Quoteing on new construction home - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Business > Business, Marketing, and Sales
Old 11-20-2013, 09:41 AM   #1
Built2ride's Avatar
Default Quoteing on new construction home
I'm going to be quoting on a brand new home 2300sqft. 87 insulated pots and minimum code plugs and switches ect.
I can account for material no problem based on the professionally done drawing. But accounting for labour I'm worried I may overshoot it.
I'm wondering if you guys have any tips to accurately quote your labour based on your experience. I don't believe in pricing per square foot.
Maybe I'm asking a non answerable question. I'll post what I come up with and I'll post the e1 drawing see what u guys think.
Built2ride is offline   Reply With Quote
Old 11-20-2013, 09:44 AM   #2
B4T
Scotchkote Installer
B4T's Avatar
Rewards Points: 15,378
There are plenty of pricing threads here to read.. most say using sq. ft. pricing is a bad idea... IT IS...
Old 11-20-2013, 09:46 AM   #3
This is one of those times where it really helps to use other people's numbers (time per outlet, not price) to help you formulate your own. After you do enough of these jobs you will be able to tweak those numbers based off your own past work.
DIYer4Life is offline   Reply With Quote
Old 11-20-2013, 09:51 AM   #4
Small Potatoes
flyboy's Avatar
Rewards Points: 398
I have a sure proof, time saving way to quote new construction. It'll take less then 2 minutes.
Simply tell the builder/developer to get all his quotes and send you the cheapest one.
Then ask him how much less you need to do it for to get the job.
Old 11-20-2013, 10:18 AM   #5
IMO, you are doing just that. Your are only giving us the basics, without the much needed devil in the details.
You can't sq/ft this...don't even try....
Sq/ft pricing is based on doing the exact same thing 100-1500 times, over and over again. It's usually used in large developments. The same cookie cutter buildings or homes.
It would be eaiser to see the plans....
Dnkldorf is offline   Reply With Quote
Old 11-20-2013, 11:22 AM   #6
Rewards Points: 514
If you know the material, get a labor unit book and labor each item...
Then if you get the job, analyze how accurate you are
cdslotz is offline   Reply With Quote
Old 11-20-2013, 11:36 AM   #7
Rewards Points: 340
Remember that thread some apprentice made asking how long it should take to install something like 6 pot lights?
The answers on here ranged from 30minutes to 3 hours.
FrunkSlammer is offline   Reply With Quote
Old 11-20-2013, 12:16 PM   #8
daveEM's Avatar
Rewards Points: 816
Yeah, an hour a pot light for me.
Edit: Of course 87 in 2300 sq ft they are probably 6 inches apart. I may have to re-think this...
They say if opportunity isn't knocking,
...Build a door.
I like perfect.
daveEM is online now   Reply With Quote
Old 11-20-2013, 12:23 PM   #9
Rewards Points: 340
Yeah and half of them are 20' up in the "open conceptness".
Old 11-20-2013, 12:50 PM   #10
gold's Avatar
Rewards Points: 2,048
Send a message via Yahoo to gold
Assuming gas appliances and a 200 amp overhead sevice wired to minimum code @ $5 a sq ft plus 150 per recess.
$24550
Total job cost from the hip for service equipment decent fixtures wire etc and labor (direct expenses not counting overhead) between $8-10k.
I bid 22 since july I got 9 of those I'm about to bid 4 more.
I just started doing new construction again a few months ago mostly semi custom about the same size some a little bigger. Finished 5 since August priced that way and did pretty well That many hihats it would probably take me a week 7 full days) with a helpie to rough a few days to final.
Or do it another way, I find a lot of the guys that say you can't bid by sq ft don't actually do this type of work and some are just full of ****. Another method is by opening that works too.
IMO doing take offs for small semi custom is a waste of time but YMMV
gold is offline   Reply With Quote
Old 11-20-2013, 02:33 PM   #11
RGH
RGH's Avatar
Rewards Points: 2,034
....haven't done one in years....but....it is better to be over and not get it than short and take a pounding....tough market...let us know how you do
I rather be fishing......
RGH is offline   Reply With Quote
Old 11-20-2013, 04:55 PM   #12
NJ-IEC
Magnettica's Avatar
Rewards Points: 424
Originally Posted by flyboy
I have a sure proof, time saving way to quote new construction. It'll take less then 2 minutes. Simply tell the builder/developer to get all his quotes and send you the cheapest one. Then ask him how much less you need to do it for to get the job.
That's usually how it goes too. I bid a giant house an old friend of mines building and was told $38k was almost double the quotes he's been getting. Almost double!! I told him to make sure a doorbell was installed because it wasn't on the plans and to call if he need me for any reason after construction starts.
Replies based on NEC 2014
The Following User Says Thank You to Magnettica For This Useful Post:
flyboy (11-20-2013)
Old 11-23-2013, 03:16 PM   #13
Bababoee
captkirk's Avatar
Rewards Points: 2,030
Thats how they do it... go per plan and nail them on change orders/add ons. I never get new construction anymore..
Full time Bovine Scatologist.
Old 11-23-2013, 03:30 PM   #14
still in business
sbrn33's Avatar
Rewards Points: 2,792
If this is your only resource you may be in trouble because in our world no one can make money doing new construction or for that matter even working for a general contractor.
My advice is to not listen to "us" and go with what you know is fair and honest.
Old 11-23-2013, 06:46 PM   #15
Going_Commando's Avatar
Rewards Points: 300
Your best post ever.
ICF construction Joefixit2 General Electrical Discussion 13 04-01-2015 08:16 PM
New Construction Bandit1250 Residential Electrical Forum 45 07-11-2013 11:48 AM
New construction bid journeyman777 Residential Electrical Forum 32 03-30-2013 11:30 AM
Construction follies. Wirenuting Off Topic (Non Trade) 1 01-09-2013 12:29 AM
Home Depot and the Home improvement Hack B4T General Electrical Discussion 180 12-31-2009 04:03 PM
