Old 10-27-2008, 08:06 PM   #1
Chairman of the Bored
BuzzKill's Avatar
Default 150 amp residential service question
I got a service call from a prospective homeowner who's house failed the initial house inspection before sale; among other issues in the house, there is a tap in the crawlspace of the service conductors leading to the panel from the main disconnect by the meter; there was a previous fire at the residence and my guess is the fire damaged the sevice conductors and the electrician simply spliced in part of a new service length to replace the said damaged service conductors. It was a decent enough tap, using pressure connectors/kerneys and bound with rubber tape, however it is not in a junction box. My plan is to save the homeowner some serious cash and just put the tap in a 12x12 can. Question is, is that okay according to the 2005 code? I can't find anything in it saying there can't be taps in the service (as long as the said tap is not feeding anything else).
Old 10-27-2008, 08:27 PM   #2
nap
a real PITA
these aren't service entrance conductors anymore. You did state there is a disco at the meter, right? Then they are simply feeders at this point. J-box away.
Old 10-27-2008, 08:30 PM   #3
BuzzKill's Avatar
thanks for the quick reply...duh! Feeders! Damn I was over thinking the situation again.
Residential Voltage Question Gummi Bear General Electrical Discussion 6 07-26-2008 11:02 AM
residential service changes liverstos General Electrical Discussion 8 07-07-2008 06:07 PM
Residential service dilema sparkysteve Services and Service Equipment 3 07-05-2008 06:49 PM
Residential 400a. Service Both Main Tripping Karpo1961 Services and Service Equipment 3 04-08-2008 11:14 PM
Residential Service Question tahoewire Services and Service Equipment 8 01-13-2008 10:49 AM
