Old 03-02-2009, 04:14 PM   #1
Default Welding in the field
Anyone occasionally have to do any type of welding or torch cutting in the field?
If so, what kind of equipment do you have or like to use?
These days my equipment definitely spends more time gathering dust than anything else, which makes it hard to stay sharp with the welding skills.
I have one of those little Gentec portable oxy/ace torch outfits that has really come in handy at times along with a small Hobart 140 MIG unit that I bought to make repairs on stainless hoods and other kitchen equipment. Mostly tack or stitch welds.
I rarely use solid wire and shielding gas with it though, mostly just flux core, even for stainless now. The stainless flux core wire is expensive and sometimes hard to find in small spools. It also leaves the usual flux core spatter too, but as long as the weld is hidden... no big deal.
Old 03-02-2009, 05:52 PM   #2
pipe bender
azsly1's Avatar
my company has 3 miller bobcats. i think the 225's but i'm not sure. regular stick welding... we use them to assemble hangers, brackets, stands, bracing, things of the such.
azsly1 is offline   Reply With Quote
Old 03-02-2009, 05:59 PM   #3
"A" inside wireman
randomkiller's Avatar
We have an assortment of the stuff in the crib as we have a whole other half of the company full of fitters, etc. I often have a small oxy-ace kit on the truck for cutting and a small Snap-on mig for brackets and that type of thing.
"One Nation Under God"
Old 03-02-2009, 06:21 PM   #4
I have a Lincoln buzz box, and it's perfect for all the more I ever need it. Mostly for making a bracket or transformer shelf in the field. Saves from needing to buy so many weird Kindorf fittings. I can cut with it too, with a stout rod and wing the current all the way up. Anything precise or multiples of something and I hire a welder or take a napkin drawing to a welding shop.
Old 03-02-2009, 06:52 PM   #5
Motor Repair&Control Shop
electro916's Avatar
I have a Lincoln Electric Pro-core 100, a little 120v flux core welder. Mainly gets used for transformer brackets and welding plate to I-beams, was around $400 but works great for what electricians need it for.
When somethings broke, I wanna put a bit of fixin on it
electro916 is offline   Reply With Quote
welding certificate duff7830 Union Topics 23 08-14-2009 01:05 PM
Welding Bays davidparry1 Off Topic 2 02-03-2009 12:50 AM
480v welding recept's. NorthDakota_PM General Electrical Discussion 5 09-09-2008 06:57 PM
new tool cald welding stuff nick Tools, Equipment and New Products 15 08-28-2008 04:47 AM
Exothermic Welding Joe Tedesco NEC Code Forum 16 12-13-2007 04:33 PM
