Its a 35 watt iron. I have a length of 12 gauge copper wire wound around the tip and coming off at a 90 deg angle, sharpened to a needle tip. I was using a regular small point iron, but i had to hold the thing straight up and down to get to the board and the iron got in the way of my vision. With the 90 deg tip, I can bring the iron in from the side, much easier.
I do use an optivisor which is 4x magnification. I can only work on the small stuff for about a half hour at a time, then the vision gets wonky and the hands start shaking.
Arc Angle - Geometry will save us.
