120v wiring for a camper - Electrician Talk - Professional Electrical Contractors Forum
Old 10-15-2010, 07:58 PM   #1
Default 120v wiring for a camper
A friend wants me to wire a 120v plug and install 2 outlets in his camper trailer. I was wondering if I should connect the ground to the frame or not and if doing so would have any effect on the 12 volt trailer lights.
Basically I was thinking a weather proof "in box" plug on the outside wall with an in use cover, run pipe up the side and stub in over the counter to install a metal box with industrial plate and gfci receptacle. He would just plug in with a standard extension cord from the trailer to shore power. The 120v and 12vdc systems will not be interconnected.
What would be the best wire to use for protection against travel vibration? I was thinking SO cable.
I wanted to get some opinions on this.
Funkyjunk is offline   Reply With Quote
Old 10-15-2010, 08:44 PM   #2
Rewards Points: 1,464
When I do horse trailers,I use mc cable.
Old 10-15-2010, 11:00 PM   #3
Rewards Points: 2,000
I wired my trailer for both AC and DC supplies. I have an so cord hanging out the bottom of the trailer to connect to AC power with a transfer switch separating the AC feed from the inverter. If you use any kind of transfer switch type set up, make sure you separate the inverter neutral and the house/generator neutral. The electronics in the inverter may cause GFCI's to trip.
Depending on your load, you could probably run off of an inverter. I can get 12 hours of lights, fan, cell/ipod chargers, tv, and satellite of a small Toyota battery before inverter under voltage alarm goes off. I only fire up the generator for the microwave and air compressor.
Old 10-15-2010, 11:44 PM   #4
For an ac only outlet that is attached should I run a ground to the frame of the trailer?
Old 10-16-2010, 04:42 PM   #5
all the campers are grounded to the frame. the dc and the ac. so is the al outside. I have not seen one yet that isn't. Most camping trailors have a 30amp circuit 120v.
one2question is offline   Reply With Quote
The Following User Says Thank You to one2question For This Useful Post:
Funkyjunk (10-16-2010)
Convert 120v wiring to 12v wiring cobra50 Residential Electrical Forum 22 08-13-2010 01:47 AM
120v ltg pnl tonydatank General Electrical Discussion 1 02-04-2009 04:58 PM
120V Cubical Wiring.. assitance needed. jman General Electrical Discussion 3 07-16-2007 06:02 PM
120v tap off a 240 v circuit dan NEC Code Forum 4 05-22-2007 10:48 PM
