Go Back   Electrician Talk - Professional Electrical Contractors Forum > Community > Off Topic
Old 10-07-2007, 01:38 AM   #1
Default I want one... hot dog cooker
Check this out. A pop up hot dog cooker, that works just like a toaster. Cooks the dogs and toasts the buns. 50 bucks. Cool.
http://www.hammacher.com/publish/50929.asp
Old 10-07-2007, 08:48 AM   #2
I made my own out of two strands of solid #10 stuck in a wall receptacle then one in each end of the hot dog. Less than $50.
H&S has some crazy stuff!
Old 10-07-2007, 09:33 AM   #3
Seen your member
I just used an old extension cord. Cut the female end off, strip & solder the two wires. Stick one in each end of the 'dog, and plug it in.
Piping hot in 10-15 seconds.
Old 10-07-2007, 09:39 AM   #4
But how do you toast the buns?
Old 10-07-2007, 10:17 AM   #5
I pull my dogs on a plain old stick and over a created heat & light apparatus in the back yard! Bestest tasting dogs ever!
Old 10-07-2007, 10:46 AM   #6
500 watt halogen of course.
Old 10-07-2007, 11:05 AM   #7
Seen your member
Propane torch. Hot box. Heat gun. Construction heater.
Old 10-07-2007, 04:17 PM   #8
8 grams of cardiac arrest packed into each and every single one YUMMY. Gotta be honest though, I used to often enough go for the Polish Dog at the Costco on a regular basis when I was young enough that it wouldn't show up south of the belt border.
Old 10-07-2007, 07:54 PM   #9
Haven't eated a hot dog, half smoke, ect in 36 years.
Old 10-08-2007, 06:20 PM   #10
"Euro" electrician
Just dont laugh at me for a min but i did use big 400 W HPS for a toaster for my hotdog bun.
dang , that bulb did put out pretty serious amount of heat lol.,,
but i did have one hot dog cooker that was made by Presto many moon ago i think Marc [ MDshunk ] did post it here or other fourm i am not sure if he did that.
the other fast way to cook the hotdog is wrapped in alum foil with about 3 layers thick and set top of the exhaust manfold of either gas or diesel engine and that will be done about 3 min or so depending how hot the manfold is.
Merci, Marc
Old 10-08-2007, 06:28 PM   #11
kbsparky's Avatar
dang , that bulb did put out pretty serious amount of heat lol....
Betcha that bulb would cook the dog quite easily, as well! Just put it on a stick and hold nearby, just like you would do over a campfire ...
Old 10-08-2007, 07:29 PM   #12
"Euro" electrician
Kbsparky :
sure why not that will get a nice high voltage flavored one lol
merci, Marc
Old 10-08-2007, 10:58 PM   #13
"A" inside wireman
randomkiller's Avatar
Hooked up some equipment in a food plant that makes sausage, hotdogs, and similar products. Once you have seen them made, you dont desire to eat them any longer.
"One Nation Under God"
Old 10-08-2007, 11:01 PM   #14
I don't know about that. I hooked up some equipment in a new slaughterhouse that slaughters goats, and I still like to eat.... oh, wait... I never really ate goat meat in the first place.
Old 10-09-2007, 06:57 AM   #15
"A" inside wireman
I havent eaten goat that I know of but I do find Thai sesame musk rat really good, rattlesnake and alligator are also pretty good. I hate to admit it but puppy legs that I had without knowing in Korea are really good. I have never worked on a slaughter house but I did work on a dog food factory where horse is the primary meat in the rendering pots, that will take your appetite for a day or til you get the smell out of your memory.
Old 10-09-2007, 05:17 PM   #16
My first wife worked in the regulatory division of USDA for processed meats, after a bout with food poisioning after eating a hot dog then reading the literature she brought home I swore off the winnies.
Old 10-09-2007, 06:52 PM   #17
"A" inside wireman
I did a lot of the machine control wiring for the process plant I mentioned before, so I was there when they started up the line. There was a whole lot more than meat and meat products going in those dogs. I saw bags of cellulose fiber, bone meal, and some stuff that looked like wet saw dust going in the hopper. That was enough for me.
Old 10-10-2007, 05:55 PM   #18
It was 35 years ago I read this but I do remember the 1% (maybe more) inert ingredients that could include hair and animal byproducts.
Old 10-13-2007, 05:21 PM   #19
"A" inside wireman
"byproducts" does that mean the stuff was in the container by the meat products?
Old 10-13-2007, 06:43 PM   #20
They way it was explained to me rodent hair feces, bugs, ect.......
