Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Business, Marketing, and Sales
Old 10-21-2008, 12:55 PM   #1
Zata40's Avatar
Default Cans$$
What r some of U charging to install a Can all parts and Labor?
Here in the Lansing area they R low balling @ $65 total.
"And then there was Light"
Zata40 is offline   Reply With Quote
Old 10-21-2008, 01:13 PM   #2
New work 75 Old work 150 Old work in plaster and lathe 175. + 25 for a switch 0r 50 with a dimmer.
Marco Electric is offline   Reply With Quote
Old 10-21-2008, 05:18 PM   #3
New work 6" with standard white baffle $108 - $125
Old work same as above about $125 - $150 depending on situation
Switch / dimmer extra depends on what kind of dimmer so on.
Slider is offline   Reply With Quote
Old 10-21-2008, 05:33 PM   #4
Does that $65 include the trim and everything?
fungku is offline   Reply With Quote
Old 10-21-2008, 09:38 PM   #5
Extras for Heartland Homes here $150 per light,complete.
bobelectric is online now   Reply With Quote
Old 10-21-2008, 11:28 PM   #6
Zata40's Avatar
Yes...
Old 10-22-2008, 12:20 AM   #7
Wow, that's like wholesale price and free labour! haha
Some people out there are doing community service...
Old 10-22-2008, 04:52 AM   #8
Mountain Electrician's Avatar
New work, @75 with no trim. (Includes labor to install trim) Customer then picks out their own style.
Old work, situation dependent. Easy attic access, power nearby, single gang cut-in w/dimmer, @225
Old 10-22-2008, 08:31 PM   #9
caseyelectric's Avatar
I usually stick around the 100-125 mark. I recently did some slope cans, the can housing was 45, the trim the HO picked out was another 40. Needless to say these cost a little more.
caseyelectric is offline   Reply With Quote
Old 10-22-2008, 09:19 PM   #10
Cheetah Speed System
electrician1957's Avatar
Can: $6.50
Lamp: $2
Romex: $2.50
Trim: $1.75
Misc: 1.75
The look on your face when I underbid you: Priceless.
electrician1957 is offline   Reply With Quote
Old 10-22-2008, 11:43 PM   #11
Bkessler's Avatar
Originally Posted by electrician1957 View Post
Can: $6.50
Lamp: $2
Romex: $2.50
Trim: $1.75
Misc: 1.75
making twice the money at half the work, even more priceless.
When ls lunch?
Old 10-23-2008, 05:13 AM   #12
Depends on who you've got to bid against, right?
It's easy to say "I wouldn't do it for that price!", but if that's what it takes to get the work in your market, then you've to to find a way to do it and make money or stay home.
Old 10-23-2008, 08:42 AM   #13
^^^ Quite true. A lot of you high rollers would not make it in a competitive market like Los Angeles. Nobody lowers their prices because they want to, it's always in response to market forces.
Old 10-23-2008, 10:05 AM   #14
Bkessler's Avatar
I am in OC, I have lowered my prices on cans, I used to be 125 minimum for 6" but now am floating between95 and 125 depending on situation. Your right 1957 about it being very competitive, I try and convey the advantage of having someone with 15 years experience, insurance and workman's comp do it for a little more but some folks just care about the bottom line, oh well can't blame em.
When ls lunch?
Old 10-23-2008, 01:26 PM   #15
I dont know where he is buying his materials, but i know i cant get materials that cheap at any supply house. I dont even think bulk has anything to do with that.
Old 10-23-2008, 04:46 PM   #16
At Home Depot you get 6 new work Halo cans with white baffle for $60,12 lamps for $36. Say 250' nmc @$46.1 plastic box .25. 1 dimmer $10 18 wire nuts.01ea. 1 15 amp breaker $4, 6 cans complete=$138.43 in material. Cost to customer $450. Profit $311.57. Approx labor 4 hours( drive ,install,clean up)= $77.90 per hour, I'll take it.
Old 10-23-2008, 05:05 PM   #17
I'll skip the breaker and charge $446
Old 10-23-2008, 06:04 PM   #18
Bababoee
captkirk's Avatar
65 thats hardly worth doing. I charge anywhere from 125-210 depending on type of can, type of house, and pita level. You have to figure that the material for a basic 6" can is 20 bucks a can. I charge seperatly for a new switch. Sometimes there is an already existing s/L you can use, like a center light that is being removed, in this case I wouldnt charge for a swich.
Old 10-23-2008, 06:15 PM   #19
I bet you backstab too!
Water and women are in short supply! There's not enough dope for us all to get high! Jimmy Buffett!
jbfan is offline   Reply With Quote
Old 10-23-2008, 06:25 PM   #20
By 'stabbing and using Cheetah devices I trim out at over 50 devices per hour. The screws on the sides of devices are for lesser electricians who lack the dexterity to stab.
Why we use IC rated cans Joefixit2 General Electrical Discussion 1 11-10-2008 10:24 PM
Airtite Cans crk1a General Electrical Discussion 0 08-26-2008 07:56 PM
Thermals in cans!!!!! Nosparxsse General Electrical Discussion 6 10-29-2007 12:03 AM
Junk recessed cans. MDShunk Lighting Design 21 09-29-2007 08:51 PM
temperature ratings of cans MDShunk Lighting Design 2 08-15-2007 05:13 PM
