balance load - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Closed Thread
Old 06-22-2010, 05:03 PM   #1
Default balance load
why do loads need to be balanced??? why cant i just use one side of my fuse box. why does it have to be balaced???? cant i just pull of one side. just use one 110 line????inquiring minds....
mrbrenneke is offline
Old 06-22-2010, 05:07 PM   #2
Fried Bologna um um good!
jwjrw's Avatar
Is it a 3 phase system? What kinda loads are in the panel? How many amps? You probably can just use one side of your fuse box for a 120v load.....
jwjrw is offline
Old 06-22-2010, 05:22 PM   #3
I own stock in FotoMat!
Rewards Points: 6,520
You can stress the one side of the transformer.
480sparky is offline
Old 06-22-2010, 08:20 PM   #4
Rewards Points: 596
Voltage drop will be a far greater issue if the loads are not balanced.
Often the neutral is smaller than the hots, and if al loads are on one leg, it could very easily be overloaded. The neutral does not have overcurrent protection.
Rob
micromind is offline
Old 06-22-2010, 09:06 PM   #5
Skipp's Avatar
Rewards Points: 250
Even when using one side of the panel, you are still alternating between hot legs. So you're still using both (or all three if 3 phase) when only taking circuits from either side.
Skipp is offline
Old 06-22-2010, 09:15 PM   #6
evil bastard
mcclary's electrical's Avatar
Rewards Points: 746
Balancing a panel has nothing to do with what side you're on, but rather what phase the loads are on. You could have 20 spaces of a 40 space panel, all on the same side. If arranged correctly, the service will be balanced, rearrange, and it could be unbalanced. The sides have no bearing on the balance.
mcclary's electrical is offline
Old 06-22-2010, 09:22 PM   #7
drsparky's Avatar
Rewards Points: 386
I've always wondered is a POCO meter measured both legs and added them together or just used one leg and doubled it.
drsparky is online now
Old 06-22-2010, 10:33 PM   #8
Speedy Petey's Avatar
Rewards Points: 2,156
Please take a moment to post your question at www.DIYChatroom.com If you're not already a member of DIYChatroom.com you can sign up for a free account by going to http://www.diychatroom.com/register.php/
Speedy Petey is offline
Closed Thread
load demand, & load meter pimpin electrician General Electrical Discussion 3 05-25-2010 10:49 PM
How to calculate No load current and No load torque in DC Motor AMIanna General Electrical Discussion 3 05-21-2010 09:15 AM
Voltage balance (two sources) tomatina General Electrical Discussion 12 04-09-2010 07:03 AM
transformer balance SVERBERNE General Electrical Discussion 10 09-15-2009 09:13 AM
Load Bank Generator Testing vs. Using Building Load to test generators. MR MAB Other Codes and Standards 15 03-16-2009 06:37 PM
