Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrical Forum > Business, Marketing, and Sales
Old 09-12-2009, 03:03 PM   #21
Originally Posted by BDB View Post
So you are going to give them free (warranty) labor to come back and fix something from material they bought?!!?
It's a fine line if you don't word it properly. Typically this happens in residential construction. I guarantee what I can. Basically, internal wiring. My wiring will not cause an el cheopo dimmer or can light to fail.
Old 09-12-2009, 03:05 PM   #22
Master RAT!!!
Shado's Avatar
No...thats material warranties. If something goes wrong do to your labor installation...then that would be covered only....
Hmmm....how do you figure fixing something from material they bought would be covered under labor warranty? Just curious...
- Dave ........
"Beware of the Rat....he has no Master...he works how & where he wants...."
Shado is offline   Reply With Quote
Old 09-12-2009, 03:15 PM   #23
lectro88's Avatar
I've seen this more and more. My problem with it is a damn homeowner is not an electrician. Has no idea what to use or how much or what is good or junk. I tend to use commercial material. They have no idea. I will not install a .59 cent receptacle for anything. This is more of what makes my blood boil about our trade. Cheap, Cheap, Cheap. You said com. garage. metal boxes, emt, straps and fittings, give him a list and send em to homeless depot or low life supply. Good luck gettn what you wrote cause the dip$#8T at homeless works in another department and knows nothing about electrical either like the HO. Try this with HVAC. good luck getting freon HO.
I didn't write the books, I just read the books,
And look at the purdy pictures
lectro88 is offline   Reply With Quote
Old 09-12-2009, 05:28 PM   #24
child please.....
NolaTigaBait's Avatar
I will. What's the big deal on residential?
NolaTigaBait is online now   Reply With Quote
Old 09-12-2009, 05:30 PM   #25
He probably doesn't want the warranty responsibility on a 59 cent receptacle, but if it's customer supplied, there's no warranty anyhow.
I like to remain flexible and install whatever material the budget allows for. Not everyone can drive a Cadillac.
Old 09-12-2009, 07:43 PM   #26
Lighting Contractor
Lighting Retro's Avatar
Back when I ran an irrigation company in California I had a customer who wanted to do this. I show up and they don't have the fittings you need, they bought the cheapest Lawn Genie sprinklers they could find, 2", that would not even pop up above the grass, etc. I'm sure the guy was very pleased with himself thinking he could run a main water line with Class 200 pipe thinwall instead of sch 40.
At that point, I decided I would never do it again. Just not worth digging through 25 Home depot bags to see if all the right stuff was there, and having to be held up if it wasn't. Like others have said, if you do, just have a set of clear rules in place so you don't get burned. I'd explain in real plain english why this rarely works, and what they will be charged extra when they don't do their end properly.
Lighting Retro is offline   Reply With Quote
Old 09-12-2009, 08:02 PM   #27
lectro88's Avatar
I install Lev CR15 or CR20 $1.15ea. Well tamperproof now. Marc hit it, install it and call me when you need somehing else. Had several service calls to replace cheap receptacles installed by others. What I call hot spot devices. Sure I got paid to do it, its work. I just don't want to be the guy that installed the problem. I guess part of it is, I'm a commercial and industrial electrician. And I'm trying to save the world.
Old 09-12-2009, 09:09 PM   #28
I agree with the above posts. very risky.
How ever,to combat this:
Meet (on the clock),provide a stock list (on the clock),Then add your material mark up to your labor cost.
These folks don't understand: with your mark up; you are still providing a quality product cheaper than they can purchase it.
Oh well, play the game ,adjust as needed and don't work for free.
I like to send them back to the store for what 'we' need and charge them while I sit in their drive way.
Better still,Just show up to work. If the crap aint there.... Move along.
"I'll be back when you get it". And charge for travel.
1 hour is 1 hour.
Old 09-13-2009, 12:07 AM   #29
Originally Posted by kbsparky View Post
Well, for one thing, I know he does not have the permit. This so-called "garage" is going to be used for commercial purposes, and homeowners can not get their own DIY permit for anything commercial.
There is one thing about this job that I will allow the HO to provide: The trench for the underground conduits between the house and the new building. I don't particularly like trenchwork, and if he wants to dig it, I'll even lend him the shovel. 50 feet is not enough to justify the expense of renting out a trenching machine.
I won't even get to look at the job until Monday, so I'll keep you posted on the progress ....
I never had a homeowner dig a proper trench.
I tell them is needs to be 24" deep (when it realy needs to be 18") and I'm lucky if it's over 12". Not close to straight either.
Tell them once you get there, you're there to work. If anything they did needs correction, they're paying you for it.
heel600 is offline   Reply With Quote
Old 09-13-2009, 12:33 AM   #30
steelersman's Avatar
I disagree. I'd rather rent a trencher at HD for $90 or get an illegal immigrant to do it for cheap. It's money well spent.
Old 09-13-2009, 09:08 AM   #31
el abogado del diablo
i vote we change your username from 'steelersman' to 'button_pushing_man'
oldman is offline   Reply With Quote
Old 09-13-2009, 11:15 AM   #32
I'll take that. I can admit I have a tendency to do that.
Old 09-13-2009, 11:20 AM   #33
Unlimited Lic.Electrician
william1978's Avatar
Or 'Meatspin'
william1978 is online now   Reply With Quote
Old 09-13-2009, 05:14 PM   #34
If the customer supplies material by means of me picking it up on their account, that's great. But I hate to install the crap they already have.
Old 09-13-2009, 06:32 PM   #35
Just make it clear that 1) you only install UL listed items and 2) you cannot warranty anything that you do not purchase through your supplier.
sparkyy1 is offline   Reply With Quote
Old 09-13-2009, 06:41 PM   #36
I believe you're beating a very old drum by stating the obvious.
Old 09-13-2009, 09:38 PM   #37
My favorite is the main lug panel that they removed from the house down the street as the demo crew was tearing it down that they now want installed as part of the service change that they need on their house. I've had this happen more than one time. Somehow this rusty piece of crap is worth about $500 off their bill. I tell them that I install new panels that I provide or get someone else.
excellencee is offline   Reply With Quote
Old 09-13-2009, 09:41 PM   #38
Seen your member
This may be a silly question, but what are you going to do when you get sued for installing customer-supplied equipment and they get shocked, a kid gets electrocuted, or their house burns down?
This message is hidden because Forgery, JackBoot, LawnGuyLandSparky, milehiwire and user 5941 are on your ignore list.
Old 09-13-2009, 09:48 PM   #39
That simply doesn't happen.
Old 09-13-2009, 09:51 PM   #40
Not Peter D
Yeah. Most of the talk about fire and shocks are scare tactics. It sells work I suppose but the reality is that most wiring, even very poorly installed, is safe. There, I said it.
any sites for materials? dnme01 Tools, Equipment and New Products 14 11-02-2008 06:16 PM
CW looking for materials ccast General Electrical Discussion 1 09-27-2007 08:00 PM
