07-08-2012, 11:06 AM
Ty-rap tool that cuts flush??
Does one exist? Every one I've used leaves an 1/8"sticking out that will rip your skin if you run across it. Is there one that really cuts flush without you having to twist it?
07-08-2012, 11:19 AM
Yes, they exist look at some telephone supplier sites. If someone else doesn't directly link.
They are designed for that app. and do cut even closer than dikes. The blade edge starts at the outer edge.
If your even thirsty, your two quarts low.
07-08-2012, 11:26 AM
Who you gonna call?
Twist the ends off with your lineman pliers. Nothing left out of the end to rip your skin or damage wires. Also it's cheaper than buying another tool to carry around.
The Following 6 Users Say Thank You to union347sparky For This Useful Post:
07-08-2012, 11:35 AM
That only works if it doesn't matter how tight the cable tie is. I don't mind the extra tool.
07-08-2012, 12:18 PM
Use a razor knife. It's not quick though.
07-08-2012, 12:24 PM
Bucket Head
I'm not even cool online.
07-08-2012, 01:19 PM
it works at any tightness, just grab it and turn until it breaks off. If you want it really tight, pull as you turn your linesmens
The Following 3 Users Say Thank You to 360max For This Useful Post:
07-08-2012, 09:30 PM
Twisting off with your side cutters works for me too.
07-08-2012, 09:47 PM
I haven't figured that sidecutter twisting thing. It always leaves a twisted sharp piece sticking out.
Does it depend on what kind of ty rap it is? I noticed some are more brittle than others.
07-08-2012, 10:41 PM
Former sparky
And when you slip and rip your other arm open your helper can drive you to the hospital for stiches. Wrong tool for the job and looking for a problem.
07-08-2012, 11:51 PM
Spaghetti Cleaner
Flush cut nippers are what your looking for.
Otherwise cut them sideways on the diagonal. IE put one edge of the blade on the thin portion of the blade sticking up. Put the other edge of the blade on the head and cut the tie across the head.
Dykes or nippers may not be as easy to use as scissors.
Thread shorter.
07-09-2012, 12:11 AM
07-09-2012, 12:53 AM
GRAND PUBAH M0DERATOR
Just use regular dykes but there is a technique, you have to get the angle of your dangle correct and hold your tongue in the right spot then scrap one side of your dykes over the top while one stays lower down. It gets easier as the cable ties get bigger but wont work with channellock tools as they have a knife and anvil design rather than knife vs knife.
The Following 2 Users Say Thank You to chewy For This Useful Post:
07-09-2012, 01:01 AM
Seen that a few times or one dude slipped and slashed a loom we had just dressed in and had to re pull 7 outlets.
07-09-2012, 01:10 AM
I dont know if Id like to do that too many times in a row. When I was just starting out I could spend an entire day tying cables. Climb ladder, cable tie, cut, cable tie, cut, cable tie, cut, cable tie, cut, cable tie, cut. Move ladder, climb ladder, cable tie, cut, cable tie, cut, cable tie, cut, cable tie, cut, cable tie, cut, move ladder, climb ladder, etc etc.
07-09-2012, 02:38 AM
This is what I use all the time. It leaves an absolutely flush cut and has different torque settings on it. I never leave home without it!
http://www.tnb.com/ps/fulltilt/index.cgi?part=ERG50
07-09-2012, 08:49 AM
#18
Bandwidth Conservator
I use side cutters and watch where I'm sticking my hands.
07-09-2012, 07:51 PM
#19
Yes you can twist your side cutters around a little as shown in the picture above, but lately I have found using knipex cobra pliers works really good to twist off the tails.
I hate people who leave sharp cut off tails on ty-raps, it sucks when you are 40ft up in the cable tray and getting stabbed by all the sharp ends, cause some dumb ass was lazy and just cut them with sidecutters.
07-10-2012, 12:31 AM
#20
No tie raps allowed in the TELCO central offices. Everything gets lashed down with waxed string. This avoids the nasty sharp tails and cuts.
