Getting brakes changed - Page 2 - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Like Tree25Likes
Old 11-27-2016, 03:02 PM   #21
Signal1's Avatar
Rewards Points: 714
^^^Perfect post by @frenchelectrican^^^ I used to work in an auto parts store in high school.
This is the stuff he's talking abouthttp://shop.advanceautoparts.com/p/c...016/12032707-p
Majewski likes this.
The Following User Says Thank You to Signal1 For This Useful Post:
frenchelectrican (11-27-2016)
Old 11-27-2016, 03:37 PM   #22
still in business
sbrn33's Avatar
Rewards Points: 3,226
Supposed to put that on when the before the brakes are installed. Any good mechanic knows that. He needs to find a new one.
Old 11-27-2016, 04:00 PM   #23
Rewards Points: 3,812
Just don't let air go back up the brake lines, the ox sensors are expensive to replace.
Old 11-27-2016, 10:13 PM   #24
cabletie's Avatar
Rewards Points: 102
Sometimes the brake hoses going to the caliper collapse. It happens inside the hose so you can't see it.
I had problems with a caliper hanging up so flushed out the fluid and replaced the caliper. It was still wearing the pads faster on that wheel. So asked a mechanic what it could be. He said try the hose. That fixed it.
frenchelectrican and WronGun like this.
The Following User Says Thank You to cabletie For This Useful Post:
telsa (11-27-2016)
Old 11-27-2016, 10:26 PM   #25
Rewards Points: 14,658
Faults within the (vacuum assisted) power booster also do not show up.
Some indications: lousy gas mileage, sluggish acceleration, plenty of brake wear.
What's happening is that the booster is applying pressure even when your foot is off the brake.
This can also cause your brakes to squeal, too -- if conditions line up.
Old 11-27-2016, 10:31 PM   #26
corn-fused
papaotis's Avatar
Rewards Points: 406
WOW! after reading all this i see there no brake mechanics here! why would you take your vehicle back to same shop that already screwed it up twice? there is no grease that fixes a caliper, its only for the 'slides' that the caliper moves on. a stuck caliper there is no cure for except to replace or rebuild( unless youre familiar with this and have the tools, dont)
The Following User Says Thank You to papaotis For This Useful Post:
MechanicalDVR (11-27-2016)
Old 11-27-2016, 11:59 PM   #27
Deplorable-Electrician
Rewards Points: 27,846
And no mention of the clip that goes on th eback of the piston side pad to lock it to the piston.
There is grease to keep the shoes from rubbing on the backer plate on drum brakes. Never greased pads or any parts for disc brakes.
Old 11-28-2016, 12:15 AM   #28
cabletie's Avatar
Rewards Points: 102
I have only used caliper lube on the glides like papaotis mentioned. Sometimes that RTV stuff to get the pads glued on and stop rattling.
The only grease I ever heard off was a used car dealer trick. They would pack the old wheel cylinder with grease so you didn't see the break fluid leaking from the cylinder. Never believed they would do it. By the time you could do that, you could hone it and use a cheap rebuild kit.
Today it is only a little bit more for a new caliper than it is for the rebuild kit. Probably because of trade deals with china.
papaotis likes this.
Old 11-28-2016, 12:36 AM   #29
frenchelectrican and papaotis like this.
telsa (11-28-2016)
Old 11-28-2016, 03:02 AM   #30
The last mechanic to work on my pick-up screwed me. He could've killed me.
So, I made life simple.
I just bought new parts for everything.
Believe me, assembling brand-new OEM parts goes very sweet.
Mechanics look upon tradesmen as 'marks.'
Probably because they've learned that anyone trusting them to do right must be a chump.
Old 11-28-2016, 04:46 AM   #31
Signal1's Avatar
Rewards Points: 714
put little grease on the slider for calipers
disc brake quiet is not grease, it basically forms a kind of rubber coating on the back (metal part) of the pad, you're supposed to let it dry before it goes in the caliper. A little ketchup pack usually comes in the box with the pads but it's not enough.
frenchelectrican likes this.
Old 11-28-2016, 04:49 AM   #32
Signal1's Avatar
Rewards Points: 714
Like so. I usually do it first, so it can dry while I'm taking the wheels off and brakes apart.
The Following 2 Users Say Thank You to Signal1 For This Useful Post:
frenchelectrican (11-28-2016), Suncoast Power (11-28-2016)
Old 11-28-2016, 05:09 AM   #33
Signal1's Avatar
Rewards Points: 714
Also Wrongun you should always request OEM parts, for your E250 van those are Motorcraft.
Old 11-28-2016, 11:07 AM   #34
Rewards Points: 1,518
i generally change caliper each time i change disc on my 1500 2002 gmc, they are just 35-40$ each for exchange!!
Old 11-28-2016, 03:59 PM   #35
WronGun's Avatar
Rewards Points: 294
Default Getting brakes changed
This whole thing is annoying ... anyways I bitched and brought the vehicle back..... they took all of their stuff off and started over with brand new parts.... they are using the premium Napa parts which probably aren't premium to begin with.... new pads, new rotors , new calipers , new hoses, and fluid flush, and oil change is going to run about $725 with tax, 400 of which I already paid the first time .... so I'll be spending another 325...I don't have the tools, time, or experience to do this myself.. plus I live in a uppity town home community and they don't want to see me in my driveway changing my van brakes ! Lol
Old 11-28-2016, 04:11 PM   #36
Rewards Points: 2,522
Best auto repair book I ever bought was
How to Keep Your Volkswagen Alive:
A Manual of Step by Step Procedures for the Compleat Idiot
by John Muir
Muir said something smart about brakes, ''The ability to stop is often more important than any other capability-humans, cars, whathaveyous. Do a good slow solid job on your brakes''.
John Muir would agree with your decision.
WronGun likes this.
Old 11-28-2016, 04:14 PM   #37
WronGun's Avatar
Rewards Points: 294
They pulled the wheels off and showed me the the caliper situation.... the rust is preventing them from releasing all the way....2006 e350..... only 51,000 miles but 11 yrs old now
Old 11-28-2016, 07:04 PM   #38
That is really strange, I have owned a boatload of vehicles and have yet to change a caliper on any of them.
Old 11-28-2016, 07:10 PM   #39
WronGun's Avatar
Rewards Points: 294
Just picked it up ... all fixed.... quiet and responsive
Old 11-28-2016, 07:11 PM   #40
Rewards Points: 1,246
That kinda waste money on that if the caliper is working properly.
As long you dont see rust stain on pistion ya should be fine.
One way I do is crack open the brake line and see if you have clear fluid or not if dark color it will be wise to check more closer to see if you have rust in there and ya have to bleed it out some to get old fluid out.
Once that clear up then it should be good to go for long time.
How have you changed your wiring? meadow General Electrical Discussion 19 05-13-2016 03:43 PM
Right orientation of receptacle per CEC? nomadapower Canadian Electrical Code Forum 45 03-28-2016 11:49 PM
Have You Changed Your Business Structure? Cricket Business, Marketing, and Sales 2 01-14-2016 07:31 PM
