Old 06-04-2012, 11:18 AM   #21
Former sparky
Originally Posted by Peter D View Post
I guess you haven't mastered the use of a utility knife.
Sure I have, betcha I could dissect a body with one.
Old 06-04-2012, 11:20 AM   #22
Licensed Journeyman
nolabama's Avatar
Originally Posted by cable_guy
Anyone out there that uses a splicers knife by choice for anything? I could see it being handy from a datacom perspective since I could carry that, snips, and a punch down tool and be good for most cabling purposes instead if carrying snips, punchdown tool, ring cutter, and then a utility knife yet on top of that. Seems more streamlined and simple( in theory at least).
I have used that knife before and found it not very useful and did not keep an edge long.
Old 06-04-2012, 02:04 PM   #23
cable_guy's Avatar
Well thanks for all the comments guys! I will probably get myself a cable splicers kit here pretty soon then.
cable_guy is offline   Reply With Quote
Old 06-04-2012, 06:26 PM   #24
cable_guy's Avatar
Originally Posted by Ty Wrapp
I used a cable knife & splicers scissors (snips) my whole career. I could strip any cable, from quad IW to a 900 pr . No need for those specialized strippers. Plus, the blunt nose on the cable knife is good for scraping stickers off of terminals and the handle erases Sharpie marks.
Great tips by the way about non conventional uses for the splicers knife. That's the type of info I like to hear about. How the experienced folks do things out in the field.
Old 06-04-2012, 06:56 PM   #25
cdnelectrician's Avatar
After working in the telecom side of things I got used to that knife and it's all I use for any size of wire or cable. I don't trust utility knives with a thin blade, too many close calls with blades snapping. Plus the sheepsfoot blade works great for slitting cable sheath especially tek cable, making it possible to push the blade away from you without damaging the conductors. You won't be sorry with your purchase!
Old 06-04-2012, 06:58 PM   #26
Yea, the way Klein bevels the edge on those knives make them a pain to sharpen...nothing a good stone can't fix though...
Old 06-04-2012, 07:01 PM   #27
jza
My knife of my choice, it's great.
jza is offline   Reply With Quote
Old 06-04-2012, 09:22 PM   #28
a cable splicers knife is used for exactly what it is called, splicing cables over 600v, if you have ever spliced cable with a semi-conductor that knife can't be beat. A high voltage inspector would shot you then shot you again if he seen you using a razor blade (utility knife), you nick that semi-conductor and you cause all sorts of problems, they also are great for loomex or nomex or nmd90 or what ever that craps called you pull into wood studs.
jontar is offline   Reply With Quote
Old 06-04-2012, 10:30 PM   #29
Heavily Armed Member
HARRY304E's Avatar
Works great for everything....
Old 06-04-2012, 11:08 PM   #30
I've had one for years, I really only use it for re-splicing over head services , other than that, Im way too accustomed to my SOG pocket knife, feel naked without it.
GEORGE D is online now   Reply With Quote
Old 06-08-2012, 03:10 PM   #31
I work for a cable company, mostly doing commercial install work. Have one of the knife/scissor combos that you see on the belt of every telephone guy. For the RG-6 and other soft cables the specialized strippers are worlds better, but for CAT3/5 it's solid and convenient, and for stripping hardlines like QR715 and such it's pretty much the best thing around. Disposable utility blades really don't compare, you can break one or two per day on feeder and trunk coax splicing. You don't want the blade to break and separate you from the tip of a finger.
Honestly it's a useful knife for the few ounces it adds to your belt. Solid, nice weight, comfortable full-tang handle, and very sharp without being the kind of thing that causes accidents.
phillyphandom is offline   Reply With Quote
Old 06-08-2012, 03:22 PM   #32
cable_guy's Avatar
Yeah it sounds like from what everyone is saying its definitely worth having, now to wait until I get some other things I need more...
The Following User Says Thank You to cable_guy For This Useful Post:
HARRY304E (06-08-2012)
Old 06-08-2012, 10:23 PM   #33
who u work for ? me iam with rcn
jaym812 is offline   Reply With Quote
Old 06-08-2012, 10:26 PM   #34
i use it sometimes to remove the jacket off flooded .625 hardline or removing heat shrink i wont use it on fiber cables
Old 06-08-2012, 11:11 PM   #35
IT/Phone Guy
Jay, is that you? From cabletechs?!
jeffmoss26 is offline   Reply With Quote
Old 06-08-2012, 11:21 PM   #36
yes it is
Old 06-08-2012, 11:59 PM   #37
I'm curious why you won't use it on fiber? I only cut in to fiber with my splicers knife.
Dawizman is offline   Reply With Quote
Old 06-10-2012, 01:47 PM   #38
I'm with Comcast. Western Philly suburbs. I think we have an RCN system a few counties away but it's smallish so I'm not too familiar.
Old 06-10-2012, 03:27 PM   #39
DGFVT
John's Avatar
How about this? You get a star if you know what it's real purpose is.
Attachment 14501
John is online now   Reply With Quote
Old 06-10-2012, 04:26 PM   #40
IT/Phone Guy
Hacking into old lead sheath cable??
The Following 2 Users Say Thank You to jeffmoss26 For This Useful Post:
John (06-10-2012), Ty Wrapp (06-11-2012)
Cable Knife Safety Ceramic Workplace Safety 22 05-13-2012 12:47 PM
For Sale: Sumitomo Electric Type 25 splicer and other items Ronald11 Electrician Swap 0 04-13-2012 01:04 PM
Utility knife Current Tools, Equipment and New Products 64 07-17-2011 09:02 PM
Knife sharpener itsunclebill Tools, Equipment and New Products 22 10-01-2010 10:08 PM
Buck Knife gold Off Topic 15 09-12-2010 08:36 AM
