Old 11-03-2009, 10:06 AM   #1
Lucky to be Alive
Default Using Clamp Meters
I just bought a new Ideal 600A clamp meter. My old 400A meter died recently. But, now I have a question.
With my old meter, if I was measuring a 600A service that was supplied by two 350 MCM's, I would measure the current on each 350, then add them together. Now, this new meter should be able to measure the full 600A by measuring both 350's together. I have tried this, and it appears to work fine.
But, the owners manual says I should only measure 1 wire at a time. Does anyone else measure 2 wires at a time with these clamps? Or, should I stick to 1 wire like the manual says, and add them together like I did with my 400A meter?
Voltage Hazard is offline   Reply With Quote
Old 11-03-2009, 08:24 PM   #2
My guess is that they meant:
Don't measure the HOT and NEUTRAL together.
Don't measure the HOT (A) and HOT (B) together.
Speedskater is offline   Reply With Quote
Old 11-03-2009, 08:50 PM   #3
Robotic Rat
nolabama's Avatar
i have a 600 amp fluke clamp meter and i will measure what will fit in the clamp
why would i want to measure two wires of the same phase seperatly and add that up when my meter would do it?
the more i learn the less i know
Old 11-03-2009, 10:09 PM   #4
Hazardous,
You can measure as many wires together as you want, as long as they are the same phase. So, 2 350's acting as one feeder, is a perfect application. You said it worked okay, and this is why.
My guess is Ideal does not want to educate people, and that is why they say "only measure 1 wire". They don't want to say you can measure more than one, then have people try to measure a hot, and neutral together. They get fewer trouble calls if they tell you to measure only 1.
Bruce Wayne is offline   Reply With Quote
Old 11-03-2009, 11:33 PM   #5
Parallel conductors are "one wire".
Old 11-04-2009, 12:20 AM   #6
sparks134's Avatar
one phase!
sparks134 is offline   Reply With Quote
Old 11-04-2009, 12:47 AM   #7
Originally Posted by sparks134 View Post
one phase!
Not sure how they are different, other than the fact that the ground and neutral can be paralleled too.
Old 11-04-2009, 10:52 PM   #8
sparks134's Avatar
more than one wire!!!
What clamp meters do you recommend? nratom45-70 Tools, Equipment and New Products 14 07-21-2009 12:52 PM
1 riser 2 meters NolaTigaBait NEC Code Forum 30 06-27-2009 10:25 AM
Recall of fluke clamp meters nick General Electrical Discussion 11 05-21-2009 10:58 PM
Meters Littlejim82 Tools, Equipment and New Products 12 09-22-2008 07:14 PM
dc meters frank Vintage Electrical 0 04-11-2007 05:53 PM
