Funny Electrical Questions - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Old 04-22-2011, 04:48 PM   #1
Rewards Points: 356
Default Funny Electrical Questions
Many of you may have seen these as they have been around but I thought I would post them for the newer members.
I thought these questions would be helpful to those studying for the electrical exam. I think it will be very helpful for inspectors as well as contractors to refresh what they should know. Email me if you need answers....
1. What color is a green ground screw?______________________
2. Electricity will leak out of pipes if you do not use rain tight fittings. T F
3. To trip a circuit breaker, you must stick out your foot as it walks by. T F
4. When dealing with conduit, the O.D. must exceed the I.D. or the hole will be on the outside. T F
5. A keyless fixture cannot be unlocked. T F
6. A circuit breaker reads "20" on the handle. This means it can trip 20 times before it is worn out. T F
7. If you plug something 110 volts into a 120 volt outlet, you will have 10 volts leakage. T F
8. When hooking up a 220 volt device, you must use 220 volt wire. T F
9. The gauge number of a wire is the number of plugs the wire can handle. T F
10. A flush mount device may only be hooked up to a toilet. T F
11. An ohm is a Hindu measurement of voltage. T F
12. Electrical Inspectors are also know as: _____________________
13. Service Entrance Conductors direct from the supply house with current already in them are very dangerous. T F
14. High voltage wire is used on upper levels of tall buildings whereas low voltage wire is usually found in the basement or underground. T F
15. If you have a molded-case circuit breaker, the mold can be washed off with warm soapy water. T F
16. Three ECs enter an empty room and lock the only entrance: the door. All have on a tool-belt with a regular screwdriver, a pair of lineman's pliers, and a roll of Scotch-33. The light overhead is supplied by a sinusoidal voltage source and the light has a 0.935% power factor. Harmonics are not a factor, but the Carnot Cycle might be. The next morning, all three ECs leave the room and lock the door behind them. How many ECs are left in the room? __________
The Following 4 Users Say Thank You to Dennis Alwon For This Useful Post:
Bama (04-22-2011), ce2two (04-22-2011), Demac (04-22-2011), The_Modifier (04-25-2011)
Old 04-22-2011, 05:17 PM   #2
Coaster Sparky
thegoldenboy's Avatar
Rewards Points: 1,000
1. What color is a green ground screw? Green
12. Electrical Inspectors are also know as: ___***holes___
16. Three ECs enter an empty room and lock the only entrance: the door. All have on a tool-belt with a regular screwdriver, a pair of lineman's pliers, and a roll of Scotch-33. The light overhead is supplied by a sinusoidal voltage source and the light has a 0.935% power factor. Harmonics are not a factor, but the Carnot Cycle might be. The next morning, all three ECs leave the room and lock the door behind them. How many ECs are left in the room? _____3_____
I passed.
I saw a girl texting & driving the other day & it really made me mad, so I rolled down my window & threw my beer at her.
thegoldenboy is offline   Reply With Quote
Old 04-22-2011, 05:28 PM   #3
Rewards Points: 356
Originally Posted by thegoldenboy View Post
I passed.
You got the last one wrong.
Old 04-22-2011, 05:29 PM   #4
Coaster Sparky
Now I'm currently reconsidering my choice of profession.
Old 04-23-2011, 08:47 PM   #5
Davidg408's Avatar
Rewards Points: 252
That's freakin' hilarious!!!!!!
The sword is only as powerful as its master
Davidg408 is offline   Reply With Quote
Old 04-23-2011, 10:33 PM   #6
no **** just so our teacher said he gave us work he gave us a test with questions like that.
kdoyle201192 is offline   Reply With Quote
Now that's funny! LARMGUY Off Topic (Non Trade) 0 12-09-2010 11:28 PM
Electrical student looking for a few helpfull interview questions answered Matt(NEIT) Introductions 4 07-03-2010 02:54 PM
How funny is this Skipp General Electrical Discussion 35 05-26-2010 04:55 PM
Utah Electrical Questions. Justin_Haze General Electrical Discussion 8 03-24-2010 03:37 PM
This is funny blueheels2 Off Topic (Non Trade) 18 01-11-2010 09:55 AM
