Cat 5e conduit fill. - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Old 06-02-2011, 11:11 AM   #1
Default Cat 5e conduit fill.
What size emt conduit can you use for 33 cat 5 e cables.
MDNY3 is offline   Reply With Quote
Old 06-02-2011, 11:26 AM   #2
I own stock in FotoMat!
Rewards Points: 6,520
Contact the manufacturer and ask for the outside diameter of the cable you're using. Then use Notes 5 and 9 in Chapter 9.
janagyjr (06-02-2011)
Old 06-02-2011, 12:11 PM   #3
Thanks
Old 06-02-2011, 12:23 PM   #4
BDB
Rewards Points: 570
4 pair cat 5E ....36 cables in a 2 1/2" and 50 in a 3"
BDB is offline   Reply With Quote
Old 06-02-2011, 12:42 PM   #5
Ayuh
Ima Hack's Avatar
http://www.midwestamericom.com/white...ty%20Table.pdf
Good electricians aren't cheap, cheap electricians aren't good.
Ima Hack is offline   Reply With Quote
Old 06-02-2011, 12:46 PM   #6
BBQ
Salty Member
BBQ's Avatar
FWIW the NEC does not care if you stuff the cables in, there is no fill limit for data cables.
However, other standards likely restrict the fill more than the NEC would.
Old 06-02-2011, 08:22 PM   #7
NO high voltage here
Rewards Points: 1,248
you need to look in the eia/tia, not nec
Old 06-02-2011, 08:24 PM   #8
jza
Mad as Hell Member
jza's Avatar
Rewards Points: 2,302
1/2 inch if you remove that pesky blue insulation.
jza is offline   Reply With Quote
The Following User Says Thank You to jza For This Useful Post:
randas (06-03-2011)
Old 06-02-2011, 10:32 PM   #9
God-fearing Volt-head
janagyjr's Avatar
Rewards Points: 520
Send a message via ICQ to janagyjr Send a message via AIM to janagyjr Send a message via MSN to janagyjr Send a message via Yahoo to janagyjr Send a message via Skype™ to janagyjr
You mean that pesky blue insulation which keeps those wires nicely bundled?
Owner, Trinity Electrical and Handyman Services
All original content licensed via the OWL (http://owl.apotheon.org) from date of post.
My work truck
janagyjr is offline   Reply With Quote
Old 06-02-2011, 11:21 PM   #10
its not needed. its just there to look cool anyway
The Following User Says Thank You to mikeh32 For This Useful Post:
randas (06-03-2011)
Old 06-02-2011, 11:37 PM   #11
janagyjr's Avatar
Rewards Points: 520
I like the fact that it keeps the wires nicely bundled in each cable, needed or not. To each their own. TIA/EIA standards, afaik, are not law. YMMV.
My work truck
Old 06-03-2011, 12:56 AM   #12
Ambassador of Amps
TOOL_5150's Avatar
Rewards Points: 2,114
that what cat5e cross connect wire looks like...
I HAVE THE RIGHT TO OFFEND ANYONE I PLEASE. YOU HAVE THE RIGHT TO BE OFFENDED, YOU DO NOT HAVE THE RIGHT TO SHUT ME UP.
Old 06-03-2011, 06:13 PM   #13
jza
Mad as Hell Member
jza's Avatar
You don't know what you're talking about.
Old 06-03-2011, 07:26 PM   #14
janagyjr's Avatar
Rewards Points: 520
Are you insinuating that I have no idea what Cat5e cable looks like? Or that perhaps I've never terminated it? Or even pulled any (of the three assumptions you could make, this would be the only one that's true)?
My work truck
Old 06-04-2011, 12:06 AM   #15
jza
Mad as Hell Member
jza's Avatar
The blue insulation is only there to ease pulling it through a ceiling or walls.
The pipe would replace this insulation. It's redundant to leave it on.
Old 06-04-2011, 01:45 AM   #16
Data Tech/Apprentice.
Rewards Points: 22
Your kidding me? You will get a wiremap if that's all you test for... Put a fluke scanner on it and you will see why not to do that and to keep cable de-sheathing to a minimim when terminating ends, the inner insulation is super fragile and will burn through when you pull it.
Old 06-04-2011, 01:51 AM   #17
Spaghetti Cleaner
Rewards Points: 524
The outer jacket is also there to reduce cross talk.
A compliant installation has no more then 1/2" from end of jacket to termination point.
Thread shorter.
sarness is offline   Reply With Quote
Old 06-04-2011, 08:04 AM   #18
janagyjr's Avatar
Rewards Points: 520
Sometimes, I actually do know what I'm talking about.
My work truck
Old 06-04-2011, 10:09 AM   #19
3rd Generation
MF Dagger's Avatar
Rewards Points: 1,010
Recently I was trying to decide a conduit size for some cat5's and some coax. Two observations
1. The manufacturer I looked at and the dimensions I used from them had 2 Cat5e's as equal in area as 1 RG-6Quad. Exactly equal. Coincidence?
2. Whatever conduit size you think you should use, upsize it one size. I would have really been happy had I gone with my gut and gone one size larger.
Beercan ceiling fan.
MF Dagger is offline   Reply With Quote
Old 06-04-2011, 10:30 AM   #20
Rewards Points: 3,855
Apparently, data installers are super weak human beings. They want 1" pipe for single cable data drops, and 4" for a couple cables between IDF's. You need to keep this handicap in mind when running pipe for these delicate flowers we call low voltage installers.
Tags
eia, networking
Conduit Fill GEORGE D NEC Code Forum 17 03-07-2011 06:42 PM
Conduit fill for protection jwjrw NEC Code Forum 44 10-22-2010 06:48 PM
Need help with conduit fill nitro71 NEC Code Forum 5 07-24-2010 10:52 PM
Conduit fill and de-rating BruceB NEC Code Forum 11 09-21-2009 10:39 PM
Conduit Fill Roger123 General Electrical Discussion 10 10-10-2007 11:08 PM
