Go Back   Electrician Talk - Professional Electrical Contractors Forum > Community > Site Help and Suggestions
Closed Thread
Old 04-09-2009, 03:15 PM   #1
Default high resistance?
This connection (in pics) is located in a electrical sub base below PTAC unit (a/c,heat combo) through the wall. This is the third unit failure and is very concerning. The wiring practice of the previous employee worries us. The cord from the a/c unit has a very thick insulation and when attached with a wire nut it did not seem to be a proper fit causing, what I believe, to be arcing in the wire nut until it fails. Does this theory seem valid? These connections are about 4 to 5 years old (if that info helps).
My background: I was an industrial electrician for over 6 years, yes I served my apprenticeship, but do to the economy I moved out of the service area and took a job in charge of maint. in a high end senior building. Any thoughts on the faults?
Thanks.
http://s578.photobucket.com/albums/s...albumview=grid
3tigerz is offline
Old 04-09-2009, 03:22 PM   #2
sorry posted in wrong cat.
3tigerz is offline
Old 04-09-2009, 03:24 PM   #3
JohnJ0906's Avatar
No connector or strain relief on that cord?
Just wire it up and shove it into the unit?
Yes, you should be concerned, and worried. Was this employee an electrician?
I wonder why the PTACs didn't come with a factory connected cord.
John from Baltimore
"One day at a Time"
JohnJ0906 is offline
Old 04-09-2009, 03:34 PM   #4
Duplicate.
Go here: high resistance?
Speedy Petey is online now
Closed Thread
Ground Rod Resistance Billy716 NEC Code Forum 42 07-05-2009 10:07 AM
calculating resistance of a wire mike4089 General Electrical Discussion 6 02-11-2009 08:29 PM
Resistance , Length calculation calimurray General Electrical Discussion 15 02-09-2009 04:36 PM
Ohms(resistance) Testing wallace7777 Services and Service Equipment 19 11-23-2008 02:54 PM
Ever have a fuse with an abnormal resistance? MNservicetech General Electrical Discussion 7 08-09-2008 01:21 PM
