I have 5 Westinghouse Panels that desperately need new breakers the panels are before 1950 and are in the block wall so I finally got someone from a supply house to send a man out to custom fit all 5 panels new guts,new breakers new panel cover four 100 amp 20 circuit panels and one 30 circuit panel.Between me changing the old guts and installing the new and making sure everything fits right and labeling it do you guys think $500.00 a panel my labor cost is too much or not enough how much do you think I should charge per panel.:confused1:
As far as the wire bending radius these panels are main lug and they are fed with #8 wire even though the panel is rated for 125 amps there isn't much wire bending lol but I did bring it up to him and he said it was not an issue
Gah, we had to do this about 10 months ago in a school we remodeled. Similar situ - panels in block walls they wanted us to "retrofit" with new kits that fit the old cans. I was shocked at the cost ($3,500 each, as I recall). I talked to the guy who did the change out and the labor I had into it (about 8 hours per panel) was about right, on average. Several were easier than others, but all in all, it panned out. Still, wouldn't want to do it again.
One option we considered for future situations was to just rent a concrete saw and cut in a new panel. And frankly, it would've worked in this application too, but we didn't think about it until after we'd done a couple
Wow $3,500 8 hours? all the guts are supposed to be close because they are measured maybe a little tweeking but I can't see 8 hours a panel I would go nuts lol and when you say cutting into the wall you would have to cut the box out of the wall and trying to get the pipes just right that to me would be a pain in the ass but thanks for the info
Related Threads
Electrician Talk
2.3M posts
93.3K members
Since 2007
