210.8 A 3 and pumps - Electrician Talk - Professional Electrical Contractors Forum
Old 02-26-2012, 08:35 PM   #1
Podagrower's Avatar
Rewards Points: 568
Default 210.8 A 3 and pumps
Every outdoor receptacle at a house needs to be GFCI protected, unless it is for snow or deicing, fine.
I got a call today for a septic tank sewage pump that trips it's GFI, every once in a while (3 or 4 months). The float switch and pump are plugged into a weatherproof receptacle, with a in use cover, the GFI receptacle is not a WR type. The last septic pump I wired had a slick pedestal arrangement so that there was not a receptacle and no need for a GFI.
So far, the best solution I have for getting rid of the GFI is to cut off the plug ends and make the proper connections in a j box (knowing that one cord is the float switch that turns on the pump). Can anybody think of a better way?
Podagrower is offline   Reply With Quote
Old 02-26-2012, 09:17 PM   #2
Rewards Points: 262
Some of those cords cannot be cut as they may have breathers in them. I would check with the AHJ on this.
Old 02-26-2012, 09:18 PM   #3
Rewards Points: 262
NC has this amendment
Exception No. 2 to (3): A single outlet receptacle supplied by dedicated branch circuit which is located and identified for specific use by a sewage lift pump.
MHElectric (02-26-2012)
Old 02-27-2012, 01:08 AM   #4
Jlarson's Avatar
Rewards Points: 2,792
Megger the pump and cords before you go cutting cord ends off and getting rid of GFCI's.
The Following 2 Users Say Thank You to Jlarson For This Useful Post:
BBQ (02-27-2012), micromind (02-27-2012)
Old 02-27-2012, 04:32 AM   #5
BBQ
Salty Member
BBQ's Avatar
What a concept, locate and fix the problem instead of circumventing safety equipment.
Please help with alternating pumps kondia General Electrical Discussion 19 03-12-2014 02:07 PM
Boiler pumps backstay General Electrical Discussion 8 02-21-2012 12:39 AM
Sewage pumps nrp3 General Electrical Discussion 6 10-15-2011 12:26 PM
gfci's for pumps? Signalservice General Electrical Discussion 46 10-03-2011 06:45 PM
Pool pumps eds General Electrical Discussion 4 07-07-2010 06:38 PM
