Old 02-15-2009, 01:48 PM   #1
Default Worst Screw drivers.
Husky tips bend easily.
Kliens with Carbide tip, the tip snaps off.
OTHERS?
Old 02-15-2009, 02:13 PM   #2
electricalperson's Avatar
screwdrivers made by evolv. you can get them at sears my helper broke the tip off trying to twist a KO out of a recess light
Old 02-15-2009, 03:32 PM   #3
seo
OTHERS?
You must be a lot stronger than I am I've had good luck with the Kliens.
seo is offline   Reply With Quote
Old 02-15-2009, 03:40 PM   #4
europamo's Avatar
I usually buy craftsman screwdrivers now, they seem to take a beating and if they do not, I just return it. But this Klein rapi drive sucks. its a waste of effort.
europamo is offline   Reply With Quote
Old 02-15-2009, 03:50 PM   #5
semi-electrician
I am sure there are 1000 guys that would disagree with you on that one, you need to be smarter than the tools your using.
Old 02-15-2009, 03:53 PM   #6
village idiot
piette's Avatar
X2. I love my Rapi drives. It took a bit of getting used to about 15 years ago, but have never had a problem since. Nearly every electrician I have ever worked with uses them and loves them.
Jeff
piette is offline   Reply With Quote
Old 02-15-2009, 03:58 PM   #7
semi-electrician
Jeff
Never cracked a device with one of tore up a wall from slippage like I so many guys do with drills.
Old 02-15-2009, 05:23 PM   #8
JohnJ0906's Avatar
Jeff
X3. I love 'em.
John from Baltimore
"One day at a Time"
Old 02-15-2009, 05:48 PM   #9
Originally Posted by JohnJ0906 View Post
X3. I love 'em.
X4. Been using them for 20 years and loving 'em!
Old 02-15-2009, 06:30 PM   #10
Sparky
X5 Love to use them when I can
-Jay
headrec is offline   Reply With Quote
Old 02-15-2009, 06:33 PM   #11
Seen your member
X6. Once you learn how to use them, they're great.
Most people don't apply enough pressure when using them to install a device, too much when installing the cover, or mistakenly believe the tool does all their thinking for them.
To anything!
Old 02-15-2009, 06:51 PM   #12
europamo's Avatar
i think your misunderstanding me, I just do not like the klein one.
Old 02-15-2009, 09:38 PM   #13
B4T Scotchkote installer
Black4Truck's Avatar
I only use Sears Craftsman.. I always bend the tip trying to unlock a frozen screw on a neutral bar or a rusted MP lug. They give you new ones for free without asking questions. I trade mine in at least 2 times a year from wear and tear.
Old 02-15-2009, 10:47 PM   #14
When I did a lot od S&P I loved mine.
Old 02-15-2009, 11:54 PM   #15
EURO who else makes a similar product?
Old 02-16-2009, 01:42 AM   #16
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
Pretty sure I have seen a craftsman bent screwdriver as well. I have the phillips as well as the straight klein ones though.
~Matt
Old 02-16-2009, 01:43 AM   #17
Burger Flipper
TOOL_5150's Avatar
OTHERS?
Screwdrivers arent prybars.
~Matt
Old 02-16-2009, 01:43 AM   #18
Burger Flipper
TOOL_5150's Avatar
Oh and husky AND kobalt [the 2 big box brands] are both garbage quality.
~Matt
Old 02-16-2009, 07:44 PM   #19
JohnJ0906's Avatar
~Matt
WHAT?!?
John from Baltimore
"One day at a Time"
Old 02-16-2009, 08:31 PM   #20
europamo's Avatar
Greenlee is what I have, but just about all of them do. problem with the klein one i had is the crank action sucks, maybe its a defect who knows
Klein Nut drivers Gents Tools, Equipment and New Products 32 02-07-2009 08:47 PM
ideal screw drivers nolabama Tools, Equipment and New Products 15 01-17-2009 04:20 PM
Adding ground screw n0c7 NEC Code Forum 33 10-21-2008 08:58 PM
blown up screw driver dadadan Tools, Equipment and New Products 19 04-24-2008 07:34 AM
The Handyman.....an electrician's worst..... Nosparxsse General Electrical Discussion 12 08-14-2007 08:33 PM
