12-01-2008, 04:42 PM
What to use when stripping romex?
Hey guys,
Just woundering what you all use when you strip the outter jacket of romex wiring, Im starting my apprenticeship soon and i was gonna buy a hook knife but my dad told me some bad stories about him and a hook knife, so i am looking for another tool to use. Any suggestions are greatly appreciated.
Thanks,
Gents
12-01-2008, 04:51 PM
Seen your member
12-01-2008, 04:52 PM
Is there anything that does all different types of cable? other then a knife?
12-01-2008, 04:54 PM
Seen your member
They're designed to cut through just the sheath and not the insulation on the wires inside. Some only do one size (14/2 or 12/2), some do both. I think one model does 10/2.
The bottom photo is one that does both 12 and 14. That will do 98% of the stripping needed in resi wiring.
12-01-2008, 05:44 PM
i like to use one of these  you can also use your lineman pliers or a razor knife. a razor knife is easier to mess up with
12-01-2008, 07:26 PM
Unlimited Lic.Electrician
Yes sir, I love my hawkbill.
12-01-2008, 08:13 PM
old schoolers  . I use whatever is nearby. Don't do much romex.
12-01-2008, 08:18 PM
I don't do that much romex either, but my hawkbill will tear up some 500 and 600 mcm. oops I called it MCM and not KCMIL.
12-01-2008, 08:26 PM
i use mine like that too. usually before i start stripping stuff like that i sharpen it for a few minutes and go to work
12-01-2008, 08:29 PM
That bottom one from Klein is EXACTLY the one you want. Very ergonomic!
You can strip 10ga solid with the 14-2 hole too!
I use the 14-2 hole to strip everything up to a 4 ga. Practice makes perfect!
12-03-2008, 02:48 PM
Try the T&B s-stripper #s18-223 or 18-223, strips 14 & 12 on one side and 10 on the other. I have been using the s type for years.
12-05-2008, 03:15 PM
Wish I was in the water
I also use the Klien in the bottom picture and love it. Nice clean, professional strip. Actually had an inspector ask how I got the straight edge on romex, I showed him and he liked them also.
If you're gonna be stupid, you better be tough.
12-05-2008, 04:28 PM
Licensed Journeyman
do not use your linesman pliers, 9's, kliens or whatever they are called were your at - i have heard and do not know the validity of this but i have heard that if you use your kliens they can mess up arc fault breakers
12-05-2008, 11:25 PM
Romex Strippers
I like the Ideal #45-621 model. The latch on the Klein gets in the way, bumps into the locked position. The Ideal locks and fits into J boxes better.
12-06-2008, 01:09 AM
3rd Generation
I think more accurately Klein's can mess up romex
12-06-2008, 07:55 AM
semi-electrician
It's very rare that our company uses romex, the last job I was on that the guys were using it they had a small yellow tool from Ideal that you slide on the cable and it slits the jacket, it has a blade to cut the jacket and a built in stripper. Found it...
Lil' Ripper Stripper™
Catalog # 45-025
Features
- Rips ROMEX® outer jacket cleanly and quickly.
- Clips outer sheathing to remove excess ROMEX® jacket.
- Strips inner conduit wires.
- Looping holes loop wire for screw-on connections.
- Twist-Assist™ tightens most popular sizes of winged twist-on wire connectors.
- Injection molded elastomer grip provides a comfortable, slip resistant grip.
- Strip length measuring scale allows for quick and easy measurements.
- Conveniently fits in your pocket.
Product Resources
- ROMEX® is a registered trademark of Southwire Company
12-06-2008, 12:33 PM
the worst romex strippers are those cheap stamped metal ones. i bought an electricians tool kit from greenlee and it came with one. i threw it away still in the package. i hate those things
using that sheepfoot knife ill never go back to anything else. razorblades work pretty well but i find its easier to mess up romex with.
i had a set of those klein romex strippers and i ended up giving them to my helper who lost his pair
12-06-2008, 10:32 PM
#19
"A" inside wireman
Caulk one up for the old timer with the hawkbill.
"One Nation Under God"
12-08-2008, 10:04 PM
#20
ive got one of the kline 12-2 14-2. i dont even know if they will open anymore, in the rare event that we get a romex job i normally dont have to do it.
imo romex is good for tieing down ladders and temping lights
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Stripping Romex reqs.
subelect |
NEC Code Forum |
14 |
07-16-2008 07:05 AM |
Mc Or Romex Or Bx
Nitro9119 |
3 |
05-19-2008 08:48 PM |
romex/conduit
2leggedogwbrassballs |
44 |
02-17-2008 02:36 PM |
romex on edge
JohnJ0906 |
Code Violation Discussion |
7 |
05-04-2007 04:41 PM |
Romex Where Not To Use
BILL |
3 |
03-11-2007 09:53 AM |
