 10:16 PM   #5
NO high voltage here
Rewards Points: 1,248
tone and probe.... Progressive
butsett, harris/fluke. Fluke owns harris now
punchdown-ideal, Paladin(best blades and punchdown), or harris
scissors-klein is the best for this
crimper-ideal rachetmaster
You should also have a basic wiremapper. The ideal one at HD is great, but obviously fluke is better
All I do is data/voice so feel free to ask
Old 12-06-2011, 10:35 PM   #6
Rewards Points: 124
What's the difference between a 814, 914, & 914S punch down tool?
Old 12-06-2011, 10:39 PM   #7
the 914s is rubberized
the 900 series also has the plungers too
Old 12-06-2011, 11:29 PM   #8
Data Tech/Apprentice.
Rewards Points: 22
What do you guys use your scissors for? I have a pair but I only use them for cutting kevlar and label tape. Everything else I do with dykes.
For testers - they sell cheap mod-taps or wiremap testers over here for like $5.00NZD on our version of Ebay which theres nothing wrong with as your just checking your wiremap is correct.
I had an extech tone source that wasnt really that usefully unless I stripped back the 2 pairs and twisted them into 2 conductors to tone out individual cables from a loom. I now have a Fluke intellitone which I am really happy with and it also has a pair test function. We certify all our installs with a Fluke DTX 1800 scanner so the wiremap is redundant for me in most cases unless I'm trouble shooting someone elses work.
I have a pair of http://www.acetoolonline.com/Klein-D...kle-d257-4.htm in my hand holding them with my pinky and the ball in my thumb when I'm doing a panel of CAT6A with plastic between each conductor as it leaves both hands free but still can snip it out, they told us when we did the cert for the product that it was fine to leave in and punch down with the conductor into the jack but I do not agree with them on that and we were having problems with no continuity on the pin that the plastic was punched down onto.
I have used a Fluke punchdown tool a couple of times and they are very nice, went to order one and they wanted $220NZD for it so for now I can make the cheap generic ones work for me, just throw away the 110 that comes with them. I have a genuine Krone tool and a "Klone", I really cant tell the difference to tell you the truth and couldnt if I was blindfolded aside from the "Klone" is covered in the grease from direct buried cables.
They also make "Jack-rapid" tools for most products but I have never really warmed up to them, it punches down all 4 pairs at the same time.
I like to wear a http://www.acetoolonline.com/Custom-...p/clc-140m.htm on my left hand and I hold the jack on my third knuckle bone for punching down.
I also was in a store once and they had "garden hose corner guides" on sale for $1.99, before I do a cable run I cable tie them onto the corners of the basket tray and can pull around 4 corners by myself with the rollers, these are invaluable since every run is a home run.
Old 12-06-2011, 11:50 PM   #9
When you do this **** all the time, you need a good punchdown. the cheap ones are cheap for a reason. the blades suck on them, and the spring will break
Harris/fluke telco/data stuff is the same now too
As for the scissors. We use them for everything!!! cutting cable, stripping cable, cutting cable ties, cutting packages, cutting velcro, cutting more wire, and a lot more that i cant think of now.
The two tools i use most are my scissors, and a punch down.
as for that rapid-jack thing... waste of money, unless you do only one jack type. A lot of times, you will switch the brands from job to job.
this is the scissors too
The Following 2 Users Say Thank You to mikeh32 For This Useful Post:
chewy (12-07-2011), Ty Wrapp (04-20-2012)
Old 12-06-2011, 11:52 PM   #10
i use this punch down tool http://www.techtoolsupply.com/Produc...ode=PAL%2D3586
jaym812 is offline   Reply With Quote
Old 12-07-2011, 12:35 AM   #11
Rewards Points: 22
Yeah those punchdowns are a disposable item really at $12NZD, keep 1 in my pouch and spare 2 in my vehicle, I chuck the blades away and use other ones the company supplies.
Interesting about the scissors, I use these if I need to strip wires like for clocks or nurse call systems and they cut like a hot knife through butter http://www.service.kleintools.com/To.../Product/11057 But I think the feature I use most would be the screw shears.
Old 12-08-2011, 11:56 PM   #12
zwodubber's Avatar
Rewards Points: 1,010
Needed to take a pic for another thread so I grabbed this stuff also. Crappy webcam pics because I broke my iphone
These are the basic low voltage tools I keep with me and have gotten me through what needed to be done.
Random parts bin
RG6 stripper
Klein 16 - 26 stripper
Ideal punchdown
D Sub crimper
small cutter
Klein F-type and bnc compression tool
Ideal RJ-45/11 crimper
Small drivers
D sub insertion/removal tool
Ideal tone generator and amplifier probe
Ideal VDV tester
Ideal Securitest (CAT5/6, CCTV)
Ideal Stripmaster RG6 tool
Have some others in the van somewhere too, you'll find yourself picking things up here and there.
zwodubber is offline   Reply With Quote
The Following User Says Thank You to zwodubber For This Useful Post:
chewy (12-09-2011)
Old 12-09-2011, 01:26 AM   #13
this is over 2 years, and a lot has been upgraded....
The Following User Says Thank You to mikeh32 For This Useful Post:
chewy (12-09-2011)
Old 12-09-2011, 02:21 AM   #14
Rewards Points: 518
Saves the hands!
crazyboy is offline   Reply With Quote
Old 12-09-2011, 02:25 AM   #15
Rewards Points: 22
This is the contents of my toolbelt and I do pretty much just new construction commercial and some industrial voice and data.
Old 12-09-2011, 01:38 PM   #16
IT/Phone Guy
Rewards Points: 588
I use Klein for my main tools (screwdrivers, strippers, cutters etc), Ideal modular plug crimper, Harris/Fluke for all the specialty stuff. Can't beat their punch tools and butt sets.
jeffmoss26 is offline   Reply With Quote
Old 12-09-2011, 02:02 PM   #17
Rewards Points: 22
These are my handtools that dont live on my pouch.
Old 12-09-2011, 02:42 PM   #18
IT/Phone Guy
Rewards Points: 588
This is my main set of tools...
Old 12-09-2011, 05:06 PM   #19
do you like that whole saw?
I tried the shark one, and loved it!
Old 12-09-2011, 05:16 PM   #20
Electric Al
oldtimer's Avatar
Rewards Points: 2,306
Yes!
I think he likes the whole saw, not just part of it!
Sorry, I couldn't resist.
Steven Wright
The Following User Says Thank You to oldtimer For This Useful Post:
xplod (04-20-2012)
New Tools bduerler Tools, Equipment and New Products 26 05-18-2010 11:06 PM
More cool tools... Gedore tools mikeh32 Tools, Equipment and New Products 3 05-18-2010 07:38 PM
tools powerline Tools, Equipment and New Products 38 12-31-2008 09:43 AM
tools to buy powerline Tools, Equipment and New Products 1 12-21-2008 06:41 PM
Tools paul d. Tools, Equipment and New Products 3 07-21-2008 05:54 AM
