120v flat wire - Electrician Talk - Professional Electrical Contractors Forum
Old 06-07-2011, 04:38 PM   #1
Rewards Points: 250
Default 120v flat wire
http://www.flatwireready.com/products/electrical.html
Anyone ever hear of this? Currently under UL testing.
Funny I was thinking years ago after seeing people run extension cords across the floor and under carpet if they could invent a flat extension cord
lovethetrade is offline   Reply With Quote
Old 06-07-2011, 04:46 PM   #2
Rewards Points: 1,006
Their speaker wire products are pretty cool. I like the paintable flat speaker wire you can glue to a wall and paint over.
I fear that someone would try the same thing with a 120v flat cable....and then try to nail a painting up, right through it. No doubt UL has the same reservations....
__________
Was born in HACKensack, NJ
CraigV is offline   Reply With Quote
Old 06-07-2011, 04:53 PM   #3
Rewards Points: 600
I use a hydraulic jack and a breaker bar, oh wait you said flat wire, sorry.
I installed a boat load of it in the late 70's early 80's.
Old 06-07-2011, 05:21 PM   #4
Rewards Points: 250
You intstalled 120v flat wire in the 70's?? I never knew it existed until today.
I know it's used inside laptops and other electronics sometimes called ribbon cable but never knew they had it for 120 volts.
Old 06-07-2011, 05:25 PM   #5
Rewards Points: 600
http://www.arcat.com/divs/sec/sec16128.shtml
http://www.ampnetconnect.com/documen...n_Rev4_Web.pdf
Old 06-07-2011, 05:27 PM   #6
BBQ
Salty Member
BBQ's Avatar
I bet he is talking about a different but similar product, that can be found in ARTICLE 324 Flat Conductor Cable: Type FCC
Old 06-07-2011, 05:30 PM   #7
Rewards Points: 250
"Southwire's revolutionary FlatWire, the Invisible Wire Solution®, has been approved for standard 120VAC electrical wiring applications in the 2008 National Electric Code (NEC). Under article 382 of the NEC, Concealable Non-Metallic Extension (CNE), the innovative surface-mount wiring technology that will present consumers with new opportunities in electrical wiring while greatly advancing safety."
Southwire claims this is revolutionary? If this has been around why are they saying it's revolutionary?
Old 06-07-2011, 05:32 PM   #8
Rewards Points: 250
Says it CAN'T be used in residential buildings.
120V Sub-Panel ? Cletis General Electrical Discussion 22 04-01-2011 12:21 AM
120V smokes Chris Kennedy General Electrical Discussion 25 01-17-2011 06:20 AM
Flat Wire??? rsihnhold General Electrical Discussion 15 08-12-2010 08:42 PM
120v ltg pnl tonydatank General Electrical Discussion 1 02-04-2009 04:58 PM
120v tap off a 240 v circuit dan NEC Code Forum 4 05-22-2007 10:48 PM
