Go Back   Electrician Talk - Professional Electrical Contractors Forum > Community > Off Topic
Old 08-11-2009, 08:19 PM   #1
Senior Moment
rlc3854's Avatar
Default New Electric Car System
Ok, here we go gas problems solved and new revenue for electricians.
http://www.wired.com/autopia/2009/08...tic-slot-cars/
rlc3854 is offline   Reply With Quote
Old 08-11-2009, 08:28 PM   #2
The designer has umlauts in his name. Never trust someone with umlauts.
Old 08-11-2009, 08:34 PM   #3
Nobody read me my rights!
Why? Is it because it's 120volts, which is illegal as of today?
WWWWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAa aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhh hhhhhhhhh!
Old 08-11-2009, 08:44 PM   #4
No silly, because they're umlauts. So did everyone make the 230 V transition smoothly? Mine went off without a hitch.
Old 08-11-2009, 08:45 PM   #5
Related to electric cars.... I honestly picture a day where so many electric cars are plugged into the grid to recharge that we can use them as micro distributed peak shaving plants (un-charge them when need be). That could potentially offset construction of generation plants, make transmission scheduling easier, and keep energy prices lower.
I'm an electrician, not a magician.
Old 08-11-2009, 08:52 PM   #6
YYeess. AAbboouutt tthhee oonnllyy pprroobblleemm II sseeeemm ttoo hhaavvee iiss mmyy ccoommppuutteerr wwaannttss ttoo ddoo eevveerryytthhiinngg ttwwiiccee bbeeccaauussee II ffoorrggoott ttoo cchhaannggee tthhee sswwiittcchh iinn tthhee bbaacckk ooff tthhee ttoowweerr ttoo 224400 vvoollttss.
Old 08-11-2009, 08:56 PM   #7
Senior Moment
rlc3854's Avatar
Chevy 230 Volt
Old 08-11-2009, 09:05 PM   #8
Bob Badger's Avatar
Your still using the model T of computers.
You need a new 'puter, most self adjust, no more switches.
Old 08-11-2009, 09:28 PM   #9
II''mm nnoott ccoommppllaaiinniinngg.. MMyy mmoonniittoorr iiss qquuiittee bbrriigghhtt nnooww.. AAnndd II''mm ssttiill uussiinngg aallll mmyy oolldd 112200 vvoolltt bbuullbbss,, ssoo II lliigghhtt tthhee hhoouussee uupp rreeaall wweellll nnooww. SShhoouulldd ssccaarree aallll tthhee bbuurrggllaarrss aawwaayy aass wweellll.
Old 08-12-2009, 02:45 AM   #10
Master RAT!!!
Shado's Avatar
Just crack me up why don't you......
- Dave ........
Shado is offline   Reply With Quote
Old 08-12-2009, 06:13 AM   #11
Toronto Sparky's Avatar
http://www.theglobeandmail.com/repor...rticle1247751/
Don't fight .. Play nice!
Toronto Sparky is online now   Reply With Quote
Old 08-12-2009, 09:38 PM   #12
TTTThhhheeee ppppoooowwwweeeerrrr ccccoooommmmppppaaaannnnyyyy mmmmuuuusssstttt hhhhaaaavvvveeee bbbbeeeennnn bbbbyyyy aaaaggggaaaaiiiinnnn ttttooooddddaaaayyyy bbbbyyyy mmmmiiiissssttttaaaakkkkeeee aaaannnndddd ddddoooouuuubbbblllleeeedddd mmmmyyyy vvvvoooollllttttaaaaggggeeee aaaaggggaaaaiiiinnnn....
NNNNoooowwww IIII aaaammmm rrrruuuunnnniiiinnnngggg oooonnnn 444488880000 vvvvoooollllttttsssss!!!!!!!!!!!!!
Old 08-12-2009, 09:49 PM   #13
I bet your fridge is real cold now!
Old 08-12-2009, 09:55 PM   #14
Is it ok if I tell you you're out of your mind? That would require massive use of grid tie inverters, which would cost a bloody fortune. Granted, I suppose this feature could be built into the charger itself, but it would still be quite silly if you ask me.
Old 08-12-2009, 09:57 PM   #15
Originally Posted by Peter D View Post
Is it ok if I tell you you're out of your mind? .
Yes, as long as you don't mind if I ask you to take your place in line.
Old 08-12-2009, 09:59 PM   #16
Not only that, the electric car's battery could potentially be drained in the morning from this "peak shaving" usage you speak of. You're nuts.
Old 08-12-2009, 10:03 PM   #17
WWWWhhhhyyyy,,,, yyyyeeeessss iiiitttt iiiissss.... AAAAbbbboooouuuutttt 444499995555°°°°RRRRR....
Old 08-12-2009, 10:23 PM   #18
Wow, your new voltage even jolted the Rankine scale back from the dead! If they double it again, do you think you could revive the Reaumur scale too?
Old 08-15-2009, 07:40 PM   #19
D³a³r³n³e³d³....... P³O³C³O³!³ .......T³h³e³y³...... u³p³p³e³d³ .......m³y³ ...... v³o³l³t³a³g³e³ .......a³g³a³i³n³!³
N³o³w³ .......m³y³ .......c³o³m³p³u³t³e³r³ .......w³o³r³k³s³ .......o³n³l³y³ .......i³n³ .......s³c³i³e³n³t³i³f³i³c .......e³x³p³o³n³e³n³t³i³a³l³s³!³
Wireless P.A. system NolaTigaBait Structured Wiring 27 08-11-2009 10:29 AM
Carter System? hbgorr General Electrical Discussion 19 03-20-2009 06:42 PM
Ungrounded system? Ray Cyr Services and Service Equipment 6 02-05-2009 12:04 PM
need a better/different lightin system nap Lighting Design 16 03-06-2008 10:36 PM
New lighting system Joe Momma Lighting Design 11 02-14-2007 03:29 PM
Electrician Talk © 2006 - 2010 The Building Network LLC
