Old house rewire??? - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Business > Business, Marketing, and Sales
Old 02-07-2010, 12:39 PM   #1
william1978's Avatar
Rewards Points: 2,000
Default Old house rewire???
I was asked yesturday about rewiring a 1,000 sq. ft. house with plaster and they are wanting all the old wiring removed and are wanting me to rewire everything. My question is how do you all charge for this type of job? I can beat holes in the plaster where ever I need to is what I was told to get the boxs where I need to and to drill holes as needed. Just some suggestions would be great. Thanks in advance.
Old 02-07-2010, 12:44 PM   #2
I own stock in FotoMat!
Rewards Points: 6,520
In no case would I ever consider giving a fixed price. There's too many variables and possibilities.
Give them a T&M quote, possibly with a Not To Exceed limit. You will work T&M up to that price, and if you're not done, you either walk away or negotiate for more work.
Old 02-07-2010, 12:44 PM   #3
Fried Bologna um um good!
jwjrw's Avatar
The last one I did everything was pulled from crawl...I cut all metal boxes out used smartboxes and left lighting circuit how they were. They didnt want to tear up plaster and I priced it by the hour. There is no telling what you will run into and I would be leary or giving a solid price... Just me
Old 02-07-2010, 12:47 PM   #4
child please.....
NolaTigaBait's Avatar
Rewards Points: 14
That's what I did. Way too many variables. There's probably no insulation in the walls, which should make it easier to do.
Old 02-07-2010, 01:00 PM   #5
chenley's Avatar
Last one I did I came from above for most of the outlets, due to the crawlspace being inaccessible to most parts of the house from HVAC being installed.
House was built with sawmill lumber (actual 2x4's) and they had horizontal pieces running halfway down the wall. Broke two whip bits on that one. Mainly just did the kitchen, laundry, and den since those locations where all on one breaker. Wired those locations up to 08 code.
Have a full renovation in the rear of that house coming up this spring/summer.
Old 02-07-2010, 01:00 PM   #6
The reason there's no insulation is so they could install fire blocks.
Old 02-07-2010, 01:03 PM   #7
jwjrw's Avatar
You mean the perline between studs? And diagional perlines also....
Hate remodels with rock/plaster on the walls !
Old 02-07-2010, 01:06 PM   #8
child please.....
Rewards Points: 14
Most of the house here, the old ones anyways, don't have the fireblocks. They just have a 8 or 10 foot void from the bottom to top. The new houses almost all have the damn fireblocks.
Old 02-07-2010, 01:07 PM   #9
child please.....
Rewards Points: 14
Those are the ones in the corners of the house. After Katrina, I really got to see how alot of houses were constructed.
Old 02-07-2010, 01:09 PM   #10
In all my years, I have never wired a new house with fireblocks. The only time I encounter them is in remodel work on older homes.
Old 02-07-2010, 01:11 PM   #11
jwjrw's Avatar
Me too! But I wouldnt put it past the nail bangers!
Old 02-07-2010, 01:11 PM   #12
child please.....
Rewards Points: 14
Really?....Crazy how different parts of the country do different things. Every new house here has them.
Old 02-07-2010, 01:17 PM   #13
Lucky for me the house has a 1/2 to 3/4 basement in it and the rest has a crawl space of about 4'.
Old 02-07-2010, 01:18 PM   #14
Maybe you have a local building code that requires them.
Maybe all your framers are stuck in the past..... doing things 'the old-fashioned way' and never thinking beyond that.
Point: Julia Child had a guest on her show on time, explaining how she cooked a Thanksgiving turkey. Just prior to putting the bird in the pan, she (the guest cook) took a knife and cut a chunk off the turkey. Julia asked why she did that, and she explained that's the way her mother always did it.
Well, it just so happened that her mother was in the audience, so during a commercial break, they asked her (the mother) why she did that. Her response: "It's something I learned from my mother. I don't know why she did it, but she always did."
So the two women, curious as to why Grandma would automatically cut a hunk of turkey off before putting in the pan, went to the nursing home to ask her.
She expained, "Well, when Frank and I got married back in 1935, we got a roasting pan as a wedding gift. Problem was, it wasn't big enough for the turkeys we raised, so I always had to cut a peice off to fit it into the pan."
Maybe framers in your area are related to these women.
chicken steve (09-18-2012)
Old 02-07-2010, 01:19 PM   #15
child please.....
Rewards Points: 14
My guess is the local code.
The Following User Says Thank You to NolaTigaBait For This Useful Post:
BBQ (09-18-2012)
Old 02-07-2010, 01:36 PM   #16
Murphy's Avatar
Rewards Points: 254
Send a message via AIM to Murphy
not insulation is good but you still never know what u will run into in these old walls. plaster and lath fall inside the wall and makes it impossible to fish sometimes. but considering they understand holes must be cut, dont kill yourself cut as many needed to get it done, if they dont like the idea of time and material charge a fairly high price.
Murphy is offline   Reply With Quote
Old 02-07-2010, 01:37 PM   #17
Chairman of the Bored
BuzzKill's Avatar
Rewards Points: 2,536
how about attic space?
the ones with floor slates for walking make for more labor of course...
If t/m is a no go for them, take some time and study the place, top to bottom and give a price per outlet/switch.
Old 02-07-2010, 02:11 PM   #18
Can't Remember
Rewards Points: 1,170
I did a dining room this week. 1890's house. No damage to walls, the ceiling was gone from a water leak. Two circuits, 5 receptacles, two three way switches, fan box overhead. All knob and tube removed, hacked nm to kt repaired, and a couple of small repairs = $1000.00 Probably closer to 1200.00, but they are good repeat customers and thats what I estimated. Lots of mess, Mike Rowe/Dirty Jobs crawlspace. Metal old works cut in and attached to the lathe and plaster.
Old 02-07-2010, 02:21 PM   #19
I haven't been in there yet. All of this is what I have been told by creditable sorce. Going to have to go and check it out real good like you say.
Old 02-07-2010, 02:40 PM   #20
Wyome
Rewards Points: 846
Those diagonal fire blocks or sway bracing are just the pits. I am rewiring my parents' house, and it has them. Every 3-6 months I load up and drive over there to do a little more.
New name for Rewire? Bob Badger Off Topic (Non Trade) 5 11-22-2009 07:51 AM
110 year old house rewire what would you charge? pawirenut General Electrical Discussion 31 04-16-2009 05:01 AM
Rewire fun randomkiller General Electrical Discussion 2 12-22-2007 07:19 PM
