Old 04-27-2009, 10:33 AM   #1
BIGRED's Avatar
Default 1900 boxes with plaster rings & metal studs
What is the best 1900 box or accessory, for metal studs, to keep the the box from pushing in opposite the stud side? Any tricks to fix existing boxes that push in?
BIGRED is offline   Reply With Quote
Old 04-27-2009, 10:37 AM   #2
Chief Electron Relocator
Erico Far Side Box Supports.
Old 04-27-2009, 10:41 AM   #3
Erico H23... AKA H-bracket
Old 04-27-2009, 10:46 AM   #4
We use caddy H23 for metal stud box supports. If you have 6" studs you will need different part #.
dawgs is offline   Reply With Quote
The Following User Says Thank You to dawgs For This Useful Post:
BBQ (11-13-2012)
Old 04-27-2009, 10:53 AM   #5
That would be this.
Old 04-27-2009, 11:31 AM   #6
That would be this.
And they make a nice 3-box rig too, for all those (power) (clean power/IG) (Data) triple-box applications.
Old 04-27-2009, 05:59 PM   #7
That would be this.
These are easy to prefab in the shop
user5941 is offline   Reply With Quote
Old 04-27-2009, 06:02 PM   #8
william1978's Avatar
Do they still sell those? I haven't seen those in a long time I bet atleast 12 years.
Old 04-27-2009, 06:03 PM   #9
An H6 is what you would need for a 6" wall.
Old 04-27-2009, 06:22 PM   #10
The pix are right from Erico's website.....
Old 04-27-2009, 07:10 PM   #11
I've used the H-23's for new work for probably 10-15 years. I fix one's that tip in by using the Caddy device leveling
ring on top of the drywall and tightening the yoke of the device up on the leveling ring really well.
Old 04-27-2009, 07:34 PM   #12
I guess what I meant to say is does anyone still use these?
Old 04-27-2009, 07:35 PM   #13
I know of one guy...... old geezer, kinda set in his ways.....
Old 04-27-2009, 07:43 PM   #14
Everybody that I know of around here use h23,h6 or other caddy brackets.
Old 04-27-2009, 09:28 PM   #15
Bababoee
captkirk's Avatar
thats what I always use. And you can use your standard 1900 stock without having to stock a different box with feet on it. very user/order friendly
Old 04-27-2009, 10:13 PM   #16
el abogado del diablo
we've been looking into these
Raco 189H
but no one carries them locally, or seems to even be able to get a price...
otherwise we've been using H23's with mudrings for the last 20+ years...
oldman is offline   Reply With Quote
The Following User Says Thank You to oldman For This Useful Post:
joe cool (11-12-2012)
Old 04-27-2009, 10:16 PM   #17
kbsparky's Avatar
We use a block of wood between the studs -- gives rigid mounting all around!
-KB
Old 04-27-2009, 10:29 PM   #18
Default Cave In???
Mounting box right next to stud Box frames with finger. Or box brackets easy to get from caddy cat.Today the rock crews slam boards up jamming most box's in ,then they roto just the inside perimeter of the p-ring. If your lucky the don't scar up the wires.I've come close to all out wars over this shoddy craftsmanship.But with the low payed imported workers it 's useless to stress over it. Now if the rough inspection is good. I photo the depth of the box's in a few places. If at devicing there's a problem I tell my guys to hole saw a couple to flush them up and the rocks guys can worry about it during the punch list review.
acmax is offline   Reply With Quote
Old 04-27-2009, 10:31 PM   #19
not when I got 250 boxes going in a building, and not a block of wood to be found
i know some guys use new work deep metal gems with the brackets...if they are on the open side of the stud, they will install a short length of metal stud over the open side to give them a solid stud to screw into...
Old 04-28-2009, 07:18 PM   #20
For a while my company was using these black plastic stud things that stabed into the back of the box. Pretty slick, cant remember the manufacturer or name of them though...
Shaffer87 is offline   Reply With Quote
Wedding Rings 480sparky Structured Wiring 28 11-07-2008 01:07 PM
ceiling studs olectric Workplace Safety 13 08-31-2008 04:32 AM
Grounding metal boxes Mackie NEC Code Forum 16 03-21-2008 11:36 PM
Earthing of Metal Back Boxes??? supasparx UK Electrical Forum 6 03-12-2008 06:18 PM
1900 boxes 480sparky Vintage Electrical 8 10-13-2007 01:56 PM
