One way moving truck with a lift gate? - Electrician Talk - Professional Electrical Contractors Forum
Go Back   Electrician Talk - Professional Electrical Contractors Forum > Electrician Talk Community > Off Topic (Non Trade)
Like Tree21Likes
  • 2 Post By Bird dog
  • 6 Post By splatz
  • 6 Post By Switched
  • 2 Post By Cow
  • 1 Post By Suncoast Power
  • 2 Post By splatz
  • 2 Post By MikeFL
Old 03-20-2017, 03:01 PM   #1
Rewards Points: 42
Default One way moving truck with a lift gate?
I'm moving from Houston, TX to Plant City, FL. I had planned on getting a 26 foot moving truck with a lift gate. I've now learned that "one way truck" and "lift gate" don't go together in the same sentence. Pretty aggravating.
I hate using the ramps. Lift gates are SO much easier. Especially on the big, bulky, heavy stuff. I've got a welding machine to move that is too wide for the ramp, and too dang heavy to lift up. It is on wheels.
Any of you folks know of a rental company that does one way with a lift gate? Penske and Budget have lift gate for round trip only. Enterprise doesn't do one way. U-haul doesn't do lift gates.
I looked at renting a local (round trip rental) truck with lift gate, but the mileage charges would double the rental charge.
Real pain in my arse at the moment.
McDaniel8402 is offline   Reply With Quote
Old 03-20-2017, 06:00 PM   #2
Rewards Points: 614
Rent a truck with a liftgate to load welder onto truck with no liftgate. Get to Florida & do opposite. Or build a wood ramp you can take along with you.
brian john and MechanicalDVR like this.
Old 03-20-2017, 06:50 PM   #3
Click Here
Rewards Points: 4,898
I know this isn't optimal, but Harbor Freight has those engine cranes for $200. They are rated at 4,000lbs, which I am sure your welder doesn't come close to. And you can probably find many other uses for this in the future, such as generator placing.
Old 03-20-2017, 07:12 PM   #4
Rewards Points: 1,624
Yeah the engine hoist will be too big to lift into the truck too but you could use the welder to cut it into pieces and reassemble it in Florida.
readydave8, wendon, telsa and 3 others like this.
MikeFL (03-20-2017)
Old 03-20-2017, 07:18 PM   #5
Rewards Points: 4,328
What about one of those companies that drops off the storage containers, ships them to your new location and picks them up when done? Those are at ground level.
The Following User Says Thank You to Switched For This Useful Post:
MikeFL (03-20-2017)
Old 03-20-2017, 07:35 PM   #6
Click Here
The Harbor Freight one is pretty light and foldable.
Old 03-20-2017, 10:57 PM   #7
Cow
Rewards Points: 2,282
Post your load on Uship and let someone else deal with loading and unloading it.
It's worked well for me in the past.
MechanicalDVR and telsa like this.
Suncoast Power (03-21-2017)
Old 03-21-2017, 05:03 AM   #8
Semper Fidelis
Suncoast Power's Avatar
Rewards Points: 4,284
I'm thinking that if the welder is your only show stopper, I would find a way to get it up that ramp.
Or, pull a rented trailer or car hauler with the box truck.
telsa likes this.
Old 03-21-2017, 05:54 AM   #9
MechanicalDVR and Bird dog like this.
Old 03-21-2017, 05:56 AM   #10
Rewards Points: 12,430
Just so.
Don't think outside the box... think behind the box, truck.
Old 03-21-2017, 08:18 AM   #11
Small Potatoes
flyboy's Avatar
Rewards Points: 384
You have a "too heavy" and "too wide" welder.
Sell the old one on eBay and buy a newer, lighter and more compact welder when you get to the new location.
The Following User Says Thank You to flyboy For This Useful Post:
Old 03-21-2017, 09:08 AM   #12
Deplorable-Electrician
Rewards Points: 18,640
Unless you had a truck with a really low bed the engine lift wouldn't have the height to get the welder high enough. The Budget trucks I used to move the last time were way too high for an engine hoist to work. Roller cabinets were hard enough getting up and down the ramp.
DJT, making libtards cry since 20 Jan 2017
Old 03-21-2017, 09:42 AM   #13
Rewards Points: 224
I've got a 14' truck with a ramp. When I have to move a condenser we just slide it up on top of the ramp on the little curbs that keep your dolly from rolling off. Any chance you could take an old piece of carpet, fuzzy side down, and just slide the welder up with the wheel hanging over the edges of the ramp?
Old 03-21-2017, 10:04 AM   #14
MikeFL's Avatar
Rewards Points: 762
Send a message via Skype™ to MikeFL
Here you go brother. Someone did all the work for you.
One-way moving trucks with lift gate:
http://firstquarterfinance.com/renta...o-choose-from/
telsa and splatz like this.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
Old 03-21-2017, 11:29 AM   #15
Rewards Points: 856
Just think! You move across the country, and when you arrive in Plant City, you realize you never left Texas!
Service body truck and conduit ponyboy General Electrical Discussion 13 11-21-2016 09:17 PM
New here...tips on running electric wire to my front gate about 300ft from the house oxonian General Electrical Discussion 5 09-09-2016 01:44 PM
Scissor vs vertical master lift gom9112 Tools, Equipment and New Products 16 07-17-2016 05:34 AM
Bucket Truck Issues BrokenCastle General Electrical Discussion 18 05-25-2016 10:37 AM
price range for first work truck???? los0515 Business, Marketing, and Sales 37 02-27-2016 12:32 AM
