Go Back   Electrician Talk - Professional Electrical Contractors Forum > Community > Off Topic
Old 08-29-2009, 12:10 AM   #1
Default Anyone strip paint off doors?
I have about 10 doors I need to strip, there's about 5 coats of paint and a coat of Poly. Did one tonight with stuff that I picked up at a hardware store and it took 4 hours and 3 beers shy of an 18 pack what does everyone suggest? There has to be an easier way, If I keep this up im going to need a liver transplant from drinking to much.
Sparky480 is offline   Reply With Quote
Old 08-29-2009, 12:24 AM   #2
Burger Flipper
TOOL_5150's Avatar
Send a message via ICQ to TOOL_5150 Send a message via AIM to TOOL_5150 Send a message via MSN to TOOL_5150 Send a message via Yahoo to TOOL_5150
hahaha
Were you using Jasco paint remover? Its the best. Theres the jel type stuff that you "paint" on and let it sit for like 10 mins then scrape off... i know that works well too.
~Matt
Old 08-29-2009, 12:26 AM   #3
B4T Scotchkote installer
Black4Truck's Avatar
Check the Benjamin Moore website FINISH REMOVER 315
http://www.benjaminmoore.com/bmpsweb..._productsspecs
Old 08-29-2009, 12:30 AM   #4
Yes im using the stuff that you paint on and scrape off. Going to try and break out the pressure washer tomorrow instead of scraping it off going to pressure wash it off
Old 08-29-2009, 12:35 AM   #5
Burger Flipper
TOOL_5150's Avatar
I have heard that works too... you can put stripper on, and pressure wash it off.
~Matt
Old 08-29-2009, 12:37 AM   #6
Default Brace your self!
(I'm gonna' state 'Liberal', 'Organic' and 'patience' in the same post) None of which I observe )
I got this stuff..."Citristrip" @ a box store. I could not believe how well it worked! You must put it on 'liberaly' and let it work..VERY small smell.Easy on the brain & organic (for the most part).
Patience is required...(needs time to work, as with most strippers (paint ).
I've had good luck with it. I bought a bunch in '04 (I dabble with furniture).
But here is an address: WWW.KLEANSTRIP.COM
Old 08-29-2009, 12:49 AM   #7
Burger Flipper
TOOL_5150's Avatar
All the ones I have seen were fast acting.
~Matt
Old 08-29-2009, 01:18 AM   #8
~Matt
I'll go no further! (You got ripped off)
Old 08-29-2009, 02:06 AM   #9
Site Idiot Smacker
BCSparkyGirl's Avatar
Sounds cray, but try hairspray. That stuff is miracle cleaner. I **** you not. Eats thru latex paint like no ones business.
BCSparkyGirl is online now   Reply With Quote
Old 08-29-2009, 02:12 AM   #10
Burger Flipper
TOOL_5150's Avatar
Hairspray and a match... thatll do it.
~Matt
Old 08-29-2009, 02:20 AM   #11
Site Idiot Smacker
don't even need the match.
Old 08-29-2009, 02:21 AM   #12
Burger Flipper
TOOL_5150's Avatar
You do if you dont want to deal with the doors any more
~Matt
Old 08-29-2009, 02:24 AM   #13
Site Idiot Smacker
true, but I think he still wants top use the door, you silly man!!!
Old 08-29-2009, 02:26 AM   #14
Burger Flipper
TOOL_5150's Avatar
you could set them on fire temporarly, and give them that old rustic look.
~Matt
Old 08-29-2009, 03:53 AM   #15
Hang the doors back on the frame, then later in the night, smash the front door open with a sledge hammer, rummage through the house like a robbery, causing damage to the other doors as you go. Then call the cops and your insurance agent. Get some shiny new doors and maybe even a little pocket money.
Or you can give me a shout and I'll do it: inphase@dirtydeeds.com
Old 08-29-2009, 07:45 AM   #16
steelersman's Avatar
If you pressure wash it off, you are going to allow that toxic stuff to runoff into the environment, whether it be into the storm drain or not, so I would highly recommend any other way than that.
Old 08-29-2009, 08:12 AM   #17
captkirk's Avatar
if your door has a stain on it and you use a chemical remover it will bleed through after you paint it. I think sanding is the way to go. I stripped a door with chemicals that had a mahogany stain on it and to this day I am still adding paint to it to hide the stain underneath it. Ive used klitz and everyother stain killer and it still has managed to bleed through. The pressure washer wont work, your only gonna warp your doors and possibly damage them. Water and doors dont really get along to well. If you use water on them you might as well throw them out.
captkirk is online now   Reply With Quote
Old 08-29-2009, 08:19 AM   #18
klitz?
I think you mean kilz.
Old 08-29-2009, 08:26 AM   #19
oldschool's Avatar
kilz
one L
oldschool is offline   Reply With Quote
Old 08-29-2009, 08:31 AM   #20
Originally Posted by oldschool View Post
kilz
one L
You mean one lowercase l.
I fixed it. Thanks.
Lead Paint and the EPA for electricians. MDShunk Other Codes and Standards 9 01-07-2010 08:03 PM
van doors nolabama Tools, Equipment and New Products 9 07-04-2009 11:25 PM
What's the best way to strip 3/0? Panic AK General Electrical Discussion 49 04-26-2009 09:47 AM
Save your paint! 480sparky Off Topic 3 02-07-2009 05:17 AM
paint paul d. General Electrical Discussion 6 07-20-2008 09:56 PM
